Thanks for any help.
Post Title: Re: Has anyone changed their own brakes (Indy Golfer)
Posted by: New2Import at 6:30 AM 7/3/2009
I know I could change pads if I had a step by step guide. I certainly would want it done correctly but I think dealers hold us hostage on this with knowledge they think we can't obtain.
Post Title: Re: Has anyone changed their own brakes (BigP)
Posted by: New2Import at 8:31 AM 7/3/2009
What brand of rotors and pads did you use? Did you notice any performance difference over the stock setup to warrant the extra cost?
I think it would be nice if this forum had a "Do It Yourself" section like other forums have.
Thanks again
Posted by: New2Import at 10:25 AM 7/3/2009
IoS at http://www.infinitipartsusa.com, has an additional 5% off extended until mid-July. IoS is one of NICO sponsors (I don't work for them)
Below is a procedure for those who want to service their brake. I modified the procedure from FSM for clarification and inclusion of optional steps.
M35/M45 Brake Pads Replacement
Specification (from FSM) and Pricing from IoS:
-Front Rotor: 28mm new/26mm minimum; Maximum Runout=0.035mm ($82.11 from IoS)
-Rear Rotor: 16mm new/14mm minimum; Maximum Runout=0.055mm ($69.20 from IoS)
-Front Brake Pads: 11mm new/2mm minimum ($61.33 from IoS)
-Rear Brake Pads: 8.5mm new/2mm minimum ($58.66 from IoS)
Tools and Materials Required
-Tire wrench, jack and jack stand
-Breaker bar (1/2” drive)
-Ratchet Drive (1/2” or 3/8”)
-Metric sockets (14mm for pin bolts, 21mm for lug nuts; 22mm for torque member bolts if rotor needs removal/replacement)
-Torque wrench (32 ft-lbs for pin bolt, 72-87 ft-lbs for lug nuts)
-C-clamp (for pushing the piston)
-wire sufficient to support the brake cylinder body
-optional steel brush to clean lug nuts and hub bolts
-optional disc brake cleaner
-DOT 3l Brake Fluid (32 oz), container and vinyl tube for optional Bleeding Brake System
-PBC grease or CRC Disc Brake Quiet
-suitable wipes/rugs
Removal and Installation of Brake Pad (from FSM)
REMOVAL
1. Remove tires from vehicle with power tool (or tire wrench or breaker bar with 21mm socket).
2. Remove lower sliding pin bolt (14mm socket).
3. Hang cylinder body with a wire, and remove pads, pad retainers, shims, and shim cover from torque member (Option: clean retainer and shims with brake pad cleaner).
Note: If rotor needs to be removed – First remove both pin bolts and hang cylinder body. Then remove both Torque Member mounting bolts (breaker bar may be required with 22mm socket ) and pull out the torque member. Pull out the rotor (have them turned or replaced)
CAUTION:
Deform pad retainer when removing pad retainer from torque member.
INSTALLATION
1. Apply PBC (Poly Butyl Cuprysil) grease or equivalent (or CRC Disc Brake Quiet) to between shim cover and shim. Install inner shim, inner shim cover to inner pad, and outer shim, outer shim cover to outer pad.
2. Install pad retainers and pads to torque member.
3. Press in piston until pads can be installed (use C-clamp and old brake pad to push piston), and then install cylinder body to torque member.
CAUTION:
In the case of replacing a pad with new one, check a brake fluid level in the reservoir tank because brake fluid returns to master cylinder reservoir tank when pressing piston in.
NOTE:
Use a disc brake piston tool (commercial service tool, or C-clamp) to easily press piston (use the old pad together with the C-clamp to press the piston until it is flush with the piston cylinder).
4. Install upper sliding pin bolt and tighten to the specified torque. Refer to BR-29, "Components".
5. Check rear disc brake for drag.
OPTION: Bleed Brake System in sequence- rear right, front left, rear left and front right. Ensure brake reservoir level does not go below minimum or air will enter the system (spongy brake)
6. Install tires to vehicle (Torque lug nuts to 72-87 ft-lbs. Over-torquing may warp the rotor).
Good luck
Rod
Post Title: Re: (loystock)
Posted by: BigP at 7:55 AM 7/4/2009
Mike
Post Title: Re: (BigP)
Posted by: M45Caliber at 1:07 PM 7/4/2009
These binders are MUCH more linear, have stronger stopping power at all speeds and have firmed up the brake pedal a little bit too.
