http://akliquid.myphotoalbum.c...domes
They have white also. I also put super white LED in the license. Looks nice. I'll tell you the easy install if you want to get the plates, but they are super bright. I got blue cuz my car is blue, but they have all different ones to suit individual's preference. But again. just look for the ones that are Ba9s.
Modified by akliquid at 2:06 AM 5/3/2008
Post Title: Re: LED Lights for the interior lights and licences plates? (akliquid)
Posted by: DaleHeller at 6:32 PM 5/2/2008
Any issues when you went back to have it worked on (e.g. warranty voided, etc?)
Post Title: Re: LED Lights for the interior lights and licences plates? (DaleHeller)
Posted by: akliquid at 1:40 AM 5/3/2008
Have had no issues at the dealership or with warranty work.
Modified by akliquid at 2:08 AM 5/3/2008
Posted by: xxNite at 12:44 PM 5/5/2008
http://cgi.ebay.com/2pcs-501-W...wItem
I was a little worried about fit at first, but had to try them cause they have 5 LEDS pointing in all directions. They fit and they look like this:
http://rides.webshots.com/phot...lwhiE
http://rides.webshots.com/phot...pxcPr
http://rides.webshots.com/phot...QLGDh
definitely worth the $10
Hey AKLIQUID. In your photo album, what did you use to replace the factory H3 fog lights? they look b-e-a-u-t-i-f-u-l! I am assuming you went with an aftermarket H3 HID retrofit kit, right? which one & how much? I neeeeeedz that!
T. I. A.
xxNite
Post Title: Re: LED Lights for the interior lights and licences plates? (xxNite)
Posted by: LaCapitalRue at 4:25 PM 5/5/2008
| Quote, originally posted by akliquid » |
| I got some LED's from AUTOLUMINATION. The interior lights are Ba9s. I actually put a 25 SMT LED plate. Here's a link: http://akliquid.myphotoalbum.c...domes They have white also. I also put super white LED in the license. Looks nice. I'll tell you the easy install if you want to get the plates, but they are super bright. I got blue cuz my car is blue, but they have all different ones to suit individual's preference. But again. just look for the ones that are Ba9s. Modified by akliquid at 2:06 AM 5/3/2008 |
akliquid...could you please send me the link of where you got those...? I've spent close to $50 on trial and error buying the Ba9s bulbs...only one set has worked. I was told there was/is a polarity issue and that's why all of the LEDs I've gotten do not work. Do you have an 08...?
Post Title: Re: LED Lights for the interior lights and licences plates? (Hoshtaylor)
Posted by: akliquid at 10:01 AM 5/6/2008
http://autolumination.com/otherleds.htm
Posted by: Hoshtaylor at 8:44 AM 5/7/2008
Thanks for the info...I just ordered them. I'll let you know what happens after I install.
Posted by: xxNite at 11:19 AM 5/7/2008
Which ones for the '04 M45?
I want to change ALL of the interior lights in the ceiling liner, footwells, and even the trunk with brighter LED's(except the dash gauge cluster)
Posted by: akliquid at 12:17 PM 5/7/2008
I agree the SMT variety are GREAT. anything else is usesless and directional is a must.
what is the light in between the two front two map lights that illuminates down towards the gearshift? it is the one that adds subtle light so you can see near the cupholders, a little?
Posted by: akliquid at 12:35 PM 5/7/2008
http://akliquid.myphotoalbum.c...=ba9s
I couldn't get access to the light in between the maplights. Let me know if you figure it out.
Posted by: Hoshtaylor at 8:19 AM 5/8/2008
| Quote, originally posted by xxNite » |
| I follow you on the fact that they are the BA9s variety, but do you remember if they are screw-ins or did they have two pointy posts? I agree the SMT variety are GREAT. anything else is usesless and directional is a must. what is the light in between the two front two map lights that illuminates down towards the gearshift? it is the one that adds subtle light so you can see near the cupholders, a little? |
They are BA9s bulbs...NOT the screw in bulbs. In other words, they are the ones with the "two pointy posts"
Posted by: Hoshtaylor at 3:11 PM 5/12/2008
Has anyone changed out their map bulbs to LED's on an 08...???
Posted by: topstar79 at 5:56 PM 5/14/2008
| Quote, originally posted by Hoshtaylor » |
| yeah so I just received the bulbs and they don't work. I've only found 1 kind of LED bulb that works in this spot and they are hardly bright at all. I don't understand why none of these BA9s bulbs aren't working. Has anyone changed out their map bulbs to LED's on an 08...??? |
The reason why probably none of the other bulbs you've tried works is because the polarity of the leds are reversed. I've changed out my map lights with these:
http://cgi.ebay.com/ebaymotors...photo
and I just reversed the little white connector between the actual led board and bulb adapter and it worked fine and they are extremely bright.
Hope that helps.
Post Title: Re: LED Lights for the interior lights and licences plates? (topstar79)
Posted by: Hoshtaylor at 9:32 AM 5/16/2008
| Quote, originally posted by topstar79 » |
The reason why probably none of the other bulbs you've tried works is because the polarity of the leds are reversed. I've changed out my map lights with these: http://cgi.ebay.com/ebaymotors...photo Any chance you could describe this a little better or maybe have a pic of what it is I need to do...? and I just reversed the little white connector between the actual led board and bulb adapter and it worked fine and they are extremely bright. Hope that helps. |
| I installed license plate LED bulbs and WOW they look darn good! This is a link to where I got them from: http://cgi.ebay.com/2pcs-501-W...wItem I was a little worried about fit at first, but had to try them cause they have 5 LEDS pointing in all directions. They fit and they look like this: http://rides.webshots.com/phot...lwhiE http://rides.webshots.com/phot...pxcPr http://rides.webshots.com/phot...QLGDh definitely worth the $10
T. I. A. |
That is too bright.
Post Title: Re: LED Lights for the interior lights and licences plates? (ttsupra26)
Posted by: xxNite at 2:51 PM 5/21/2008
Modified by xxNite at 11:33 AM 8/27/2009
< Contact Us - NICO
