Nissan Forums / Infiniti Forums - NICOclub > M-Series Forum / Fuga Forum > 06 m45 sport rattle under acceleration! (Printable Version) Click here to print this topic.
Post Title: 06 m45 sport rattle under acceleration! Posted by:crza81 at 8:07 PM 1/10/2007 Ok i am new to the forum and have a question to see if anyoone else is experiencing this issue. from a stop i hear a metallic rattle noise between 2-3 k rpms and it is intermittent! very frustrating. sounds like it coming from the front pass. side......if anyone has this problem or knows a fix!!!!!
Post Title: Re: 06 m45 sport rattle under acceleration! (crza81) Posted by:szhosain at 10:30 PM 1/10/2007
Quote, originally posted by crza81 »
Welcome to NICO!
I hope someone chimes in about this, because I have no clue! Is it inside the car or in the engine compartment? Does it happen when the car is stopped and you rev it? Or do you have to be moving to get it? Has this been going on since you got the car, or is it a recent thing?
Total SWAGs: something loose rattling around in the glove compartment? Are your front right lug nuts on tight? Everything tight in the engine compartment?
Z
Post Title: Re: 06 m45 sport rattle under acceleration! (crza81) Posted by:runis at 8:50 AM 6/17/2008
I have the same issue. Rattle is definitely in the engine compartment...between 2-3k RPM...goes away after that. Does not do it in neutral. Anyone?
Post Title: Re: 06 m45 sport rattle under acceleration! (runis) Posted by:CakeDaddy at 11:00 AM 6/17/2008 heat shield or worst case.. motor mounts. I suggest jacking the car up and locating the heat shield and wiggle it with your hand (use gloves) and/or start the car while on jack to see if the sound if more evident while the car is jacked.
I had a similar issue with my previous car (ack Legend) and I used a wedge between the heat shield and never heard it again.
good luck my man
Post Title: Re: 06 m45 sport rattle under acceleration! Posted by:mym45sport at 11:09 AM 11/21/2008
I finally got the dealer tech to replicated this on my M45 and he tested another m45 that had the same rattle/buzz. The dealership said they contacted Infiniti who said it was a known problem, #927866. I have document and the dealer said when Infiniti has a fix , they will repair mine. It's so annoying....
Post Title: Re: 06 m45 sport rattle under acceleration Posted by:mym45sport at 11:16 AM 11/21/2008 Dealer actually changed out the Y pipe, however the rattle was still there. That's when they contacted Infiniti.
Post Title: Re: 06 m45 sport rattle under acceleration! (crza81) Posted by:maxnix at 6:07 PM 11/21/2008 I presume you are im;ying under acceleration. If it sounds like a can of marbles being shaken, then you are probably not using a Tier 1 Premium fuel.
If you are, better hook it up to an ODB II reader and check ECU and accesory functioning.
Post Title: Re: 06 m45 sport rattle under acceleration! (crza81) Posted by:ArbitrageMan at 9:22 PM 11/21/2008
Finally someone else has posted about this. I have the exact same issue on my car. I just got the car a month ago, so I havent taken it in yet for service. It has 29,000 miles on it.
Ive narrowed it down to occurring during light to medium acceleration, between about 2300 and 2900 RPM. My guess is something in the exhaust system, because it seems to be a certain note that the exhaust hits that causes the noise. But it could be cat converter heat shield i guess.
I agree about it coming from the pass side. Its totally noticeable, and very annoying.
Post Title: Re: 06 m45 sport rattle under acceleration! (mym45sport) Posted by:OhioAlex at 1:31 PM 2/23/2009
Do you have the dealers name and reps name who opened this case with Infiniti? I am having the same issue with my 06 M45 and have had it to the dealer 3 times to no avail. Did you ever get it fixed? Any help you can provide me with will be helpful to myself and my dealer. Thanks!
Post Title: Re: 06 m45 sport rattle under acceleration! (OhioAlex) Posted by:MRider at 12:23 AM 3/9/2009 I think I had a similar situation, it sounded either like a knock and ping noise (like when you don't have high octane gas) or like a loose chain on bicycle rattling coming from under the front carriage. If this sound like my case, you might want to have them check the brake cable line...may need to be tighten.