And virtually zero dust to boot. I had to brake very hard recently (from ~100 down to 65 - don't ask, don't tell, OK) and it was like a Star Fleet tractor beam grabbed the a**-end of my M and locked on. Absolutlely no shuddering and no fade. These brakes actually get a little stronger after they are warmed up a bit. Gave the seatbelt/shoulder harness a good test too.
Search this forum for a few other posts on this topic, but the rotors AND pads for all 4 corners were around $600. My mechanic installed all of this for a flat $180. Once again -- these are not OEM -- these were the FROZEN ROTORS and HAWK pads. Unreal.
I can recommend this set up without hesitation - best brakes I've used to date. Wish I had a set up like this back in my IMSA and SCCA days.
I'd have been out-braking those pesky 930's into turn nine at Riverside and the corkscrew at Laguna.
Posted by: BigHeadDennis at 9:18 AM 7/7/2009
--Dennis
| Quote, originally posted by loystock » |
| Personally, I replace brake pads when thickness falls below 5mm, although minimum acceptable thickness is 2mm. Rotors need not be replaced unless they are cracked, severely warped, thickness is below spec. or upgrade is desired. A warped rotor may be turned for @ $20 each provided the resulting thickness does not fall below spec. Be careful when buying aftermarket brake pads. Some of them are too hard (and nois?) that your stopping distance may be affected. IoS at http://www.infinitipartsusa.com, has an additional 5% off extended until mid-July. IoS is one of NICO sponsors (I don't work for them) Below is a procedure for those who want to service their brake. I modified the procedure from FSM for clarification and inclusion of optional steps. M35/M45 Brake Pads Replacement Tools and Materials Required Good luck Rod |
| Quote, originally posted by New2Import » |
| $900 WOW. I did C/D rotors and ceramic pads for half that myself. Very easy. Just need a C clamp to move pistons in calipers back with the the old pad in it. Some things you just have to do it yourself. Oil and brakes are just one of the few. |
Please do also remember to clean and regrease the caliper pins ... to avoid sticking pins!
Z
Post Title: Re: (BigHeadDennis)
Posted by: szhosain at 12:22 PM 7/7/2009
| Quote, originally posted by BigHeadDennis » |
| Do you have a similar write-up for replacing the rotors? |
The info is in the FSM (link is in my sig - my first post in this thread above). Although, I am sure that real world experience would modify it - similar to what Rod did for the pad change description he posted above.
Z
Posted by: jedgington at 3:06 PM 7/19/2009
I went to IoS website to order OEM replacement front brake pads for my 06 M35X. If you browse their catalog, and click Brakes - Brake components - Front pads, you are presented with one option, the pads you listed for $61.33. However, if you go a different route and click Front Suspension - Brake components - Front pads, you are presented with two options, the pads for 2WD ($61.33) and for AWD ($76.66). Different prices, so I assume different parts.
When looking for aftermarket brake pads at other websites, I've noticed that their front pads are listed as replacements for the base 2WD model, sport model, and the X AWD model.
So, my question is: are OEM replacement brake pads different for 2WD and AWD? If so, what makes the AWD model cost almost 25% more?
