Nissan Forums / Infiniti Forums - NICOclub > Nissan Online Mechanic > 1989-1994 240sx: AIV PAIR valve removal tutorial (Printable Version)
Post Title: 1989-1994 240sx: AIV PAIR valve removal tutorial
Posted by: vancouverbc at 12:31 AM 5/31/2007
Originally Posted by vancouverbc
Tutorial Index
Overview: The AIV is basically useless .(see important qualifier*). You have two choices: Remove it entirely or simply disconnect one hose. People remove it to free up space. KEEP ALL PARTS as you will need for emission inspections and when you sell car.
*(In british columbia, the aiv will help you pass the idle test. In california it is closed loop during idle so you may not need it for idle test. keep for visual inspection)
WHY AIV(PAIR valve) IS A PROBLEM:
If reed valves become gunked up in the AIV unit, exhaust gas and condensation will be allowed to flow into the intake.(ie air box where air filter is). This can cause your cars idle to bob or drop below what it’s supposed to, also can cause slight stumble during acceleration. Deposits from exhaust can coat MAF and cause ECU to read the wrong amount of intake air flowing past it.
Only the older s13 hatchback model 240sx’s will have this unit, Nissan realized it was almost pointless and caused problems as it aged, so they discontinued it in the s14 and s15 lineup.
The entire assembly is on the right hand side of the engine (looking from front of car), it’s comprised of hoses, a black plastic resonator, the metal AIV unit, solenoid unit, and black bracket which bolts everything to the car.
EASIEST SOLUTION: Simply disconnect rubber hose that goes from AIV unit to air box. This hose takes air from air filter box and delivers it to AIV unit. Exhaust can not get into air intake system once this hose is disconnected.
The AIV unit is now getting unfiltered air which should not be a problem.
The following picture shows the hose disconnected(with a white filter added):
Difficulty: 2
Time: 1 - 2 hrs
Tools
What you will need:
1. Ratchet with small and large extenders for the ratchet pieces
2. 10mm ratchet piece, you can try to use US sizes, but be careful not to strip the bolts
3. Philips-head screw driver
4. Flat-head screw driver
5. Rubber caps to plug up the hoses. Should get every size in one pack.
(reuse clamp to hold cap on metal exhaust pipe. no, it wont melt)
Special plug for elitests
Removal instructions:
First you need to unbolt the black bracket holding everything to the car. It’s attached with 3 bolts, 2 above the AIV, and 1 below. The extenders will come in handy here, other wise you have to use one of those single piece wrenches, or a small ratchet.
When the bracket is off, loosen the hose clamps for the tubes going to and from the resonator (2 hoses, 4 clamps). Push the bracket forward to gain easy access to the bolts holding it on. Unbolt the resonator (2 bolts), and pull it off from the hoses and set hoses aside.
To remove the AIV unit, first unbolt it (3 bolts), then pull off the small vacuum line connected to the top. Pull hard to pop it off, it shouldn’t rip on you, it’s a tuff little hose. Next, Nissan decided to use a metal clamp type of holder on the hose under the AIV, why? To piss you off. You will need to twist the AIV upside down or sideways to be able to remove the clip. Stick the flat head screw driver in-between the part of the clip where it sticks up and twist, pull, and push to loosen it. At this point you can remove it or just slide it down the hose.
Your last adversary is the solenoid, which is held on by one last bolt. Show those hoses no mercy as you pry them off. Wiggle the electrical connector back and forth while pulling to disconnect it.
At this point you have 2 roads to take. You can clean the AIV and then put everything back together or plug up everything and leave the AIV off,
To clean the AIV, take off the screws holding its two halves together (be careful, they are easy to strip!). Take apart the reed assembly, carefully taking note how it’s put together, and polish/clean them using steel wool and carb-cleaner/gas. If they are deformed you can bend them back slightly yourself, or buy new ones
If you wish to leave the AIV out you need to plug up every opening left. You can ghetto-rig it like I did, or you can do it clean and proper with some sort of stopper for the openings. Either way you will have to improvise with materials around your garage, or you will have to take a trip to the hardware store to find stuff.
Here’s a pic of the Atmospheric and Vacuum lines that went to the solenoid, I used some little screws to plug the line up, then I tied it down to the evap-line, which travels from the gas tank to the carbon canister in the engine bay.
Hopefully your lines have little colored bands on them, which will help you when reconnecting them to the solenoid. Make note of this before you disconnect them however, mine were faded almost to the point where you couldn’t tell what color they were. If there’s no bands or they are badly faded, make a mark with something so you know where it hooks back up!!!!
