Help! Installing R32 Steering Wheel on a S14
SKproductionZ
Well i just picked this upfrom what i heard it is a direct swap, but before i start taking things apart i just am curious if there is anything else i should know before i start messing with it. I know the SRS light would be a problem but there is a door jam trick i read aboutbut yeah overallanything i should know before i start?Thanks!!its going in a 98 240sx
superficialfilter
Car: 1997 240sx se
I'm sure it'll fit right on there but the question is whether or not your worried about losing your cruise control and horn. From what I can see it wont work with the 240sx clock spring, not without some modification. Or you might be able to find a clock spring from some other nissan with the connection in the 12 o'clock position. Then theres the matter of mounting the cruise switch.
