timing belt question
General Discussion forum for Versa Owners
kam472
Car: versa
Just out of curiousuty regarding timing....is it belt or chain in our versas? cheers!
pfc369
Car: 2007 Versa sl/ cvt
chain
bigdog
Car: 2007 Nissan Versa S
2007 Nissan Xterra
1982 Dodge truck
if anything it shouldn't need changing till over 100k miles easily
jmaclean
Car: 2008 Nissan Versa SL
bigdog wrote:if anything it shouldn't need changing till over 100k miles easily
If it's a chain, I thought that it never needs changing!? But this raises another question, does the CVT belt have to be changed at some point?(only have 4,000 miles on mine at this point)
biggie
Timing Chains are usually 80-100k miles.
No clue on the CVT stuff.
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
Yes, the CVT innards will eventually need to be replaced. Save a LOT of money, because it's not as easy, neat, and tidy as replacing a timing chain.
Remember... Subaru's first CVT, when they failed, were 9 times out of 10 replaced with a manual transmission because the refit was cheaper than the repair.
IMHungry
Car: 2008 Versa SL H/B cvt, sport, tech (mine)/2007 Versa S H/B, VOP, 4 spd auto (hers)
According to Nissan, cvt has an indefinite lifespan. Fluid should be getting checked starting at 160,000km.
keanucosmo
biggie wrote:Timing Chains are usually 80-100k miles.
Timing Chain replacement is not listed anywhere in Versa maintenance schedule. They are usually a replacement item when a engine overhaul is done, but not a maintenance item.
I've driven cars with timing chains over 200k miles with no problems.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Generally timing chains don't ever need replacing unless something goes wrong or the engine isn't maintained properly. And even when timing components do fail, it's usually other components like guides and not the chain itself that are the problem.
biggie
Yall apparently aren't use to KA 240s then. The chains need replacing on them or your motor will get screwed.
Maybe other motors aren't much of a problem.
my_new_v
Car: 2008 Toyota Tacoma X-Runner
My 93 had the KA and it had over 130k miles on it and the timing chain was never touched and it was my daily driver/track racer
biggie
my_new_v wrote:My 93 had the KA and it had over 130k miles on it and the timing chain was never touched and it was my daily driver/track racer
You were taking a chance though, hardly know anyone who doesn't change the chain on KAs after 100k miles. It is actually recommended service on 240s. Again, apparently the Versa is different.
my_new_v
Maybe Im getting lucky with cars lol. Cause the chain on the 240, the transmission on the V, waiting to see if I get lucky with my truck now lol.
brucek
Car: 2008 Versa
Quote »Generally timing chains don't ever need replacing .[/quote]Exactly correct.
Belts have various schedules from 100K to 160K, but a chain is generally known to last the life of the vehicle. It is not a maintenance item.
brucek
IMHungry
'89-'90 240SX had a problem with timing chain guides if memory serves me. '91 and had the twin cam engine and were fine.
Ever Victorious
'73 AMC Hornet
IMHungry wrote:According to Nissan, cvt has an indefinite lifespan. Fluid should be getting checked starting at 160,000km.
That's what every manufacturer will tell you about every transmission.
my_new_v
IMHungry wrote:'89-'90 240SX had a problem with timing chain guides if memory serves me. '91 and had the twin cam engine and were fine.
True....so maybe it was just the KA24E's with the timing chain problems.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
biggie wrote:Yall apparently aren't use to KA 240s then. The chains need replacing on them or your motor will get screwed.
That's what I was referring to in my above post. It's not the chain itself that's the problem. It's the guides for the chain which fail and can lead to chain failure (either by wearing against the block or jumping from excessive slack). The chain itself would be fine if the supporting hardware didn't fail.
Actually, it wasn't. There were other Nissan engines (especially the VH45DE) that had the same problem.
biggie
MinisterofDOOM wrote:Actually, it wasn't. There were other Nissan engines (especially the VH45DE) that had the same problem.
The top guide breaks on the KADE as well, most just remove them and Nissan stopped putting them on the S14 KAs.
my_new_v
I was referring more to the KA engines. lol What car has the VH45DE?
Ever Victorious
'73 AMC Hornet
I'd guess the Q45, just off the top of my head...
Return to “Versa General Chat”
