Nissan Forums / Infiniti Forums - NICOclub > Pathfinder Forum / QX4 Forum > P 1444 EVAP purge control valve (Printable Version)
Post Title: P 1444 EVAP purge control valve
Posted by: Lars at 1:04 PM 6/1/2009
Hi everybody, I figured I'd share my saga here in hopes of some advice and to possibly help anyone else with a similar problem (yes, I searched the forums and found one post with no solution). So a few weeks ago my SES light comes on. I figure O2 sensor and borrowed a code scanner. The scenner showed P0325 (knock sensor) and P1444 (EVAP purge control valve). After reading up in the FSM, I tested the valve, and found that it was bad (the FSM says you can simply attempt to blow through it with it disconnected, if you can blow through it the valve is bad as it should be closed with no power attached). I replaced the valve - which is fricking expensive. Things were great for a week. Then the SES light comes back on, with the same codes... test the new valve - bad. I suppose that the new valve could have gone bad in a week, but that seems unlikely. I'l be getting another new valve this week, but want to make sure there isn't anything causing the valve to fail.
Does anyone know if there is something (other than a faulty part) that would cause an EVAP Purge valve to fail?
Post Title: Re: P 1444 EVAP purge control valve (Lars)
Posted by: billyd at 6:39 PM 6/27/2009
I may have your answer. Your Evap Canister is bad. The carbon in the canister will clog the valve. Before you replace it blow your line out or it may happen again. I have the same problem and when I took mine in they wanted 480 to fix. I got a question for you where did you get your valve from? Thanks
Post Title: Re: P 1444 EVAP purge control valve (billyd)
Posted by: Lars at 10:25 AM 6/29/2009
Yes, you are right! Sorry for the late update. I got Nissan to warranty the first bad valve. I didn't install the replacement because I had a hunch that there was something else going on. When the orig one went bad I tested it by blowing through it, and remembered some little black pieces coming out of it. Pieces of charcoal from the canister. Right now I can't afford a new canister, so I threw a fuel filter inline before the purge control valve, and sure enough a few days later there are pieces of charcoal in the filter. Once I can afford a new charcoal canister, I'll buy one.
One of my friends does parts for a local body shop, he ordered it for me.
Posted by: billyd at 4:16 PM 6/29/2009
Lars, I just ordered a canister and valve from Sunrise Nissan dismantlers in Rancho Cordova Ca for 130. You should check them out.
http://www.sunrisenissan.net.... I spoke with Jason and he hooked me up.. Good Luck
Posted by: W O T at 4:26 PM 6/29/2009
What exactly is the purpose of that valve and canister? Is it for emissions of the crankcase?
Posted by: Lars at 11:15 AM 7/2/2009
Billyd - not a bad price. I paid close to $200 for a new valve alone. I'll give them a ring about the canister.
WOT - these are emissions components - but for the fuel system, not the crankcase. Basically, the canister scrubs the fuel vapor from the fuel tank and feeds it back up to the intake for the engine. When the valve goes bad, it allows the fuel vapor to feed into the engine without any control - basically, it affects idle, but not much else - the valve gets stuck open, it is normally closed.
