Been a while since i had to diag issues on a car with a distributor. Has a misfire under load, much more noticeable in higher gears/lower rpm. My first thoughts are related to the plug/cap/rotor... im gonna take a look at it this weekend and make sure.
Just makin sure there shouldnt be something specific to be lookin for with the SR20 suffering from a misfire.
Post Title: Re: '93 n2k, potentialy mine (Liquid_Neon)
Posted by: pachuco at 1:24 PM 6/6/2009
but it could be a fuel injector crapping out. If it was missing at idle you could unplug one injector at time to see which one is causing it.
You may want to check the Ignition Timing. If it is advanced then it needs high octane or will lean misfire. Base should be 15 degrees. When I first bought my b13 SER it was advanced to 18. Luckily I put 93 octane in it when i bought it .
Post Title: Re: '93 n2k, potentialy mine (pachuco)
Posted by: unijabnx2000 at 1:09 AM 6/9/2009
| Quote, originally posted by pachuco » |
| sounds like a good place to start, plugs wires cap and rotor. but it could be a fuel injector crapping out. If it was missing at idle you could unplug one injector at time to see which one is causing it. You may want to check the Ignition Timing. If it is advanced then it needs high octane or will lean misfire. Base should be 15 degrees. When I first bought my b13 SER it was advanced to 18. Luckily I put 93 octane in it when i bought it . |
she drives it almost every day the way it is too... cant be bothered to fix the friggin misfire. lazy/poor/stuck up/dont care about cars.... i wanna save the car
Posted by: Liquid_Neon at 5:31 AM 6/9/2009
| Quote, originally posted by Liquid_Neon » |
| Quick thing, do the 91-93 n2k's have vlsd like the ser do? |
yes they do. Nx is the ser big brother. NX has much better radiator the ser's and the brakes are much better than ser also.
LOL hell i just bought NX cailbers and rotors for my ser
Post Title: Re: '93 n2k, potentialy mine (dmp316)
Posted by: Liquid_Neon at 8:03 AM 6/10/2009
| Quote, originally posted by dmp316 » |
yes they do. Nx is the ser big brother. NX has much better radiator the ser's and the brakes are much better than ser also. LOL hell i just bought NX cailbers and rotors for my ser |
haha... i have the n2k brakes on my pulsar... so i know what u mean. a nice big brake upgrade.
Posted by: ABNRML4U at 4:08 PM 6/14/2009
< Contact Us - NICO
