Fuel tank 15-7/8 gallons
Coolant (with reservoir tank) 7-1/8 quarts
Engine oil without filter 3-3/4 quarts
Engine oil with filter 4 quarts
Transmission fluid
Manual transmission (M/T) 5-1/8 pints
Automatic transmission (A/T) 8-3/4 quarts
Differential Carrier (R200) 2-3/4 pints
Differential Carrier (R200V) 3-1/8 pints
Power steering system 1.0 quart
Air conditioning refrigerant 1.8 - 2.0 lb of R12
Engine Tune Up Data:
Engine model KA24DE
Firing Order 1-3-4-2
Idle speed (in "N" position, No-Load) 700 +/- 50 rpm
Idle speed (In "N" position, Air Conditioning ON) 1000 +/- rpm
Ignition timing 20 degrees = +/- 2 degrees B.T.D.C. at idle speed
High tension cable resistance less than 30 kilo ohms
Spark Plug Type
standard BKR5E-11
cold BKR6E-11
cold BKR7E-11
gap mm (in) 1.0-1.1 (0.039-0.043)
tightening torque
N-m 20-29 (2.0 - 3.0 kg-m, 14-22 ft-lb)
Drive belt deflection (cold) all belt measurements in millimeters with
inches in parenthesis
alternator 11 (0.43) limit
deflection after adjustment 7-8 (0.28-0.31)
deflection of new belt 6-7 ( 0.24-0.28)
Air conditioner compressor
limit 12 (0.47)
deflection after adjustment 7.5-8.5 (0.295-0.335)
deflection of new belt 6.5-7.5 ( 0.256-0.295)
Power steering pump withOUT SUPER HICAS
limit 13 (0.51)
deflection after adjustment 7.5-8.5 ( 0.295- 0.335)
deflection of new belt 6.5-7.5 (0.256- 0.295)
Applied pressed force N (kg, lb) 98 (10, 22)
Power Steering pump with SUPER HICAS
limit 9 (0.35)
deflection after adjustment 6.5-7.5 ( 0.256- 0.295)
deflection of new belt 5.5-6.5 (0.217- 0.256)
Oil pan drain plug tightening torque
N-m 29-39
kg-m 3.0-4.0
ft-lb 22-29
Clutch pedal height mm (in) 186-196 ( 7.32- 7.72)
Clutch pedal free play mm (in) 1.0-3.0 ( 0.039- 0.118)
Front wheel alignment (unladen) fuel, radiator and engine oil full with
spare tire, jack, and tools.
camber -1 degree 30' to 0 degree
caster 6 degree 00' to 7 degree 30'
toe in mm (in) 0.3 - 2.3 (0.012 - 0.091)
toe in degree 2' - 13' ( total toe in angle)
Full turns inner wheel 39 degree - 43 degree
Full turns outer wheel 33 degree
Rear wheel alignment (unladen) as above
camber -1 degree 30' to -0 degree 36'
toe in mm (in) 0.5- 4.5 (0.020- 0.177)
toe in degree 3' - 25' (total toe in angle)
Brake:
CL22VB (non-abs)
pad repair limit mm (in) 2.0 ( 0.079)
minimum front rotor thickness limit 18.0 (0.709) mm (in)
minimum rear rotor thickness limit 8.0 (0.315) mm (in)
CL25VA (abs)
minimum front rotor thickness limit 20.0 (0.709) mm (in)
pedal free height M/T 177- 187 (6.97 - 7.36) mm (in)
pedal free height A/T 186- 196 (7.32 - 7.72) mm (in)
parking brake # of notches 6-8 (under force of 196N, 20kg, 44lb)
Engine Compression in PSI
standard 179 @ 300rpm
minimum 151 @ 300 rpm
difference limit between cylinders 14 @ 300rpm
Thermostat inspection
valve opening temperature 170 degree fahrenheit
maximum valve lift 0.31 inches @ 194 degree fahrenheit
Oil pressure check
Idle Speed More than 11 PSI
At 3000 rpm no load 60-70 PSI
Radiator cap relief pressure 11-14 psi
leakage test pressure 23 psi
< Contact Us - NICO
