Is anyone else having this problem? The service dept. checked out everything last week and suggested that there was some "cupping" on the tires that might be the source of the noise. The tires look fine, there is plenty of tread left, but the noise is bothersome both at low and high speeds. Any thoughts or confirming opinions would be appreciated. I have never had Dunlop tires...maybe this is common. I would hate to buy new tires at this point, but may have to in order to return to the quiet ride i expect.I use to own Dunlop and after 28K miles, they sound awful. I went to Michelins and now get 60K miles without any tire noise. Dunlop to me is plane crap. Only my opinion, not to poke fun to anyone.
Post Title: Re: Tire noise (EXcitement)
Posted by: Poyzinous at 8:42 AM 6/23/2009
| Quote, originally posted by EXcitement » |
| My EX is experiencing very loud tire noise after putting about 30,000 miles on my Dunlop tires. |
How have you been rotating them. I would say run your hands over the surface of the tire with an open palm towards the tread. If you feel raised edges on the inside edge of the tires you are starting to develop feather edging. This is a normal byproduct of alignment and is not a design flaw. With frequent cross rotation the wear can be balanced. I would also suggest getting a 4 wheel alignment. Your front toe should be set to between 0.02 and 0.04 each side. This will allow for less chance of featheredging without sacrificing road feel.
This is one of my primary reasons for strongly recommend asymmetrical tread designed tires. Keeping to a strict ~7k rotation schedule will get the most out of your tires.
| Quote, originally posted by RioD007 » |
| You are lucky... mine were toast after 14,000 miles |
You really do drive the hell out of that thing don't you.
Post Title: Re: Tire noise (SteveTheTech)
Posted by: EXcitement at 6:47 AM 7/1/2009
This is one of those instances where a little more proactive maintenance will save you money down the road.
Posted by: gloa2000 at 12:38 PM 7/1/2009
Changing tires are very expensive. If you maintain them well, you will save money. I have set of Falkens on my car and with 60k miles on them i still have plenty of treads left and it still rides like a new car.
Post Title: Re: Tire noise (gloa2000)
Posted by: mapplay at 5:46 AM 7/28/2009
| Quote, originally posted by SteveTheTech » |
Yes I Do And Love Every Second Of It!
But that was with a few IOS track days that really chewed them up and i always run the thing at about 38-40 psi
but my new tires are lasting MUCH better even though they are VERY VERY soft compound tires
perhaps its the fact that there wider I dont know...
Any thoughts?
Post Title: Re: Tire noise (Cobra427)
Posted by: ecosse at 8:32 AM 10/6/2009
So I'm also interested in the best recommendation for replacement tires (for all season use). Is Nokian WR the way to go?
Post Title: Re: Tire noise (ecosse)
Posted by: kullenberg at 9:03 AM 10/6/2009
My EX is experiencing very loud tire noise after putting about 30,000 miles on my Dunlop tires. Is anyone else having this problem? The service dept. checked out everything last week and suggested that there was some "cupping" on the tires that might be the source of the noise. The tires look fine, there is plenty of tread left, but the noise is bothersome both at low and high speeds. Any thoughts or confirming opinions would be appreciated. I have never had Dunlop tires...maybe this is common. I would hate to buy new tires at this point, but may have to in order to return to the quiet ride i expect. |
Solution to your problem, don't go too fast nor too slow.
Posted by: TheWife'sEX at 1:31 PM 10/12/2009
The bad news is that with only 2k miles on them, they're starting to show the same problem that started with the Dunlops at about 14k miles. The problem is not "cupping" or "feathering" - as many service managers and even techs would and have incorrectly called it - but heel and toe wear on the outside tread blocks only. When viewed from the side, there is a sawtooth like shape to the tread blocks, with the leading edge being slightly higher than the trailing edge. It can be felt by running the palm of your hand along the outside circumference. I wonder if that's actually a problem others on this forum are experiencing but mislabeling?
We bought the car with 12k miles on it, and it drove fine (although not 100% sure the tires hadn't already started to wear abnormally - in fact, they may have been relatively new, I never checked the tread depth). Went on a long road trip and about 2k miles in, started to get vibration in the front, mostly passenger side. Got 4-wheel alignment, balance and rotation halfway into the trip, but tires never "corrected" as they said hopefully would happen. Couldn't stand the vibration after a few more months and 10k miles, so bought the new tires (but skipped the alignment, which was likely a mistake).
