I bought this car about three years ago when I started as a Mechanic at Nissan. I hate to sell this car but times are hard. Its time to let it go this car has been my pride and joy. It was built by myself and two other factory trained Nissan Master Mechanics. It is a great car but it does have a few flaws because its a work in progress and I never had sufficient funds to finish it. I bought the car bone stock. It was a base model 1996 240sx with 90K miles It had power windows manual lock and four lug hubs No A/C and etc.
I purchased the motor swap(front clip including all parts to make it right hand drive with A/C) from Jarco near Atlanta Georgia a very reputable motor swap importer the mileage on swap and vehicle were extremely close. This swap was completed professionally by two of my coworkers and I at Bill Gatton Nissan in Bristol,TN. Everything was done Correctly Nothing was rigged on the vehicle. I also purchased a S14 Silvia Rear Suspension Cradle with a Viscous differential, front and rear 5lug hub swap and R33 front fixed caliper brake upgrade from Jarco.
I will now list all the parts I have added as upgrades:
18" staggered G35 coupe wheels
Tein coilovers
Battery relocated to trunk with Optima gel battery
Walbro 255 fuel pump
2 Guage pod with procomp boost guage and procomp EGT guage
Greddy Turbo timer
Greddy electronic profec spec II boost controller
NGK Wide Band O2 sensor with digital display
Sony CD Player and diamond audio speakers
Nismo shift knob
New shift boot
Front Mount Intercooler
Nismo Iridium Spark plugs
Samco radiator hose
Blitz air cleaner
Blitz BOV
Nismo Fuel pressure regulator
Exedy Stage 2 clutch
Cat delete oversized Downpipe with wide band bung
HKS high power exhaust
Nismo engine and trans mounts
Nismo radiator cap
Turbo gasket
Exhaust manifold gasket
poly tension rod bushings
Nissan OEM kouki front fenders,headlamps,corner lamps,hood,headlamp brackets,washer squirters,OEM nissan JDM kouki front bumper,JDM nissan OEM Blinkers,and Nissan OEM Bumper Bracket. JDM Nissan OEM Silvia emblems Front Rear and Ks Emblems.
OEM Nissan Rear windshield molding (not installed yet)
Like I stated before I have all the parts off of the clip to make this car Rhd with A/C I will be included with the car along with all the parts depending on what the bid reaches
I have the reciept and boxes for most if not all the parts.
I'm sure I missed some things too. The wiring was done in such a way that it can be disconnected and reconnected without any problems (correctly).Now I will try to honestly state the cars flaws and problems. The rear windshield moulding is damaged but I have the new part. The Kouki Front end was Installed because my buddies daughter backed into the car in the driver way and damaged the hood and bumper.(It was a low speed collision but I wanted to change it anyway) I painted the parts so they were sanded and primed but the hood ended up getting some spots on it cause i didnt have a booth. the rear bumper the pain is peeling some. so it really could use some paint in spots. The driver side rear fender has a 6in scratch/dent above the wheel it is not a really bad spot on the car just cosmetic.Its also has various small scratches and dents here and there nothing abnormal. This was done prior to me owning the car. The transmission has a slight leak at the driveline output shaft seal also the trans has some wear on the 4th gear synchronizer it will grind slightly at the 3rd to 4th shift and 5th to 4th at higher RPM like on the Interstate. This doesn't render the car undriveable but it needs to be fixed at some point. All these things are very minor but I just want to address all the problems.
This car is extremely fast drives straight and handles awesome. I estimate it to be somewhere between 250 to 315hp depending on boost. The boost has never exceeded 12 to 14psi and was typically kept at 10psi. Since I have owned the engine the oil has been changed every 2000miles with Mobile 1 fully synthetic 5w 30 the gear oils were changed at this time as well. All fluids in car are Genuine Nissan fluids except for the Mobile 1. I have over $12,000 Dollars invested in this vehicle Including parts and labor.
I am listing this vehicle at my bottom dollar dont make offers this is as low as I am going if it dont sell at this price I am just gonna trade it off
$7500 FIRM
I really want this car to reach a home where it will be finished and maintained.
NON-negotiable on the price!
Modified by NOAH041283 at 8:19 PM 6/23/2009
Post Title: Re: TN: 1996 240sx s14 Sr20det kouki Front lots of mods (NOAH041283)
Posted by: richiev8s13 at 3:53 PM 5/5/2009
http://cgi.ebay.com/ebaymotors...%3AIT
Post Title: Re: TN: 1996 240sx s14 Sr20det kouki Front lots of mods (aquabob89)
Posted by: NOAH041283 at 12:26 PM 6/2/2009
bump
Post Title: Re: (NOAH041283)
Posted by: nos487 at 1:16 PM 6/23/2009
| Quote, originally posted by joker350gt » |
| can you send pics to joselopez402@gmail.com |
SEE PICS HERE
Posted by: NOAH041283 at 7:58 AM 7/7/2009
< Contact Us - NICO