Post Title: Re: 06 m45 sport rattle under acceleration! (MRider) Posted by:ArbitrageMan at 5:39 AM 3/9/2009 Im taking mine in this morning for the issue. I hope the figure it out because its really loud when you have the windows open...and its getting nice out.
Post Title: Re: 06 m45 sport rattle under acceleration! (ArbitrageMan) Posted by:M4T5 at 8:52 AM 3/9/2009 mym45sport did say Infiniti acknowledges this issue and was stated to reference this: The dealership said they contacted Infiniti who said it was a known problem, #927866.
Anyone with this problem should reference this problem number to their particular dealership. That should help with avoiding the shrubbing of the tech and service managers shoulders..........
J
Post Title: Re: 06 m45 sport rattle under acceleration! (M4T5) Posted by:ArbitrageMan at 1:40 PM 3/9/2009
My service managed called this afternoon and said they'd found a loose heat shield and replaced it. I was pleased, but on my way home I realized the problem had not been fixed. Its exactly the same as before.
Also, I asked them not to wash the car and when I picked it up they had. I got home and took a look at the car in the sun. Hello, swirl marks, all over the car.
Post Title: Re: 06 m45 sport rattle under acceleration! (ArbitrageMan) Posted by:OhioAlex at 9:01 AM 3/19/2009
I had my car back at the dealer still with the same problem. I referenced that number and they said that pertains to the exhaust hitting the oxygen sensor but that that was not my problem. They said they placed a wedge in between the 2 and it was still happening. They are as perplexed as me and after 3 days of trying to fix, have given up. Now I'm very annoyed that this expensive car rattles like a Hyundai. If anyone else has success, let me know. I am still convinced that it's a bad catalytic but they won't replace it unless they are more convinced that is the problem.
Post Title: Re: 06 m45 sport rattle under acceleration! (OhioAlex) Posted by:ArbitrageMan at 9:11 AM 3/19/2009 Does anyone remember, and this was like 15 years ago, a car called the Chevy Lumina? They had a sport version of it and the exhaust sound was very unique. It was a reverberating...repeating...tremble...
I think thats very very similar to the sound this rattle makes on my car, except this is slightly more metalic.
Post Title: Re: 06 m45 sport rattle under acceleration! (ArbitrageMan) Posted by:jeostang at 7:45 AM 4/17/2009
My car is at the dealer right now for this issue. The rattle is from a heat shield and there is a service bulletin about it. They said they have to order parts to get it fixed.
My issue now is I paid 2000 for an elite warranty and they say that's not covered. Granted its only 280 bucks, but I just wondering what else will not be covered. I think I'm going to ask for my money back on this warranty.
Post Title: Re: 06 m45 sport rattle under acceleration! (jeostang) Posted by:ArbitrageMan at 9:34 AM 4/17/2009
Something mechanically went wrong with the car and they wont fix it under the warranty? What was their reason? Did they say the part had just worn out...or it was damaged by a rock...something like that?
Post Title: Re: 06 m45 sport rattle under acceleration! (ArbitrageMan) Posted by:jeostang at 11:05 AM 4/17/2009 I think its just the dealer not wanting to do the work. Consumer affairs called back and asked me to pay for it and they will reimburse me. So I guess I'm happy.
Post Title: Re: 06 m45 sport rattle under acceleration! (crza81) Posted by:leftlane1 at 11:54 AM 4/17/2009 I also had the exact same "coins in a tin can" sound upon acceleration, between 2k-3k rpm. I pushed very hard with the dealership, who went with the same "heat shield" fix. That is not the problem - I promise. The real problem is microfractures in the Y-pipe that cause the rattling under strain. The design issue is that the exhaust pipes hang too low and you can have an impact and not even know it, thus leading to a crack. After going around and around, and literally being embarassed to drive my car due to this noise, I finally printed reams of examples of similar problems I found online, and gave the pages to the tech. After they stopped considering me a loony, they actually talked to Infiniti tech help and discovered the problem. They had a tech get under the car, powerbraked the engine into the right rev range, and found the cracks.
After many visits with the heat shield repairs that did nothing, or the "cleaning of rocks" from under the car (I liked that one), the fix was finally for real.
Insist that your dealer examine the y-pipe and the attached exhaust tubes to see if there is a crack. I'd bet the farm that's what is causing your problem. Don't settle for these lame attempts to get rid of you as quickly as possible - you paid good $$$ for a luxury car that shouldn't sound like a jalopy every time you pull away from a stop sign.
