Nissan Forums / Infiniti Forums - NICOclub > Maxima Forum & I30 / I35 Forum > 97 i30 timing belt (Printable Version)
Post Title: 97 i30 timing belt
Posted by: festoooor at 7:51 AM 10/7/2008
Hello,
I have a 1997 i30 with 130,000 miles on it and i was told i should have gotten a timing belt at 105,000. Has anyone had any problems or recommendations for me?
Post Title: Re: 97 i30 timing belt (festoooor)
Posted by: Presscott707 at 9:27 AM 10/7/2008
95 and above maxima and I30 do not have timming belts they are timing chain.
Post Title: Re: 97 i30 timing belt (Presscott707)
Posted by: festoooor at 12:40 PM 10/7/2008
so do i still need to get it changed or am i golden?
Posted by: allensteiner at 1:32 PM 10/7/2008
you're good. they don't need to be replaced until they break - and i haven't heard of one breaking yet
Post Title: Re: 97 i30 timing belt (allensteiner)
Posted by: festoooor at 6:03 AM 10/8/2008
i was told by someone if it breaks that my rods will throw and my engine is shot though and I def dont want that to happen
Posted by: allensteiner at 7:00 AM 10/8/2008
the timing chain is designed for the life of the engine. your "someone" is wrong - no offense. if the timing chain breaks the engine will turn off because the ignition timing will stop working.
Posted by: MinisterofDOOM at 7:21 AM 10/8/2008
It might be designed to last the life of the engine, but if it does break it'll be catastrophic. The VQ is an interference engine, which means valves and pistons overlap, so if timing gets too offset you'll end up with bent valves or worse.
However, the chain will only break if something goes wrong. It was designed never to need to be replaced.
Post Title: Re: 97 i30 timing belt (MinisterofDOOM)
Posted by: allensteiner at 7:35 AM 10/8/2008
Quote, originally posted by MinisterofDOOM »
However, the CHAIN will only break if something goes wrong. It was designed never to need to be replaced.
finxed idk if it'll get that far though. without the chain turning the cams it should stall out almost right away. shouldn't it? i'm guessing because i haven't seen a thread on any max forum about a timing chain breaking so it's hard to say for sure.
Posted by: MinisterofDOOM at 7:42 AM 10/8/2008
Cams might stall out, pistons will keep moving for at least one of a number of reasons. Valves will be lifted somewhere, and that's where it will go bad. Believe me, it's bad. Tons and tons and tons of engines are the same way and there are lots and lots of stories out there about people loosing engines to belt or chain failure.
Posted by: festoooor at 8:28 AM 10/8/2008
no offense taken at all... so in other words i have nothing to worry about unless my something is really jacked up... i also read that its recommended to replace chain at 105,000... I am goin to attempt to get photos of my car up soon...
Posted by: Presscott707 at 9:43 AM 10/8/2008
im at 140k and i havnt replaced mine and it doesnt make any noises of anything.
Posted by: MinisterofDOOM at 1:21 PM 10/8/2008
I wouldn't even bother with it at 105k. Even later Nissan BELTS were good for almost that long. Chain should be good for over 300k miles unless something goes wrong. 105k is pretty much nothing to these motors. Tons of life left.
Posted by: festoooor at 1:28 PM 10/8/2008
that is quite a relief to hear... thanks alot
Posted by: diehard96 at 8:29 AM 6/7/2009
Hey man don't worry ,I have 242,000 on my 96 I-30 and have had no problems.I guess as long as you don't drive it like you stole it it'll last a lifetime.
Posted by: NutriaforBreakfast at 10:06 AM 6/8/2009
The best thing you can do for your car is to let it warm up after it
is started, ESPECIALLY during cold weather.
My car is pretty noisy on start up but once the oil starts working
in the parts on the upper engine (valves etc) it runs fine.
Posted by: themainman2029 at 3:51 PM 7/3/2009
As long as you don't drive the crap out of it and its been taken care of, you're fine. If it's had some major mechanical problems in the engine you might check into it.
Post Title: Re: 97 i30 timing belt (themainman2029)
Posted by: Super Mario at 7:04 PM 10/6/2009
My '97 I30 is over 300,000 miles. Stop worrying.
