Nissan Forums / Infiniti Forums - NICOclub > Sentra Forum / Infiniti G20 Forum / NX Forum > 2002 nissan sentra spec v type r, my car bucks for 3-6 seconds before starts (Printable Version)
Post Title: 2002 nissan sentra spec v type r, my car bucks for 3-6 seconds before starts
Posted by: MhV7 at 3:17 PM 6/24/2009
i was hoping someone could help me diagnose this problem and see what i need to do to fix it. thanks for your time
Post Title: Re: 2002 nissan sentra spec v type r, my car bucks for 3-6 second ... (MhV7)
Posted by: ProudNissanFreak at 4:47 PM 6/24/2009
What do you mean by "bucks." Like it cranks slowly?
If so, check your battery's power, make sure the cables are tight, no corrosion on the cables. If there is corrosion, clean it off using baking soda, toothbrush and water. Make sure it's completely dried before re-connecting.
If it's none of the above, it could possibly be the starter or some part of it.
Post Title:
Posted by: nametakennow at 7:36 PM 6/24/2009
Could be fuel pump, could be battery, depends on what you mean by "buck," like was said above. Does it crank but not turn over?
By the way, it's SE-R Spec V, no "Type R" involved.
Post Title: Re: (nametakennow)
Posted by: ProudNissanFreak at 7:49 PM 6/24/2009
Didn't notice that. You've got your Hondas and Nissans mixed up
Post Title:
Posted by: toothfuzzbass at 9:44 PM 6/29/2009
I have a similar problem. my 04 spec v cranks at normal speed but it doesn't want to turn over for about the same period of time. only happens when it's warm. anyone with any insight?
Post Title: Re: (toothfuzzbass)
Posted by: toothfuzzbass at 9:45 PM 6/29/2009
when I say "when it's warm" I mean when the engine is warm not the outside temp
Post Title:
Posted by: nametakennow at 5:56 PM 6/30/2009
Confirm all recalls were dealt with.
Any other symptoms?
Posted by: toothfuzzbass at 6:47 PM 7/7/2009
no, no other symptoms. car runs great with no noticeable problems after slow start and all other times.
I confirmed all the recalls were dealt with when I bought the car from a nissan dealership in november of 08.
have there been any recalls since then that I don't know about?
I know another person who had an 02 or 03 spec v that had the same issue (don't want to call it a problem bc it's not, more irritating than anything)
Posted by: YF19Alpha at 8:21 AM 7/21/2009
Sounds a lot like what I just posted about. I have an 08 Spec V and it will crank normally, just won't turn over. I stop and try again a few seconds later and it will start. It is quite irritating. It just started happening yesterday. No other issues to that point.
Post Title:
Posted by: nametakennow at 9:11 PM 7/22/2009
Check your spark plugs, if they're old you may not be getting a good spark.
