Headgaskets
KiMbRoZz
Car: 1997 Q45 Silver on Black
Who makes a bada$$ headgasket for turbo motor build?
i heard fel-pro, but who else?
480sx
Car: 1996 Pearl White 240sx
Under 500 HP, felpro is the only way to go. Over 500 HP go with either a Cometic or a custom copper HG.
WDRacing
I'd use a copper for everything if given the option. They are available without being a custom order....just google it.
neverlift
really wd, I have heard a mix on the copper gaskets. I know my exhaust gasket blows.
480sx
I freaken love my copper exhaust gasket, it seals my warped *** manifold great. Whats your problem with yours?
duncan351
Car: S14 KA-T
Fel Pro Paper HG and paper exhaust gaskets. No problems whatsoever.
neverlift
480sx wrote:I freaken love my copper exhaust gasket, it seals my warped *** manifold great. Whats your problem with yours?
IDK it leaks , or has, on a header and the t2 manifold I use to rock. it seems fine on the ssac t3 manifold... (sorry those are from my son... his fav)
anywho, felpro has done me alright(I overheat but thats from not getting the head done after 8blown pistons) I need to get on that
KiMbRoZz
I heard fel-pro is a good safety net for blown motors. instead of, let's say a detonation occurs, first to blow would be the headgasket instead of your internal motor components, driving up cost for your repair. Paper headgaskets. Copper seems like it would be too strong for what I'm doing. Blasting off towards turbo!!!!!!!
480sx
Trust me, people blow motors with non metal headgaskets all the time.
I dont really buy into that normal headgasket acting as a motor 'fuse' thing.
KiMbRoZz
who makes a good headgasket for my type of application? Ka24det pointing towards 350hp.
lrb_2000
Car: '91 Nissan KA-T hatch
Felpro ftw.. it's like $40 and proven over 500whp.
KiMbRoZz
nice!!I can't wait to go boost!
Hey, BTW I just bought a KA24DE Block and Head for 100 bucks. I believe s13 block w/ s14 head. Should i get it checked and tested for cracks or deformation? The seller told me it overheated.
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
yyyyyeeeessssssss
DevilMB3017
lrb_2000 wrote:Felpro ftw.. it's like $40 and proven over 500whp.
QFT. In experience, the Cometic MLS thing is too much trouble. Then again, I'm too lazy to take my head off again to reseat it...
lrb_2000
I have an s13 block, with a s14 head.. I had to change the upper timing chain cover, and I think that's it.. but if it's together already, you're good to go.. get the head resurfaced, and the block decked just for reassurance.. it only cost me $40 to do the head, and about the same for the block.
KiMbRoZz
lrb_2000 wrote:I have an s13 block, with a s14 head.. I had to change the upper timing chain cover, and I think that's it.. but if it's together already, you're good to go.. get the head resurfaced, and the block decked just for reassurance.. it only cost me $40 to do the head, and about the same for the block.
is the upper timing chain not the same for the s13/s14 motors?
ka-t 300
He said timing chain cover
neverlift
come on wd whats up with the copper gaskets? bou to get my head shaved and buy a new gasket
KiMbRoZz
ka-t 300 wrote: He said timing chain cover
you mean the valve cover or rocker cover??my first motor...hee
WDRacing
neverlift wrote:come on wd whats up with the copper gaskets? bou to get my head shaved and buy a new gasket
??? Whats your question? Where to get one or why not use Felpro?
neverlift
have you had any leakage around the oil or water passage? I heard they tend to not seal well in that respect. any truth?
Would a copper head gasket be reusable like any other copper gasket?
Lastly, would it seal minor imperfections in the surface like ext gaskets?
I just have a lil leakage into one of my water passages and wonder if a copper gasket would take care of it? not smoking just runs hot sometimes
DevilMB3017
Edited:
I was misinformed. No need to read what I said here.
Modified by DevilMB3017 at 1:31 AM 7/26/2008
WDRacing
If by similar you mean totally different then yes...they are similar.
I have never had any problems wioth copper...ever.
480sx
Pure copper is about a 2 on the harness scale, while steel is more like a 5-6. Thats a huge difference. Copper will seal minor imperfections when its torqued down, steel will not.
Again if your not going for huge power, go with a fel-pro.
DevilMB3017
Whoops.
I fixed my post - don't wnat to confuse to anyone searching.
I need to look into one of these copper deals.
WDRacing
480sx wrote:Pure copper is about a 2 on the harness scale, while steel is more like a 5-6. Thats a huge difference. Copper will seal minor imperfections when its torqued down, steel will not.
The Felpro is definitly a great option and they are cheap...hard to beat cheap and good
neverlift
480sx so yes it is re usable? sorry didnt get a clear y/n on that.
well I dont really plan to make over 300 anytime soon, but one day a rather large set of injectors will fall into my lap and I'll use them. So would it be wise to go ahead and do the copper h/g now? Plus I've been through , this will be three, first time didnt need it but the motor had some bad pistons,same with second, this one isnt sealed right, wonder if its the arps backing ou, my bud's sr just blew a gasket like that?
another question just came to me while typing.. do they have any issue when used on force fed and meth/water injection?
dwvilmb I too have spoken out of mis information
DevilMB3017
No need for me to spread mis-information.
AFAIK, lol, headgaksets like Cometic MLS are resuable, if you are looking for that, but they do require better mating surfaces and more machine work. Just a heads up. I've seen a lot of people post that Fel-Pros are good up to ~400...
neverlift
well I figure out what to do...
off to do a rain dance or something
480sx
Fel-pros, not reusable. Copper is reusable.
Fel-pro held NissanFanatics 30 PSI meth injected Ka together(twice) so, if it can do that i think it will be alright for your build too.
