S13 Front Strut / Firewall Brace
A forum for approved vendors of specialized, limited-production parts. Help small businesses that cater to Nissan enthusiasts and score some unique, useful parts! Contact [email protected] for approval and rates.
rotorimp
Car: 02 Xterra, 60 IH Metro
Finally ready!
These front strut / firewall braces were designed and engineered specifically for the purpose of increasing the rigidity of the cowl and front suspension areas on the S13.
Developed for the 240sx Convertible, they are equally effective at reducing front end flexion on the Coupe and Hatch, while allowing full access to the top of your engine. Valve cover removal can be done without removing the FSTB.
In addition, they are situated to transfer and distribute strut tower loads evenly across the firewall and bulkhead, increasing suspension flatness.
Manufactured from thick-walled mild steel tubing, with CNC-cut mounting plates and gusseted welds and joints, you won't find a beefier strut brace on the market. PERIOD.
Finish is a high-quality satin black powdercoat that's been professionally applied to resist chipping, scratching and flaking.
Note: Drilling of the firewall (two holes) is required. Installation is fairly simple and should take less than an hour with normal hand tools.
SAY NO TO CRAPPY EBAY STRUT BRACES!!!!
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Is it necessary to reinforce the firewall at the mounting points?
No. The steel is fairly thick there, and the forces are distributed with the direction of the firewall metal.
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
Freaking SCORE! That looks awesome Jason. This just went to the top of my list for stuff for my 'vert. I'll put one on my hatch too as soon as I get the wiring sorted out.
Loki
Car: 1994 Nissan 240SX Convertible
2010 Toyota FJ Cruiser
2001 Ford F-150 SVT Lightning
You have to drill two holes in the firewall to install this right? I'll have to find a means of doing that before I even think about ordering...
Joe
so uh what engine is going in that 240
i see some heavy mount pod modification on the crossmember
jrivera
Very nice...
DJButton
Car: 2010 Nissan 240sx
Well Jason, you truly are a master fabricator, finally a strut brace that is better then the others and will fit around my RB before I get a front facing IM! Great Work!
homeslicej2
Loki wrote:You have to drill two holes in the firewall to install this right? I'll have to find a means of doing that before I even think about ordering...
Would you have to remove the dash to drill your holes and not hit stuff? I like it btw and will have to get after I finish the brake upgrade.
Silvia_Drift
Car: 1989 Nissan 240sx Coupe
Hey man, I want one. How much shipped to Toronto Canada?
And I am also concerned about drilling the firewall. Do the brake and clutch line need to be relocated? And does it come with the hardware to mount the bar to the firewall?
Modified by Silvia_Drift at 9:29 PM 8/8/2007
digzsublime
Car: 95 S14 w/ LS1.
Very nice, I will be ordering one of these soon. I've got an RB and it looks like it should clear.
It's unny though. I was just talking to the guys in our abrication shop, like a week ago, about making one very similar to this. Guess there is no need to use up my favors when I can just buy one. Thanks.
Just out of curiousity, how thick is "thick walled mild steel tubing" ?
Hijacker
Car: '92 240sx Convertible
'94 F-150
in a few weeks, i shall be ordering one myself. thanks jason!
rotorimp
Hello all,
Drilling the two holes in the fire wall is very easy--you do have to remove the plastic just above it to get to the back side. They can be installed in about 20 min. just because you have to put it on-mark the holes and drill them. Nothing else has to be removed or changed. We did notice with some aftermarket suspension. that you have to lower one of the struts to get it on--just because they are made to very tight tolerances and I didn't want to mess up any threads on the struts. these bars also come very close to the hood. If your all stock you will be fine but some of the carbon fiber hoods come down closer and you might have to put some washers on the hinge. The wall thickness on the tubes is .095" and currently it is up to the buyer for the hardware to attach it to the firewall. Any other questions please post them.
Jonnie Fraz
Nice work Jason. I saw it when you posted up on welding web. On there you mention that there is no interfearance with top mount turbos, is that still the case?
rotorimp
YES Sir--That was the main reason for builbing them. Seems like there are endless strut bars that go across the motor but none that are able to clear the big turbo's, LS1's ect...
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
I just saw these in person this week and they look great! Now I need to get on the template for S14!
-Dan
rotorimp
As of today we have 6 Left.
datsun2401972
Car: 90 Nissan 240SX XE coupe
How much do they weigh compared to the competition?
They're significantly heavier than those sissy ebay bars, I'm guessing 5-6 lbs..
FWIW, I can flex a Cusco bar with my hands, and I'm not a real strong guy.
This thing is beefy.
Fenvy
Car: 2005 350Z Base 6MT
will it clear s13 sr20det with 3 nismo mounts?
my cusco barely clears
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
this is definitely a fine piece of work. i gotta get me one.
rotorimp
We made them VERY strong--they actually weigh 10lbs. You can NOT twist them by hand. If you look at the pictures they run very close to the fire wall as not to get in the way of any engine combo.
homeslicej2
Do you plan on making more of these (and possibly one for the rear?). I want one, but I have other things to do first.
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
Why doesn't it use all 3 bolts on the strut tower?
datsun2401972
Hopefully you'll have 1 left after the 15(payday).
And please do make a matching rear STB
Looks like the holes would be difficult to drill with the engine in?
ishkabibble wrote:Why doesn't it use all 3 bolts on the strut tower?
Because it's rigid, making it near impossible to install without dropping your struts... Don't want people to damage the threads on the strut studs!
Fenvy
that makes sense, I was wondering the same thing
rotorimp
There was no real advantage to the third bolt. The two bolts properly torqued down are sufficient--plus it gives our bar a unique look.
And Yes as long as there is a demand we will produce them. In fact Dan has me convinced to do a s14 run.
ishkabibble
1997 Infiniti I30t
AZhitman wrote:Because it's rigid
I see. Thanks, Greg, didn't think of installation.
datsun2401972
paypal sent!
Now make a rear one, lol!
Preferably one that ties into the strut towers and the bottom of the trunk!
....please?
Return to “Fabricators' Market”