Post Title: Re: 06 m45 sport rattle under acceleration! (leftlane1) Posted by:OhioAlex at 11:02 AM 4/20/2009
Who was your dealer and do you have a specific contact there who may be able to help my dealer out? Any help would be appreciated as I am now at 50K and warranty running out at 60. Thanks.
Post Title: Re: 06 m45 sport rattle under acceleration! (leftlane1) Posted by:mpgmusic at 9:45 PM 6/24/2009 Could you tell us who the dealer was that made this repair for you? I am also in the Dallas area and ahve the exact same issue.
Thx
Post Title: Posted by:Zamba at 10:02 PM 6/24/2009
I think I have the same sound in my M35X, but I never was able to figure it out before reading this thread. Thanks
Edit: I went to the dealership to have this issue fixed and they did the heat shield first. I drove it immediately afterwards and the sound was gone so, at least in this instance, the sound was coming from the heat shield.
Modified by Zamba at 10:06 AM 7/17/2009
Post Title: Re: (Zamba) Posted by:Mazeska at 6:20 AM 6/25/2009
Interesting, I have the full Megan exhausts, mid pipes, and cat back. I did not have this problem when it was stock but now I have this exact problem. It sounds to me to be the heat shield around the mufflers, but I may be wrong. Please keep us up to date.
Post Title: Re: 06 m45 sport rattle under acceleration! (mpgmusic) Posted by:leftlane1 at 2:59 PM 6/29/2009 Sorry for the delay - I don't check on here very often. I had the work done at Grubbs Infiniti, after unsuccessful attempts at Sewell. The service manager there is Hoot Lankford, and he's great to work with. In fairness to him, he didn't get involved during the first go-round. I continued to press them (and actually refused to take my car back until it was fixed for certain). It was absolutely caused by microfractures in the Y pipe. Once they replaced that pipe, the problem went away. Initially they said it was due to an impact and wouldn't b covered under warranty, but I raised enough of a stink about this problem and the design that they in fact did cover it.
Post Title: Re: 06 m45 sport rattle under acceleration! (leftlane1) Posted by:OhioAlex at 3:57 PM 6/29/2009 I called Hoot and he said he would need your name in order to pull up the work order to see how it was diagnosed. He said due to the volume of cars that come through there, he did not specifically remember that issue. Would you be willing to provide your name so I can have him look that up? Or if you would be more comfortable emailing me directly, I can be reached at atorres@oris-corp.com. Thanks for any help you can provide!
Post Title: Re: 06 m45 sport rattle under acceleration! (OhioAlex) Posted by:leftlane1 at 3:18 PM 6/30/2009 I'll do ya one better - here are my service record work order #s:
My name is Todd Ermenio, and my customer # at Grubbs is ERME01.
1st attempt at Grubbs was 5/19/08 - work order #65109. The service advisor was Duane Hacking (no longer there). This was the "loose heat shield/rocks in heat shield" non-fix.
2nd attempt was at Grubbs on 6/16/08 - work order #66628. Service advisor was the same guy. This time I insisted on them keeping it until they found the fix. They finally replaced these parts:
The tech explained to me that they found small fractures in the Y pipe while power-braking. It was definitely the metallic rattling from 2k-3k rpms you describe. This absolutely solved that problem once and for all (fingers crossed forever). I would have traded the car in at a huge loss if I had to deal with that noise any longer.
Hoot helped me recently with a suspension popping issue that I battled for over a year also, and when he got involved, the job got done.
Good luck!
Post Title: Re: 06 m45 sport rattle under acceleration! (leftlane1) Posted by:OhioAlex at 5:15 AM 7/2/2009
Thanks for the info - I will try calling them back and may try to get my dealer to call them directly.
Post Title: Re: 06 m45 sport rattle under acceleration! (OhioAlex) Posted by:Q45tech at 2:39 PM 7/4/2009 Heat shield rust and rattles from rocks inside has been a known problem since the 1990 Q45. The fixes are well known and eventually everyone will get some form of repair. In 19.5 years I've had to do mine twice.
