Nissan Forums / Infiniti Forums - NICOclub > Maxima Forum & I30 / I35 Forum > What to expect from aftermarket springs and struts (Printable Version)
Post Title: What to expect from aftermarket springs and struts
Posted by: Beancooker at 7:28 PM 1/6/2007
This thread is for the FAQ page. If you have aftermarket springs and struts, and want to add your comments feel free. Please list your year make/model and what springs and struts you are using.
2001 Nissan Maxima SE
Eibach Prokit Springs
Tokico Illumina Struts
Astetics: My car was lowered about an an inch and a half in the front and one inch in the rear. It removed almost all the wheelwell gap. It gives the car a really nice stance
Performance: Most noticable is less body roll. The springs are very stiff, and you will notice a lot more of the bumps in the road. They made an incredible difference in cornering. They also feel nothing like the stock springs and give it a sportscar stiffness. The Illumina struts are adjustable, and give the option of a softer or stiffer ride. Tis is a great option, for long drives it is nice to have a softer ride, and around town I like to keep them stiff. They are really easy to adjust, and all four can be adjusted in less than five minutes with a small flat blade screwdriver. Simply pop the hood and trunk and turn the dial on top of each strut!
Overall: I am really happy with this upgrade. It handles like a different car, and is much more fun to drive. Pleasant and sporty on long drives and very sporty around town.
Post Title: Re: What to expect from aftermarket springs (beancooker)
Posted by: LA02MAX at 7:38 PM 1/6/2007
2002 SE 6-speed
Tein H-techs with adjustable Tokico Illumina struts
Astetics: Much less wheel gap, more 'menacing' stance and more carlike. (no 4x4 for me!)
Performance: The first thing I noticed was that the floatiness was gone. Going over large bumps, the car instantly regained control rather than bobbing up and down a couple times. Also, it felt like the weight shifted a lot less in braking and accelerating, due to the stiffer struts. And, of course, body roll was greatly reduced which increased cornering capabilities keeping all 4 wheels firmly planted on the ground and allowing less weight transfer from side to side.
Overall: Definitely up there with the best purchases I've made for my car. This paired with the LTB and RSB make the max handle VERY well even at the limit. If I could go back and do it again, I probably would have waited to get coilovers, though.
Post Title: Re: What to expect from aftermarket springs and struts (beancooker)
Posted by: totaljett at 12:58 AM 1/7/2008
Could someone tell me is it possible to place non adjustable struts on my Q45t because I am willing to lose the adjustable feature. I only use the sport mode anyway so I just want a firm ride from any quality strut. Even if there is a generic replacement for the OEM I am all ears. I'm seriously trying to avoid OEM prices.
Post Title: Re: What to expect from aftermarket springs and struts (totaljett)
Posted by: MinisterofDOOM at 2:29 AM 1/7/2008
Probably get a better response in the Q45 forum.
Post Title: Re: What to expect from aftermarket springs and struts (MinisterofDOOM)
Posted by: totaljett at 8:38 AM 1/7/2008
Pro
Quote, originally posted by MinisterofDOOM »
Yeah you probably right. I gave it a shot here also because of the aftermarket reference.
Posted by: Sentientbydesign at 9:19 AM 1/7/2008
1996 I30
Eibach Pro Kit
Tokico Illumina (Front)
Tokico HPs (Rear)
Aesthetics
Greatly improved wheel gap and made the I30 look less like a Camry (I hated people asking me if my car was a Camry). The lowering springs coupled with +2" rims made for a very sexy/strong look. The "settled" in height dropped the car closer to 2".
Performance Before installing the suspension, the car would bob a lot. Taking dips too fast resulted in a dented oil pan and scraped front bumper. Taking fast corner was just suicide.
The suspension was completed in a 2 stage process. First Eibach springs and the Tokico HPs in the rear (with OEM up front), then when the fronts started bobbing around too much, I went for the Illuminas.
Cornering abilities were amazing. Nose dive (braking) was nearly eiminated. The overall feeling of the body and suspension working together is great.
