Nissan Forums / Infiniti Forums - NICOclub > Q45 Forum / Cima Forum > need advice 95 Q45 162k, gas smell (Printable Version)
Post Title: need advice 95 Q45 162k, gas smell
Posted by: ahmed_wasim at 7:56 PM 10/14/2006
Guys,
I have 95Q with 162K on it. Last winter I noticed the gas smell when stopping at stop lights. Took it to Infiniti dealer they couln't replicate the problem. The smell vanished in summer.
Now since the winter has started (yes it has started in Canada) I can smell the gas again. If I open the hood I can smell gas from passenger side (after driving). The car runs smooth and has no problem otherwise.
I remember reading here about tightening somthing. Can you tell me what it is?
Regards,
Wasim.
Post Title: Re: need advice 95 Q45 162k, gas smell (ahmed_wasim)
Posted by: elwesso at 8:10 PM 10/14/2006
The fuel hoses on the back side of the plenum are probably at fault.
Post Title:
Posted by: CrimsonQ at 8:21 PM 10/14/2006
Sounds like the same problem I had (posted a thread with video of hose dripping sometime last year)
Was a 5-6 inch peice of hose running into firewall area under passenger side of plenum.
Only leaked on cold starts then after soking in heat it would stop.
Post Title: Re: (CrimsonQ)
Posted by: ahmed_wasim at 9:18 PM 10/14/2006
Hi,
Do you still have the video. Or is it still posted somewhere
Regards,
Wasim.
Post Title:
Posted by: Jesda at 9:32 PM 10/14/2006
I just tightened mine. Its the vertical rubber hose with two metal clamps, right below the IAC. You -can- reach the screws with a small screwdriver if you move the throttle cables. Its a lot easier though to buy an IAC gasket and remove the IAC for cleaning while youre back there.
Post Title: Re: (ahmed_wasim)
Posted by: ahmed_wasim at 8:42 AM 10/15/2006
The link from last year
http://www.sdproducktions.biz/media/qfuelvid.mov
no longer works
Post Title:
Posted by: CrimsonQ at 10:06 AM 10/15/2006
ahh i need to pay my bill lol. Itll be back up tonight 8pm central.
I tightened mine as well but later replaced
Posted by: ahmed_wasim at 7:11 PM 10/15/2006
Hi,
I tightened mine also. It was a small vertical one in the area shown in the picture. I was only able to tighten the bottom part of hose. There is no way to reach the upper part. I didn't try to tighten it too much, just 3-4 rotations, is that enough or should I tighten it more.
I drove the car after that, initially there was some smell but now it seems gone. I'll try again.
Regards,
Wasim.
Posted by: goody90q45 at 7:27 PM 10/15/2006
That's the spot they were directing you to. I had two leakers back there when I first bought my Q and eventually was able to get to them both. I gave up at first but kept going back with different tools.
With the right tools you can get to the clamps you've given up on. Make sure to check for leaks with the engine cold as small leaks tend to slow down as the hoses heat and expand. As Jesda suggested, you may have to remove the IAC valve (adjacent to the right side of your circle) to get to all the clamps.
Hopefully you've reached and tightened the right clamp(s) and the fuel odor will go away once the residual evaporates. Good luck.
Posted by: lino at 2:46 PM 11/7/2006
Are these the hoses you guys are referring to?
Can anyone tell if these look original or if they may have been replaced?
I checked mine and they are very tight. I get the fuel smeel in the morning when I start the car for the first time.
Post Title: Re: (lino)
Posted by: 96Qowner at 2:59 PM 11/7/2006
Those aren't the ones. The usual suspect is a fuel hose buried deep under the middle of the plenum. It connects to the fuel pressure regulator and leads to the hard line to the fuel filter. Kinda under that yellow rectangle in the previous pics.
Post Title: Re: (96Qowner)
Posted by: lino at 3:01 PM 11/7/2006
Thanks I'll try to locate it tomorrow morning.
Posted by: GeesQ at 2:12 PM 11/21/2006
I had the same problem with my 94 Q and this morning I tightened those hoses and it seemed to have done the trick. The screws were amazingly loose where I was able to turn one about 4 times and the second one about 3.
Post Title: Re: (GeesQ)
Posted by: lino at 4:26 PM 11/21/2006
Anyone have any pics?
Posted by: Q45tech at 4:41 PM 11/21/2006
Modern fuels eat these hoses from the inside and thus their I.D. increases.
Tightening once is just a temporary fix.
Just part of the PERIODIC [every] 80-120k under plenum hose replacement.