Post Title: Re: 06 m45 sport rattle under acceleration! (crza81) Seeking Justice Posted by:leejoseph at 6:20 AM 7/8/2009 Greetings to Everyone, I'm a consumer of an Infiniti product as well. Jan 08, I purchased a brand new 07 Infiniti M35 and for a year I faught them on the rattling, pinging, rocks in acan issue. Finally it took for the reginal manager to come down after filing two complaints with the inter-circle program. It took both of us to go into the garage and actually have the tech take the "heat Shield" off and to our dimise, we found that the small piece of material inside of it was deteriorated. He made them order a new one and the issue went away. Outside of that; the middle seat popped when someone raised it because the latch was broken, my wood moding on the driver side came a loose, the passenger mirror controller went out and the last straw was a rattling in the passenger door they could not fix.
Now; the new general manger tried ease my pain by working a deal on an 09 M35 Sport; I have had the car two weeks and again the rattling issue has returned. I have had intermitted issue with the passenger mirror after putting the car in reverse, and the AC in the seat hardly works..
Now, I'm looking to take legal action against infiniti because WE all should not be paying the money that we are for a vehicle that is suppose to be top of the line. I urge you all to file complaints with the BBB (Better Business Bureau). Also; if you would like to; please contact me because I would line to form an alliance about this. I'm taking my car back to the dealer today and heading to talk with my attorney about this.
Joe Lee leejoseph@earthlink.net
Post Title: Re: 06 m45 sport rattle under acceleration! (mym45sport) Posted by:leejoseph at 9:29 AM 7/13/2009
(URGENT!!!!) Please contact me with that information about this being a problem. I had a new 07 that i purchased in 08 and after working a deal on the 09 sport model, I'm still having the same issue.
Please contact me as soon as possible; with all the details about inifinti noting this issue.
240-447-3895 leejoseph@earthlink.net
Post Title: Re: 06 m45 sport rattle under acceleration! (leftlane1) Posted by:leejoseph at 9:48 AM 7/13/2009
Todd, give me a call, as we need to talk about details. Read the thread below in the forum.
Post Title: Re: 06 m45 sport rattle under acceleration! (leejoseph) Posted by:EcstaSPT at 7:04 AM 7/14/2009
Quote, originally posted by leejoseph »
Hey that's just normal operation!
But on the way to work this morning I did hear the noise I think, passenger side, cruising at 60 or so and heard it with light throttle.
Modified by EcstaSPT at 7:12 AM 7/14/2009
Post Title: Re: 06 m45 sport rattle under acceleration! (EcstaSPT) Posted by:ArbitrageMan at 8:46 AM 7/14/2009
Quote, originally posted by EcstaSPT »
Its difficult to hear at that speed, but its definitely there. I usually here it at 25-40
Post Title: Re: 06 m45 sport rattle under acceleration! (ArbitrageMan) Posted by:EcstaSPT at 9:37 AM 7/14/2009
Quote, originally posted by ArbitrageMan »
Are your windows down when you hear it or does it matter?
Modified by EcstaSPT at 8:04 AM 7/21/2009
Post Title: Re: 06 m45 sport rattle under acceleration! (crza81) Seeking Justice (leejoseph) Posted by:llphilli at 1:27 AM 7/17/2009
Hi All
I have the same rattling on my 06 M35X with 40K, under acceleration I had two dealers check out the problem one said it was bad fuel. When said I use 91 or 94 Octane he then said it' engine ticking and all the infiniti do that. I don't think so. So I went to a different dealer, they said it sounds like a timing problem so they re tuned the car no rattling for one day then it came back. They said to some back if I still have the problem.
THanks
Post Title: Re: 06 m45 sport rattle under acceleration! (llphilli) Posted by:leftlane1 at 7:24 AM 7/17/2009
I guess some folks don't want to read what I posted or to believe what I've said. Oh well...........
Post Title: Re: 06 m45 sport rattle under acceleration! (leftlane1) Posted by:OhioAlex at 8:47 AM 7/17/2009 I think some of these other people are having different rattles and posting on this thread. This m45 rattle is clearly something in the exhaust, not a timing or octane or engine mount or anything else. Only thing is my dealer will not change my Y pipe without knowing for sure that is the cause and they cannot verify. Very frustrating. They said that Y pipe is a thousand dollars....