After replacing the tires (bought at DiscountTire.com, installed at dealer), the ride was vastly improved, but oscillation on braking was more pronounced (just more noticeable since it was isolated?). Next visit led to resurfacing front and rear discs, then replacing front discs, at no charge to me (this is at about 26k) AND another tire balance, which they admitted wasn't done properly the first time. All seemed well.
Another 1k miles or so and we're on a Sunday drive yesterday - had very slight vibration again, but I figured maybe just the road/my head? On the way back, vibration was much more pronounced, so I checked the tires when we got home and noticed the early stages of the heel and toe wear. This went from barely noticeable to pretty annoying in a hurry (less than 60 miles).
Very ticked off, and very concerned that there's more going on than a slight alignment problem. I mean, can very slight heel and toe wear cause such a noticeable vibration, especially after only 2k miles? Besides, can't the car hold an alignment for more than 6 months? I've noticed mention on this forum of a steering rack issue, but the dealer says that has nothing to do with my symptoms. Anyway, it's back to the dealer tomorrow, probably for an alignment, and then I don't know what...
Sorry for the long first post - I'm new to this forum, but have been reading for a while, thanks for all of the useful info over the past year.
Post Title: Re: Tire noise (TheWife'sEX)
Posted by: Punjab at 2:45 PM 10/12/2009
| Quote, originally posted by TheWife’sEX » |
| Speaking of Falkens, we have the 18" wheels, and we replaced the Dunlops about 2 months ago (at about 25k miles) with Falken Ziex ZE912. Looks like they're the only performance tire of the same size, they're about 2/3 the price of the Dunlops, and that model was recently ranked by Consumer Reports as the best high performance all season tire. That's the good news. The bad news is that with only 2k miles on them, they're starting to show the same problem that started with the Dunlops at about 14k miles. The problem is not "cupping" or "feathering" - as many service managers and even techs would and have incorrectly called it - but heel and toe wear on the outside tread blocks only. When viewed from the side, there is a sawtooth like shape to the tread blocks, with the leading edge being slightly higher than the trailing edge. It can be felt by running the palm of your hand along the outside circumference. I wonder if that's actually a problem others on this forum are experiencing but mislabeling? We bought the car with 12k miles on it, and it drove fine (although not 100% sure the tires hadn't already started to wear abnormally - in fact, they may have been relatively new, I never checked the tread depth). Went on a long road trip and about 2k miles in, started to get vibration in the front, mostly passenger side. Got 4-wheel alignment, balance and rotation halfway into the trip, but tires never "corrected" as they said hopefully would happen. Couldn't stand the vibration after a few more months and 10k miles, so bought the new tires (but skipped the alignment, which was likely a mistake). After replacing the tires (bought at DiscountTire.com, installed at dealer), the ride was vastly improved, but oscillation on braking was more pronounced (just more noticeable since it was isolated?). Next visit led to resurfacing front and rear discs, then replacing front discs, at no charge to me (this is at about 26k) AND another tire balance, which they admitted wasn't done properly the first time. All seemed well. Another 1k miles or so and we're on a Sunday drive yesterday - had very slight vibration again, but I figured maybe just the road/my head? On the way back, vibration was much more pronounced, so I checked the tires when we got home and noticed the early stages of the heel and toe wear. This went from barely noticeable to pretty annoying in a hurry (less than 60 miles). Very ticked off, and very concerned that there's more going on than a slight alignment problem. I mean, can very slight heel and toe wear cause such a noticeable vibration, especially after only 2k miles? Besides, can't the car hold an alignment for more than 6 months? I've noticed mention on this forum of a steering rack issue, but the dealer says that has nothing to do with my symptoms. Anyway, it's back to the dealer tomorrow, probably for an alignment, and then I don't know what... Sorry for the long first post - I'm new to this forum, but have been reading for a while, thanks for all of the useful info over the past year. |
the Ziex 912s are a great tire. I had those for a bit before i swapped to Potenza S-02 pole positions on the TL -
however it would seem you expect to not need an alignment for X amount of miles. There is no set period of when you need one. It depends on where and how you drive. I used to drive my TL like a bat out of hell, as a result, i needed new tires almost every 9000 miles and i was changing my oil probably every 3500 not out of habit, but because the engine oil was running that low already ~ 35%.
anyway, you may not drive like i did then, but the environment around you may require that you do an alignment more often than you would like. Also, things like a bent rim (one really bad pot hole can do that) or slightly bent rim will also cause bad heel/toe rash and vibrations.
i think everyone should be doing this on any car they buy, firestone has a one time fee for lifetime alignment on that car. it pays for itself very fast...
anyway, if you can check the quality of your rims, actually make sure that the tires are really all evenly worn or better yet all equally new, tire pressure, and alignment, i am sure you will discover that the noise goes away.