Overall I love the suspension, but I think the Illuminas are a little overkill for me. Turning them up to "5" allows little to no spring compression and can be extremely unpleasant. I do occasionally go under "3" for long distance comfort, but I find myself wanting the stiffness back when weaving through ignorant Cali traffic.
That being said, I probably could have stuck with HPs all around and saved myself $250 (The HPs are as stiff as "3" on the Illuminas).
Check http://forums.nicoclub.com/zer...91141 for a brand new pair of rear 4th gen Tokico HPs
Posted by: MinisterofDOOM at 4:53 PM 1/7/2008
Quote, originally posted by totaljett »
Ah, I figured you just accidentally clicked the wrong forum. Happens occasionally.
The Q's are all pretty specialized beasts. So what applies to the Max doesn't necessarily apply to them. Especially not to Q's with any sort of adjustable suspension.
Good news is our Q guys know their stuff, so they'll definitely be able to help you out.
Posted by: totaljett at 5:13 PM 1/7/2008
Thanks for the tip and excuse the interruption. As you were gentlemen
Post Title: Re: What to expect from aftermarket springs (LA02MAX)
Posted by: 02SEmaxima at 12:04 PM 1/12/2008
Where did you get the third brake light in clear? Do you think they have them smoked?
Post Title: Re: What to expect from aftermarket springs and struts (Beancooker)
Posted by: reknab at 11:04 AM 7/19/2008
Need new new front struts .... stat!
Maxima 2001 Anniversary , 5 Speed. Can some one enlighten myself and all who follow what after market struts might be a good choice to replace the ones that are totally shot on baby. I have 89k miles. They are not the adjustable type. Would I want new springs? And why? The lower profile could be cool but I'm not trying to impress anyone.
I was not expecting them to go so soon. I have an 86 maxima with 225k miles and the front 3 way adjustable shocks are still working fine? The back ones are due but still drivable. I can't really drive the 2001 now.
I'm in the San Francisco area. A good mechanic to install such items would be handy to know, if this is proper to ask.
Thanks good stuff and cheers.
Post Title: Re: What to expect from aftermarket springs and struts (reknab)
Posted by: reknab at 9:24 PM 8/4/2008
2001 Maxima Anniversary, 5 speed. 90K
I sprung for an Eibach Pro kit and the koni struts and koni shocks in the rear. It was that or what the Nissan dealer had for more money.
Whoa! The first corner I hit on I-280 was like "butter". The handling and cornering with the lower center of gravity and stiff suspension was quite nice. The struts are adjustable and I don't even know where it is set but hitting little imperfections in the road or a surface change definitely rattles the ride more than before. But it is a great improvement.
Posted by: reknab at 9:36 PM 8/4/2008
Any one put the Eibach pro spacers on a Maxima?
Posted by: Nissan6Maxima at 6:25 PM 9/20/2008
HELP FROM ANYONE APPRECIATED!!!
I purchased a 4th gen. maxima SE which was lowered about an inch or more both front and rear. During any type of driving it is very un-pleasant. The suspension on it now is either a cheap set of struts/shocks or another problem. I recently had the struts replaced from advanced. I didnt order any thing like a tein set or anything like that and I think thats what my problem is. It has a set of 18" with low profile tires. Basically I need any advice on why every crack in the road or bump or mishape will send my front and rear suspension slamming into the car and provide no shock absorption. Should i just replace the shocks? but I think i was told the shocks wouldnt do much replacing to solve the problem, it had to be a whole new strut/shock set up.
Any advice from anyone??
Post Title: Re: What to expect from aftermarket springs and struts (Nissan6Maxima)
Posted by: allensteiner at 6:33 PM 9/20/2008
here's 2 pieces of advice:
1) don't revive old posts to ask a somewhat related question - start your own thread.
2) my guess is that your setup is either missing or has untrimmed bump stops - in one case the suspension won't travel enough for cusioning, in the other it will bottom out tearing up the whole axle thing.
sell the 18's and get 15 or 16" rims + tires with a tall sidewal for comfort. what kind of shock have you got now? to upgrade get kyb agx or better yet tokico illumina - both adjustable from hard to soft.