Post Title: Re: (jedgington)
Posted by: loystock at 12:58 AM 7/20/2009
| Quote, originally posted by M45Caliber » |
| I now have almost 2000 miles on my new rotors and brakes, and in a word: AWESOME! I had Frozen Rotors and Hawk HPS pads installed on all four corners for the cost of new front rotors and pads via the dealer. I use the dealer for ALL other maintenance, except tires and brakes. These binders are MUCH more linear, have stronger stopping power at all speeds and have firmed up the brake pedal a little bit too. And virtually zero dust to boot. I had to brake very hard recently (from ~100 down to 65 - don't ask, don't tell, OK) and it was like a Star Fleet tractor beam grabbed the a**-end of my M and locked on. Absolutlely no shuddering and no fade. These brakes actually get a little stronger after they are warmed up a bit. Gave the seatbelt/shoulder harness a good test too. Search this forum for a few other posts on this topic, but the rotors AND pads for all 4 corners were around $600. My mechanic installed all of this for a flat $180. Once again -- these are not OEM -- these were the FROZEN ROTORS and HAWK pads. Unreal. I can recommend this set up without hesitation - best brakes I've used to date. Wish I had a set up like this back in my IMSA and SCCA days. I'd have been out-braking those pesky 930's into turn nine at Riverside and the corkscrew at Laguna. |
Just curious, you didnt need to change the brake lines or anything other than the rotors and pads right?
Post Title: Re: (ArbitrageMan)
Posted by: msvara at 10:17 AM 7/21/2009
CHEERS!
Posted by: jedgington at 6:03 PM 7/21/2009
| So I'm not sure what is the difference. |
Well, I called Joe at IoS today to ask the question and to order the front pads. Evidently, the same brakes fit all models. But, there are two part numbers. The first one is 41060-EG090, and is the $61.33 variety. It seems that this part has been superseded by D1060-EG51A, and is $76.66 [prices are IoS prices]. Either will work. Joe wasn't exactly sure about the difference, or why one is $15 more, but suspected it was a change in suppliers or a change in compound. He still has some of the -EG090 in stock, and they are likely the part # originally fitted to my car, and they're cheaper! So, I ordered a set of those.
Thanks to Joe at IoS for helping me out.
Posted by: loystock at 10:37 PM 7/21/2009
| Joe is DA MAN. He's a parts manager now but is still willing to help anytime he's available. When one of his guys messed up with my 2nd to the last order, he apologized and contacted me personally. Nobody is perfect. My latest order just arrived today, as scheduled. |
Most Excellent!
Unfortunately, mistakes do happen. But it is how people rectify mistakes that makes all the difference!
And, this is the reason why we recommend http://www.everythinginfiniti.com for sure. Joe Tsensky has been a long-time NICO sponsor and helps us out.
Z
Post Title: Re: (szhosain)
Posted by: jedgington at 5:18 AM 8/1/2009
Well I replaced the front pads last night. I followed your directions to the letter, along with the pages from the BR section of the manual. It took me about 2 hours to complete. I spent a lot of time cleaning junk from the shims and retainers before regreasing them. I used the CRC brake quiet between the shims and pads.
Although I am mechanically-inclined, I've never worked on my car before. I greatly appreciate your walkthrough. The only thing I'd add to your writeup is the brake burnishing procedure described in the service manual.
Thanks again!
Posted by: M45Caliber at 8:02 AM 8/1/2009
I took the liberty of painting the calipers as well, to clean up the look. If you search this forum there is a post with "before and after" pics, etc.
I may not have that racer-look with slotted and drilled rotors, but I got me some butt-kickin binders that out perform stock by a wide margin and should last about 50 to 75K miles (per their experience).
The Hawk pads are also virtually dustless as well. no residue between washings.
I was sceptical before taking the plunge on this set up but now, after a couple of thousand miles, I couldn't be happier.
Posted by: mizzoulew at 1:02 PM 11/13/2009
Finally, the Infiniti dealership parts people are telling me that they do NOT install ceramic pads, but semi-metallic. I went ahead and purchased the Infiniti pads because the hardware was so different, I thought I should. When comparing the AKEBONO and Infiniti pads, the Infiniti's are thicker, have two, rather than one, heat slots, and, the pad surface is light brown vs, black on the AKEBONO. I read a thread that said there's a "second generation" pad from the original. These Infiniti pads are part no. D1060 - EG51A, corresponding to a newer pad. Could these be better, possibly ceramic?
The Infiniti dealership people say the ceramic pads are harder and will warp the rotors. I've heard just the opposite about metallic and semi-metallic and have installed ceramic pads on my Honda Accord and F-150 - no problems. I thought ceramic pads run cooler and are less abrasive on rotors. Which is right?
< Contact Us - NICO