Another very common thing is if youve had a flat and only replaced that one tire, you will get road noise as well...so there are a few factors to all of this.
Posted by: ecosse at 7:11 AM 10/13/2009
[QUOTE=TheWife’sEX]
Posted by: EXceptional at 10:00 PM 10/13/2009
With only 18,000 Km's on them, they sound like Crap.
I'm a Michelin Man too and I guess I'll be buying a new Set sooner, rather than later.
Post Title: Re: Tire noise (EXceptional)
Posted by: EXceptional at 10:11 PM 10/13/2009
When it goes off, it just tells you that "one" of them is low.
Posted by: ramprun at 6:37 AM 10/14/2009
| Quote, originally posted by JCL622 » |
...however it would seem you expect to not need an alignment for X amount of miles. There is no set period of when you need one. It depends on where and how you drive. I used to drive my TL like a bat out of hell, as a result, i needed new tires almost every 9000 miles and i was changing my oil probably every 3500 not out of habit, but because the engine oil was running that low already ~ 35%. anyway, you may not drive like i did then, but the environment around you may require that you do an alignment more often than you would like. Also, things like a bent rim (one really bad pot hole can do that) or slightly bent rim will also cause bad heel/toe rash and vibrations. |
Living in the Northeast, I would agree that I'm more likely to need more frequent alignments than some down South or out West. However it would seem that an alignment should last more than 6 months an 8-9k miles, especially over the summer months (i.e. - April thru Sept). Since I had one in April, and the new tires on in Aug, I figured I'd go through the winter, then get one in the spring. Especially since the car drives/handles fine. I realize a car out of alignment specs can seem to drive OK and have imperceptible impact on the tires, but I find it hard to believe that it could cause so much damage to the two front tires in only 2k miles, and on two occurrences with two different tires (Dunlops and Falkens) in around 25k miles.
While I drive fairly aggressively ('06 S4 Avant and '98 M3 Conv.), this is my wife's car, and I know she's not taking off ramps at 75mph and/or weaving in and out of traffic. I've gone through tires in 25-30k miles before, but never less - and unless we're talking about hard driving on max performance summer tires, I would expect (perhaps naively) most tire sets on a fairly new vehicle with no mechanical issues to last 10's of thousands of miles, not a few thousand.
anyway, if you can check the quality of your rims, actually make sure that the tires are really all evenly worn or better yet all equally new, tire pressure, and alignment, i am sure you will discover that the noise goes away. Another very common thing is if youve had a flat and only replaced that one tire, you will get road noise as well...so there are a few factors to all of this. |
Thanks JCL662, and you were probably speaking to the thread in general, but to be clear in my case, these are 4 new tires, pressure is fine. Not sure how to check the rims (visibly they seem fine) to see if there is a slight bend to them.
I'm bringing the car in tomorrow to see what the dealer says. My limited research on heel and toe wear seems to indicate that it is caused by out of spec caster settings. The caster was within spec on the alignment back in April and was not adjusted - and from my experience, it is the least likely of the three alignment settings to get knocked "out of whack". So...it will be interesting to see what the dealer tries to claim is the cause. I'm considering going to an independent shop for an alignment first, for an unbiased measurement - but that also opens it up to the dealer claiming it wasn't done properly, so I may just have to hope the dealer does the right thing and doesn't "fudge" any readings. I know....
Posted by: TheWife'sEX at 10:05 AM 10/14/2009
| Quote, originally posted by ecosse » |
| This is a perfect description of what I have been experiencing since about 30,000 km. I want to get new tires but I'm concerned that it's a car problem not a tire problem and, like you, will be back in the same situation after spending a bunch of money for nothing. |
Interesting. I suspect we aren't the only two, and some others that have complained about early tire wear are perhaps experiencing the same exact problem, but it just isn't being described the same? I think someone else raised the concern that it might be a suspension geometry issue, which would REALLY stink...