Post Title: Re: 06 m45 sport rattle under acceleration! (OhioAlex) Posted by:ArbitrageMan at 10:51 AM 7/17/2009
Quote, originally posted by OhioAlex »
Im with you. Lets keep this thread about the exhaust related rattle.
Twice my dealer has been unable to replicate the noise. When I take the tech out in the car, the car wont make the noise. So frustrating. I havent decided what Im going to do. My warranty expires in September, and Im leaning towards NOT getting an extended warranty. I also dont have tons of time to be taking my car to the dealer repeatedly.
Post Title: Re: 06 m45 sport rattle under acceleration! (ArbitrageMan) Posted by:MnM's_M45 at 11:56 AM 7/17/2009
I've got the same issue in my 45. I'm glad I read this cause my dealer was thinking it was a heat shield. I'm going to print this out and take it to them.
Post Title: Re: 06 m45 sport rattle under acceleration! (MnM's_M45) Posted by:cerealguru at 7:12 PM 7/28/2009 I have the same exact problem in my '06 M35X. I took the service manager for a test drive and replicated the sound. He confirmed it was the heat shield, then said it wouldn't be covered under the dealer warranty (my car has 45K) because "it's a northern car and it has corrosion." I am not accepting that answer and will go through consumer affairs or the regional service manager. Is that service bulletin posted before still valid for thie heat shield issue? Clearly, this isn't an isolated issue and I shouldn't go out of pocket on it.
Post Title: Re: 06 m45 sport rattle under acceleration! (mym45sport) Posted by:cerealguru at 7:17 PM 7/28/2009
Quote, originally posted by mym45sport »
SO just to confirm, service bulletin #927866 is specific to the loose heat shields?
Many thanks!
Post Title: Re: 06 m45 sport rattle under acceleration! (cerealguru) Posted by:OhioAlex at 7:48 PM 7/28/2009
After much convincing, my dealer has agreed to change the Y-Pipe on my exhaust. This part has a cost of over $1150, but they were receptive to changing it under warranty after I did the leg work and referenced them to the previous person in Texas who had his changed. I, in fact, called the service manager Hoot and he went over the whole issue with me - could not have been nicer about it - and told me to tell my service manager to give him a call if he would like. It is being done this week, although I am out of town until Friday. I will follow up with another post on whether or not the issue is fixed, but my fingers are crossed.
Post Title: Re: 06 m45 sport rattle under acceleration! (OhioAlex) Posted by:leftlane1 at 8:02 AM 8/7/2009 OhioAlex - did that fix your rattle? Glad to hear Hoot was accomodating - he's a great guy.
Post Title: Re: 06 m45 sport rattle under acceleration! (leftlane1) Posted by:OhioAlex at 8:48 AM 8/7/2009 *********UPDATE********* So I had that work done as mentioned before - new Y pipe and gaskets and have had the car back for a week with NO RATTLE to speak of. Thanks goes out to leftlane1 for the info on the fix. Seems like this issue is finally fixed. I had to lean on my dealer to get the work done, but after repeated insistance, they made the repair.
Post Title: Re: 06 m45 sport rattle under acceleration! (OhioAlex) Posted by:The00Dustin at 8:51 AM 8/7/2009 Does anyone know whether this fix (cracked Y pipe) falls under the standard warranty or the powertrain warranty?
Post Title: Re: 06 m45 sport rattle under acceleration! (The00Dustin) Posted by:OhioAlex at 8:59 AM 8/7/2009 I am not positive but my dealer wanted to do it before I got to 60K in case there was any pushback from Infiniti - you would have to check with the dealer though.
Post Title: Re: 06 m45 sport rattle under acceleration! (OhioAlex) Posted by:The00Dustin at 12:28 PM 8/7/2009 Sounds like your dealer isn't sure. We'll wait and see if anyone else knows. I'm not to 60K yet, but tI don't think I have the noise either. Problem is, while I don't know what causes the noise, my M45 is from Texas, here in Indiana, I wouldn't be surprised if it starts making the noise after one winter, but then I'll probably be over 60k, so that'll be kinda weak if it isn't covered.
Post Title: Re: 06 m45 sport rattle under acceleration! (The00Dustin) Posted by:gigatt at 11:24 AM 9/10/2009 That noise is coming from rocks in the catalyst converters, to remove them you have to take apart the heat shield from the cats ...which doesnt seem right, so my dealer ordered mine today, talk to your Service people about getting the cats replaced - Good Luck.
