Cjmartz2k wrote:I'm pretty sure it had nothing to do with the transmission oil and a little more to do with the 740rwhp Regan---awesome!! That kicks a** dude
NO TO THE AUTO. Spend the coin on some gears, and billet forks. Maybe hunt for a R34 6 speed... then remove the T-case like people have done with the rb26 box.WhatsADSM wrote:Like they say, if you aren't braking things then you don't have enough power
Sounds like you might have reached the limit of that trans. Either the gearset or a built auto is probably your best bet.
opticnerv wrote:Maybe a V160 from a supra ? just thinking outside the box haha it would need an adapter plate just like a built auto transmission would need.
As much as we'd all love the 6spd Getrag box, people usually charge enough to shatter hopes and dreams. The Getrag gear box is a beast though... A 5spd gearset is a lot easier to find and install when it comes down to wallet thickness.Shocker wrote:
What tires are you running? This thing must be hooking hard to shock load the trans like that causing the damage. Also I'm sure you could shift a bit slower. Your not flat footing are you?
sidenote: WhatADSM your car looks f***ing mean.
I know I know, however tho when you consider the $3500 PPG set, + labor to install your looking at over 4 grand. Not sure what he can pick up a 6 speed from the GTR over there for, but it will be easier than making a bellhousing adapter plate and possible shifter location issues with the supras V160 which internally is the same transmission. V160 is stronger than the PPG gears in a GT-ST box, supra boys make 1300+ wheel through them shifting hard, running 7.9X times and don't break them. Which I'm sure you know. Not to mention they weight 3300-3700 w/driver.ItzGenX wrote:
I look at it this way, even if the GTR 6 speed is ~5k knowing it wont break might be worth it....
Crazy your blowing the trans even granny shifting. Generally shock loads are what kills transmissions first. How much torque did your motor make? Boostz3 is making about that same power and as far as I know has never ruined a gear, but has broken a shifter fork.
I'm aware of those internally same trans. Last I thought he was making 700ish on e85 through a Borg Warner Turbo... I could be confusing cars, but I'm pretty positive on that.ReganGTS25T wrote:im prety sure hes making around 100 less hp then me the z32 tranies hold up better cause of thier shorter design less shaft flex its what ive been told, the na z32 tt z32 pathfinder frontier trany gtr ecr33 are all the same gears jsut diffrent housings
Maybe on the shaft flex, the R33's is like an inch or two longer, so sure it might be possible to get a slightly larger gap as the mating gears pitch circles are pulled apart under high load. Most likely a flexture that the naked eye couldn't see..
I'm talking about the R34 GTR 6 speed getrag transmission.
Did the car make it in gear? It once the gear entered 3rd what happened? Or where you pulling through 3rd and it just blew to s*** part way through?
What? First off, bracket racing is gay. Extremely gay. Like two dudes making out gay. I'll assume you aren't talking about that. Now I don't know how much drag racing you do, but trying to build my car to go faster and challenging myself to drive it as fast as possible is why I do it. Trying to drive that beast Regan drives is more than tough to do. Now if you said he should go auto because nothing shifts as fast as an automatic, I might see your point. Of course I want to beat what ever car rolls up next to me, but I'll never go auto to help do that. I completely agree with shocker. The only way an auto transmission isn't lame is if your car has single digit e.t. potential.DrifterProdigy85 wrote:Built Auto FTW. Drag racings pointless if your not running consistent ETs.
i race in peru bro we use a dusty track in the middle of the desert no prep what so ever its worse then racing on the streetDrifterProdigy85 wrote:Isnt he breaking all his trannies through drag racing? Hes got a fast car and by his sig he hasnt gotten out of 11's yet with 600whp. Thats a problem. Its not just being able to drive the car, its having it properly setup to run fast. There is so much crap to deal with trying to run fast with a stick car that it can take the fun out of it. Just because its auto doesnt mean you cant roll race with it. You put it in a low gear and go. The only gear you dont want to race in would be your OD which shouldnt hurt if your cars gearing is properly setup. With his power, 3rd gear or his 1:1 gear should be doing well into the 140's. Thats plenty fast enough to roll race or beat anyone from a roll. Ive done alot of drag racing, street and strip and it becomes quite emabarrassing trying to tell someone how much power you make and then let them watch you run to a 11 or 12 second 1/4 cause you chunk the launch or miss a gear. You dont have that issue with an auto. OP, look into the 4l80e if your interested in having a super strong trans with OD. Otherwise pickup a Th350 or th400.
That is a weaksauce way of fixing this issue, and IMO is for lazy old timers. Its way more impressive for me to see a 10 sec ~ single digit car that is piloted through a true MT. His 700+ whp skyline is more than capable of a 9 second pass, but that comes down to the driver mod and a transmission that can handle it obviously.DrifterProdigy85 wrote:Isnt he breaking all his trannies through drag racing? Hes got a fast car and by his sig he hasnt gotten out of 11's yet with 600whp. Thats a problem. Its not just being able to drive the car, its having it properly setup to run fast. There is so much crap to deal with trying to run fast with a stick car that it can take the fun out of it. Just because its auto doesnt mean you cant roll race with it. You put it in a low gear and go. The only gear you dont want to race in would be your OD which shouldnt hurt if your cars gearing is properly setup. With his power, 3rd gear or his 1:1 gear should be doing well into the 140's. Thats plenty fast enough to roll race or beat anyone from a roll. Ive done alot of drag racing, street and strip and it becomes quite emabarrassing trying to tell someone how much power you make and then let them watch you run to a 11 or 12 second 1/4 cause you chunk the launch or miss a gear. You dont have that issue with an auto. OP, look into the 4l80e if your interested in having a super strong trans with OD. Otherwise pickup a Th350 or th400.