Kind of a stab in the dark here, but other possible design/quality issues could be related to the steering rack (seems to be a known issue, but not tied with tire wear...yet) or I was thinking maybe a problem with the front/rear torque split in the ATTESA system, causing uneven rotation rates at the corners and thus a sort of "pushing" on the tires???
Just curious, have you spoken to the dealer about it? Keep an eye on this post (or maybe I should start a new one titled "Tire Wear"?!?) and I'll let you know what I learn (or don't learn) on my upcoming visit.
Posted by: SteveTheTech at 5:26 PM 10/14/2009
First of all I would like to welcome TheWife'sEx to the group. ![]()
There are a few things that I feel have been brushed over with little attention payed to them. The Caster setting is actually one of the angles most effected by a collision or impact. Think about the inclination of the vertical axis of the front wheels centerline. Most of the force of an impact is dissipated through these components. The problem with caster is there is not only no adjustment there is no way lie about it. The caster measurement procedure may be flawed in the machine but there is no way to screw it up if camber and toe are not completely out of specification.
When I teach a new tech alignment procedures on these cars I always try to show them that these cars will tell you what is wrong right from the tires and their wear patterns. The majority of tire wear noticed on these cars if featheredging caused to excessive total toe and wear caused by incorrect inflation. The spec seems a little on excessive side and even keeping it in the green is not enough. To the untrained eye tire wear can be misread and I have actually watched several service writers misdiagnose problems and just pull things out of the air.
Total toe is more important and the closer to 0(zero) of the thrust angle the less tire wear that will be noted.
Caster is not adjustable not and will never be adjusted. We (Infiniti forum member, moderator) have been dealing with this for years with other models. Several members in the G and M forum have experienced this for a while and there have been several threads calling for all types of action to resolve this. The fact of the matter is these cars were set up to allow for the maximum performance of the AWD system. Whether your car has awd or not the suspension is not different (geometry wise) from rwd models with the exception of shock rate and slight variance in ride height. The camber caster and toe settings in the front are the same and are designed to allow for seemless torgue split with no Acura esque torque steer.
The tires will never wear from the awd system it just does not work in such a way that that is a viable option for the wear. If there were enough of a problem with the awd system you would know about it well before the tires had a chance to wear.
The roads in Massachusetts suck and many of them are going to make noise. I notice this in my own car as well as my wife's when we head up to that area. Increased tire lead and noise are noticed more in this type of vehicle. The German cars are not as prone to this but in skimming some of their forums tire issues are not at all uncommon. This is not a design flaw and will not be changed by the company as any significant alteration to the suspension will have a significant ripple effect.
The best thing for an EX that is not being put through the paces on a daily basis is a good set of Tier 1 asymetrical tires like a Goodyear, Michellin, or Bridgestone. Kumhos are not going to work well on this car no matter what when they start to break in
they will get noisy.
What is the toe setting on your most recent alignment sheet?
Posted by: TheWife'sEX at 2:06 PM 10/15/2009
Post Title: Tire Noise...
Posted by: EXceptional at 8:04 PM 10/15/2009
By the time we got back Home, the EX35 had the oscillating, rotational Noise.
We drove to Brandon Manitoba and then back to Edmonton on October 12th.
Our Air Canada flight was canceled because of bad Weather at the Winnipeg Airport, so we got our Money back and took the EX35.
The Car was parked, once we got to Brandon. Average speed on the Highway was 120 to 140 KM's.
I will do an "X" Rotation of the Tires this weekend... and see if it cures it.
Posted by: TheWife'sEX at 9:03 PM 10/15/2009
Interesting thread progression indeed - and it's very interesting that you mention a collision as being one of the few causes of caster misalignment. In the interest of full disclosure, I offer this bit of history:
I mentioned that we bought the car with about 12k miles on it (and less than 1 year old). You can never be 100% sure when you buy used, but the car seemed fine when we first checked it out (clean CarFax, although they're nearly useless). Turns out, there was light paint work done, although the selling dealership denied any work had been done (I know, never believe a thing they say).
After a little hand-wringing, we bought the car. During the next week, I took the car to two separate Infiniti dealers, who put the car in the air, checked it from top to bottom, and declared that it was fine and did not appear to have any frame or (major) body work done to it (original VIN tag on all panels). I was under the car both times, and it looked OK to me.
