If you have pictures of cars with tint that have not been posted already please post so I can get some ideas of what different percents look like. Thank you in advance.
Modified by aft981 at 8:26 PM 3/19/2009
Post Title: Re: Window tint removal (aft981)
Posted by: Punjab at 9:02 PM 3/19/2009
Its looks at home on the beach, it looks at home almost anywhere.
Post Title: Re: Window tint removal (Punjab)
Posted by: AWGD8 at 7:18 PM 3/20/2009
Post Title: Re: Window tint removal (Patrick K)
Posted by: Patrick K at 4:18 PM 3/22/2009
IMG][IMG][
/IMG][IMG
][/IMG][IMG][
/IMG][IMG][/I
MG][IMG][/IM
G][IMG][/IMG
]I had so many occasion where I stop in a 4 stop sign intersection and a
cop stop too, and waited for me to turn. I bet if he couldn`t see me inside
he would pull me over. Here in WI, they only allowed 50% front. I also
travel to Illinois where front tinting is illegal. So far 35% tint is acceptable.
I guess bec. it seems stock looking bec. front and back matches and most
oem tint at the rear is 35%.
Posted by: dividedhighw at 8:20 PM 3/23/2009
| Quote, originally posted by Patrick K » |
| If you lease thru Infiniti and tint your windows will you have to remove it before you turn the car in at the end of the lease |
| and if you do can you remove it from the rear window with out damage to the rear defrost? |
Cheers,
David
Post Title: Re: Window tint removal (dividedhighw)
Posted by: RioD007 at 11:30 PM 3/26/2009
Its all 3M so it comes off easy but I'm changing my front sides to 5%, and do my rear sides and Hatch to Double 5% and should only cost me a few Hundred And look Black.
Witch reminds me i still need to get a sheet of Huper Optik 20% on the sunroof to jam some of the 120° arizona heat
Next step is to Smoke the Head and Tail lights
Post Title: Re: Window tint removal (RioD007)
Posted by: M45Caliber at 11:31 PM 4/3/2009
Do you seriously have 20% tint on your windshield? I can't believe the Snottsdale po po's haven't gotten you yet.
I have a firend that does professional tinting, and he tints his work truck windshield (35%) and still gets pulled over 3 or 4 times a year with a fix-it ticket.
Why don't you just get the windows painted black
and avoid all the hassles of installing that film?
Posted by: M45Caliber at 11:39 PM 4/3/2009
Finally don't do this unless it's going to cost you big time if you don't remove it. Tinting typically RAISES that value of a car so they shouldn't make you pull it unless it's really damaged.
Post Title: Re: Window tint removal (M45Caliber)
Posted by: RioD007 at 11:50 PM 4/3/2009
| Quote, originally posted by M45Caliber » |
| Oh, and as for removing that tint, should you be forced to do so -- do this on a bright sunny day - preferably a hot day too -- NOT winter in Chgo, for instance.... cut out a heavy duty BLACK Hefty trash bag to the approximate size of the window. Lay a towel down underneath to catch to catch the drips, etc. NOW liberally spray the film on the window with water, then immediately stick the cut out bag over the water and lightly press in place, covering the entire inside of the window with the water and the bag. Park in the sun so that window gets the full on sun. In a few hours the film should just peel right off (basically it's like steaming wall paper off). Use something like "Goo Gone" to remove any residual adhesives left on the glass. Or if there's no wires or elements, just windex and a single edge razorblade works great! Finally don't do this unless it's going to cost you big time if you don't remove it. Tinting typically RAISES that value of a car so they shouldn't make you pull it unless it's really damaged. |
Yes my Front Glass is at 20% and now i just changed my front sides to 5% and my rear's to double 5%
So now its as dark as i like it
Most of my buddy's have my same combo of tint that i do an none of us have been pulled over in years... but thats just me.
Posted by: Moe35 at 3:49 AM 6/28/2009
< Contact Us - NICO
