nismopu »
https://forums.nicoclub.com/nismopu-u29994.html
Tue Dec 02, 2008 1:13 pm
ummm what? The piston did not get pushed into your head. You just need to rebuild your heads or go pull some heads off of a mercury villager, nissan quest, early 90's maxima, 93- up nissan pathfinder. The engine in your vehicle is barely an interference engine, the nissan quest and mercury villagers are non interferrence vg33's because of a deeper valve relief cut into the pistons. You've bent your valves and they need to be replaced or you can just go pull the heads off the above mentioned vehicles. peace.