Using some very neurotic research skills, I was able to determine that the car was driven by a Nissan exec in MI before being sold through auction to the Infiniti dealer we bought it from. It turns out it was almost certainly THE auto show (and likely road test?) car that you see in all of the pictures of the EX35 display at the US auto shows (rare Scarlet Silver/Chestnut w/all options). A celebrity I guess?!?! Pretty sure this [http://blogs.motortrend.com/6221234/car-news/infiniti-prices-its-2008-ex35-base-models-start-at-32015/index.html] is the car in my driveway....not happy about that, but at least now I know what happens to all those cars I see at the shows and in the magazines I read every month...
But I couldn't stop there, so I tracked down the Nissan exec (did I mention I could be a bit neurotic?) - and after I calmed down her very agitated husband - I was told that the car was terrific, but she had hit a bird on the highway that took out the mirror and required a new mirror and light paint work. So....I figured not great, but no big deal, that was it. Maybe, maybe not, huh?
All that given...I still think it's unlikely some previous collision is the cause of my tire woes.
Glad to hear that it is not likely/impossible that the AWD system is the culprit.
To answer your alignment reading question, the alignment done 6 months ago wasn't very severe. And interestingly, now that I'm looking at it VERY closely....it's a little disconcerting that the heading at the top says Infiniti: FX35 : 4X2: 2003-08. I seriously hope the FX and EX specs are the same....
Anyway, the camber and caster, front and rear, were fine "before" - so not adjusted. Toe front and rear were both in the red, although not outside the range, so they were adjusted a few minutes and brought back to the center of the range. Fronts were set to +0.05 left and +0.06 right, rears were set to +0.10 left and +0.11 right. Seems like the alignment wasn't (still isn't??) the problem....
Dealer couldn't take the car today, so it'll go in early next week.
Posted by: mapplay at 6:52 AM 10/19/2009
As regards Michelin tires, I have them on my 08 EX, AWD, with 24k miles. They were OEM, and I have noticed no unusual wear, however I'm going to have to replace them before I go back east in Feb. They have slowly become noisier over time, which is to be expected. After some research, I've narrowed in on the Goodyear Triple Tread, which is very similar to the Nokian WR, which I would favor, but can't find. Tire Rack rates them very highly, in all conditions of driving.
Post Title: Re: Tire noise (kullenberg)
Posted by: SteveTheTech at 5:25 PM 10/20/2009
Long term noise levels are going be the best with the Primacies. Before your post I did not know that cell phone companies made tires.
Although I only recently learned of Vredstien tires so apparently I am behind the curve. Having the ability to cross rotate the tires is really important with these cars especially with the awd models.
I really have to be honest with you guys. Now that EXs are starting to get some miles we are all learning how the tires are going to wear. One definite PRO to the Dunlops is that if you run your open palm over the tread from front to back and feel some resistance you can mount the front tires on the opposite sides rear wheels to curb any longterm wear. I have been doing this with many of the M owners I work with for a while and it really helps noise and tread wear over the life of the tire.
To TheWifesEX-
Impressive borderline creepy level of dedication to finding the original owner. It sounds like you have a decent rarely abused EX. The interior color is very unique and I personally think I could grow to really love it on a day to day basis. Looks like you made the right choice.
Posted by: ecosse at 5:28 PM 10/20/2009
| Quote, originally posted by kullenberg » |
| After some research, I've narrowed in on the Goodyear Triple Tread, which is very similar to the Nokian WR, which I would favor, but can't find. Tire Rack rates them very highly, in all conditions of driving. |
Any concern that TripleTred is 97H vs 97V on the Dunlops?
Also, I note that the TripleTreds are 'directional' tires (front to back rotation only, not what Steve the Tech has recommended above).
Like you, I'm trying to narrow in on the best "all conditions" replacement.
Posted by: kullenberg at 7:27 PM 10/20/2009
| ...which is very similar to the Nokian WR, which I would favor, but can't find... . |
Little off topic, but...
http://www.tiresbyweb.com/m-10...99999
https://www.tiresavings.com/nokian.php
http://www.best-price.com/prod...ivVyQ
etc...
Post Title: Re: Tire noise (mapplay)
Posted by: ecosse at 12:54 PM 10/22/2009
| Quote, originally posted by mapplay » |
| I am looking at Michelin Primacy MXV4 for my next set. They only come in 60R vs 55R. Are these ok to use.....Any comments on michelins????? Thanks. |
I got a recommendation today to go with the Primacy. Looking at the Michelin website, it seems there is a 225 55 R18 in the MXV4
< Contact Us - NICO
