Remember to click the pictures to see larger images, etc.
The information presented was collected and gathered from public web sites, as well as various Nissan and Infiniti User's Guides, Owner's Manuals and Service Manuals (which are copyrighted by their respective owners).
In all the posts, the latest updated information is in bold red text that will be reset to black at the next update!
___________________________________________________________________
2003/2004 M45
Capacities:
Engine Specs:
Wheels and Dimensions:
OEM Tires
1. Bridgestone Turanza ER33. 235/45-18 94W. Grand Touring Summer.
2. Michelin Pilot HX MXM4. 235/45-18 94V. Grand Touring All Season.
2006 M35/M45
Capacities:
Engine Specs:
OEM Tires
1. Goodyear Eagle RS-A. 245/45-18 96V. High Performance All-Season.
2. Bridgestone Potenza RE050A. 245/40-19 94W. Max Performance Summer.
If anyone would like to add to this information, please send me e-mail. Thanks!
Z
Post Title: Color And Trim Options (last updated on 09/30/2006)
Posted by: szhosain at 3:58 PM 11/1/2005
Exterior Colors:
Ivory Pearl
Brilliant Silver
Golden Sand
Black Obsidian
Diamond Graphite
Garnet Fire
Emerald Mist
Interior Colors:
Graphite Leather
Willow Leather
Interior Trim:
Smoke Bird's-Eye Maple
Natural Bird's-Eye Maple (with Natural Maple Shift Knob)
Color Combinations:
All exterior colors were available with interior color combinations.
2006 M35/45
Exterior Colors:
Umbria Grey
Serengeti Sand
Black Obsidian
Liquid Platinum
Crimson Roulette
Ivory Pearl
Diamond Graphite
Twilight Blue
Interior Colors:
Wheat Leather/Rosewood (N/A Sport Model)
Bourbon Leather/Rosewood
Graphite Leather/Rosewood
Graphite Leather/Aluminum (Sport only)
Stone Leather/Aluminum (Sport only)
Color Combinations:
Umbria Grey
Serengeti Sand
Black Obsidian
Liquid Platinum
Crimson Roulette
Ivory Pearl
Diamond Graphite
Twilight Blue
Post Title: Available Tires
Posted by: szhosain at 12:38 PM 2/17/2006
2003/2004 M45
Available Tires:
2006 M35/M45
Available Tires:
Post Title: Wheel Alignment Specs
Posted by: szhosain at 9:42 AM 3/5/2006
Also note that the 2006 M35 AWD model has different alignment specifications than the non-AWD M35 and M45.
Of course, remember to set wheel alignment with a full tank of gas, and items like spare tire, tools, etc. are all in their correct places in the trunk. No other unladen weight either - i.e., remove all the other "stuff" from the inside and the trunk!
Note that our resident Infiniti expert, Q45tech, also says the following (quote mildly edited):
| Quote, originally posted by Q45tech » |
| YOU OR YOUR WEIGHT MUST BE IN DRIVERS SEAT! Otherwise the alignment will be off when you get in the car! Assuming you drive alone. If you always have a passenger, the same loading situation must be maintained during alignment proceedure ... assuming you care about perfection. Your weight [150 -300 pounds] in the seat will lower the drivers side by 0.2-0.4" which will change the drivers side camber by 0.16-0.32 degrees. |
Of course, the above applies to the alignment, not the wheel arch height data!
2003/2004 M45
Alignment Specifications:
2006 M35 AWD, M35 2WD and M45
Front Wheel Alignment Specifications:
Rear Wheel Alignment Specifications:
Post Title: Gear Ratios and other Transmission information
Posted by: szhosain at 11:33 AM 3/6/2006
2003 M45
Gear Ratios and Other Information:
2004 M45
2006 M35/M45
Post Title: Final Drive ratios and other information
Posted by: szhosain at 12:36 PM 3/6/2006
2003 M45
Final Drive Ratios and Other Information:
2004 M45
2006 M35 (AWD only)
Front Final Drive Ratios and Other Information:
2006 M35/M45
Rear Final Drive Ratios and Other Information:
Post Title: Notes
Posted by: szhosain at 12:41 PM 3/6/2006
1. The OEM 2006 M35/45 wheels have a very high offset and cannot be used on other Infiniti models (using spacers is not recommended!)
2. The OEM 2003/2004 M45 wheels can be used on other Infiniti models since the offset is compatible with many of them.
3. The NISSAN Matic J Automatic Transmission Fluid is required for the Infiniti transmission warranty to remain in force. Do not substitute any other ATF.
< Contact Us - NICO