Post Title: Re: 06 m45 sport rattle under acceleration! (gigatt) Posted by:leftlane1 at 2:59 PM 9/11/2009 Don't be surprised when that doesn't solve your problem. Rocks can't get into the catalytic converters - they get under the heat shield (or so the dealer will try to convince you). This is not the problem - your rattle will return as soon as you drive away.
Post Title: Re: 06 m45 sport rattle under acceleration! (leftlane1) Posted by:ArbitrageMan at 5:00 PM 9/11/2009 Thats correct.
The rattle this thread is referring to is caused by micro fractures in the y-pipe
Post Title: Re: Do you have the dealership name or number where you had your work done. Posted by:leejoseph at 9:35 AM 9/25/2009
My issue as well, I need to make sure this will hold true as for the bulletin number.
Jan 08, I purchased a brand new 07 Infiniti (M35x) and for over a year I fought with the Infiniti services team to address a “rattling, pinging, rocks in a can” issue coming from the exhaust system beneath the front of the car. Finally it took the regional manager to come down after filing two complaints with the inter-circle consumer affairs department. From that point; it took both of us to go into the garage and actually have the tech take the "heat Shield" off and to our demise. We found that the small piece of material inside of it was deteriorated. He (Roger Gettler) made them order a new heat shield which corrected the issue. Outside of that; I had additional issues from the “middle headrest latch being broke, the wood molding on the driver side came a loose on the door, the controller in the passenger side mirror went out and the last straw was a rattling in the passenger door they could not fix and needed to replace the whole panel.
Now; the new and current general manger for Charles Barker Infiniti tried to ease my pain recently by working a deal on a 09 (M35 Sport). I have owned this car roughly two weeks and again the rattling issue has returned. I have had an intermitted issue with the passenger mirror when putting the car in reverse and the AC in the seat hardly works in this car.
Upon giving Charles Barker an attempt to resolve the issue on July 8th; I'm not only disappointed, but very dissatisfied because from one perspective I'm being told it's just how the engine sound on the cars and is normal, yet it doesn't happen on every car. From another perspective; it was identified by tech as a rattle or pinging sound, but yet they cannot duplicate it on other models or fix the issue. Additionally; the rude comments from the technician should not be tolerated by the company. Every time the technician named "Lance" has to ride with a customer to identify an issue. He is very rude and disgruntle toward customers. In fact; when explaining the issue; Lance makes rude comments "that if I want him to tell them that I would like something change out, then that's what he would tell them". He is the technician and though he here's the issue; when speaking with the service manager he then tells a slight different story or regurgitate it differently.
I'm now looking to take legal action against Infiniti because "WE" as customer should NOT have to drive a $60 thousand dollar car with a rattling sound on acceleration. I no longer want the vehicle and looking to return it and/or take whatever measures necessary to square this matter away. This same sound has been experienced by many customers across the US; they either end up going back and forth with the tech teams. Or have had the issue identified and resolved the issue in one of several different ways such as; wedging something between the shield and exhaust pipe. This is supposed to be a top of the line vehicle that should not be experiencing such issue.
Post Title: Re: Do you have the dealership name or number where you ... (leejoseph) Posted by:zags at 8:49 PM 9/25/2009
Just recently started hearing this rattle/coins in a can noise myself. My 06 M35 has 48k miles now.
Time to get it into the dealer...does anyone know when this sound is most prevalent and easiest to replicate? Just in case I have to replicate it myself for the techs.
Post Title: Re: Do you have the dealership name or number where you ... (zags) Posted by:zags at 8:50 PM 9/25/2009
And to clarify is the TSB #927866 for the heat shield or Y pipe? Both?
Post Title: Re: Do you have the dealership name or number where you ... (zags) Posted by:OhioAlex at 6:20 AM 9/26/2009 TSR is for the heat shield, but that is not the problem IMO. My rattle started at around 38K miles, and took nearly 20K to get fixed with about 4 trips to the dealer in that span. The easiest way to hear the rattle is at around 2500-3000 RPM with the car moving. I was unable to replicate the noise in neutral or powerbraking (as some other have). Dealer said the load on the exhaust while moving influenced that. Good luck gettting it fixed - it is very annoying but once it's gone, you'll be happy you chased it down.