-Red plugs into the bottom of the solenoid (vertical)
-Blue plugs into the top of the solenoid (vertical)
-When reconnecting the AIV its hose will have no color, it plugs into the side of the solenoid (horizontal)
the exhaust hose; you can plug it up with a bolt or some other stopper. I reused some of the clamps to make sure it wasn’t going to budge. Don’t worry about it shooting out of the hose, there is very little pressure in the exhaust, just make sure none of that exhaust is being vented into the engine compartment, okay?
The clean way to do this is to weld up the opening where the metal tube connects to the down pipe. I did not have a welder or a bolt that would fit the opening :
THEORY:
Pulsed Secondary Air Injection (PAIR) Valve
The PAIR valve sends secondary air to the exhaust manifold, using a vacuum created by exhaust pulsation in the exhaust manifold. When the exhaust pressure is below atmospheric pressure, secondary air is sent to the exhaust manifold. When the exhaust pressure is above atmospheric pressure, the reed valves prevent secondary air from being sent back to the air cleaner.
The valve also works in tandem with a solenoid valve which controls whether it’s on or off:
Pulsed Secondary Air Injection (PAIRC) Solenoid Valve
The PAIRC –solenoid valve cuts the intake manifold vacuum signal for PAIR valve control. It responds to the ON/OFF signal from the ECU/ECM. When the solenoid is off, the vacuum signal from the intake manifold is cut. When the ECU/ECM sends an ON signal, the coil pulls the plunger downward and feeds the vacuum signal to the PAIR control valve.
Links
http://forums.nicoclub.com/zerothread/326891
http://forums.nicoclub.com/zerothread?id=124117
Pictures
Middle is the 4 reed valves. this faces down.
Top of reed valves is shown here. Rotten.
Modified by vancouverbc at 3:33 AM 9/9/2009
Modified by vancouverbc at 2:23 PM 9/22/2009
Post Title: Re: 1989-1994 240sx: AIV PAIR valve removal tutorial (vancouverbc)
Posted by: stutterr at 11:36 PM 1/29/2009
hey man
I just did a ton of work to my car. Now it shakes at idle. It pulls pretty good, just that it shakes the car a little when it idles. I have to go and look tomorrow to see if my car still has AIV. Am I able to clean the unit if its there?
I am assuming this is the root of the problem. I tried disconnecting the MAF and the car dies. I just did fuel filter, fuel pump, new wires, oil change, transmission fluid change, rear diff flush, brake fluid flush.
Any idea?
Btw. I have a 1990 240sx. I am on a permit right now. My car was sitting for a while, so I ran some Motul Fuel Cleaner and filled her with 94. I've burned through half a tank and it still is rough at idle. The idle is at 800.
Post Title: Re: 1989-1994 240sx: AIV PAIR valve removal tutorial (stutterr)
Posted by: vancouverbc at 11:57 PM 1/29/2009
Quote, originally posted by stutterr »
hey man
Any idea?
cleaning aiv wont help your idle. just disconnect the hose that goes to air box.
Posted by: stutterr at 11:59 PM 1/29/2009
My car already has a cone intake. The MAF is plugged in, but there is a sensor that is hanging. I think it measures the air temperature.
Any idea why its shaking at idle?
It pulls nice and hard, but it shakes a little at idle.
Posted by: SirSilvia at 10:40 AM 3/30/2009
can I just take that stuff out and shove it in a box in case I need it if I ever move to a place that has emissions?
Tired of dealing with the EGR crap.
Post Title: Re: 1989-1994 240sx: AIV PAIR valve removal tutorial (SirSilvia)
Posted by: mick at 12:18 PM 4/8/2009
Must the AIV be in the compartment for California smog?
Post Title: Re: 1989-1994 240sx: AIV PAIR valve removal tutorial (mick)
Posted by: jznsx at 8:26 PM 5/4/2009
Quote, originally posted by mick »
I doubt it since the later models didnt even come with it
Posted by: Slide_Society at 10:17 PM 5/7/2009
Quote, originally posted by vancouverbc »
I went to a hardware store with a spare hacked up collector (down)pipe and found out that the pipe is a 15/16" thread. I couldn't find the proper bolt so I went to the plumbing section and picked up a 15/16" short end connector and a screw cap for the other end. Going to remove the AIV and RTV the threads on the threads and plug it up in a day or two.
Post Title: Re: 1989-1994 240sx: AIV PAIR valve removal tutorial (jznsx)
Posted by: mick at 10:14 PM 5/17/2009
Quote, originally posted by jznsx »
It came with the S13 models.
It makes the engine run richer during warmup.
The ECU expects it.
I cleaned mine out and reinstalled it.
Modified by mick at 4:41 PM 9/3/2009
Posted by: mick at 2:43 AM 6/18/2009
Spray it glossy black-It looks better
Modified by mick at 4:42 PM 9/3/2009
