Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Sun Nov 01, 2009 7:43 am
So my friend wanted to install Windows 7 on the two computers at his house. He doesn't know how to do that, so I went and helped him. They sell a family pack of Windows 7 with a key that lets you install on 3 PC's. So I got their third copy for installing the other two on their computers.
I installed Windows 7 on my laptop yesterday morning, and was damn nervous as to whether or not I would be reformatting and installing Vista again.
The first impressions;
I didn't have to find a single driver. In the obnoxious words of a Mac user... "It just works".
But it really did work. All the drivers were found and everything installed correctly.
The pack that was bought was an "upgrade" pack. Well upgrading an OS sucks. I want a clean install. So formatted the HD, and I ran it as a clean install. When I went to activate it, I expected to get a message telling me that my "key isn't valid for a clean install, please upgrade a qualifying windows product". No such message. It activated... Woot woot!!! (Vista screwed me when I tried to cheat them that way).
It’s not a resource hog. Vista required at minimum 1 full gig of RAM just to operate the system, with no applications running. Vista (at idle) would also keep my processor at about 5-7% usage all the time. 7 is running at about 1.15 gig of RAM but I am copying a disc right now also. Without DVD Shrink running right now, I would guess it to be in the 700 MB range. The proc usage (at idle) is still in the 5-7% range. Now the upside is that I actually have the option of disabling a lot of the resource usage, like aero and some of the other graphics displays, without having to go to extremes to disable them. There is a drop down menu, and you just uncheck the boxes, and I would assume that it would drop the memory usage down. I am currently running 4 gigs and have 512 megs of DDR3 on the video card, (in a laptop) so I am pretty damn well covered and won’t be adjusting those settings.
Programs install a lot faster on Windows 7. CS2 usually took around 20 minutes to install on Vista. It was complete in less than 5 minutes. Nero took around 10 minutes to install on Vista. It was complete in about 2 minutes.
There is a “page docking” feature which is pretty damn cool, if you can get more than one damn window open at a time. It will dock pages to the sides of your screen, so you can have two web pages side by side, and not have to fiddle with using the cursor to fit them. Pretty cool addition.
The “quick launch” has been re-engineered. It is now just a task bar and you “pin” your programs to it. Okay, big deal, no different really. One great feature is the ability to move the taskbar and dock it to the top, bottom, left or right side of the page. That I really like.
UAC. You actually have the option to tone down the pop ups, or completely turn it off. I still turned it off, but at least there are options on how invasive and annoying you want it to be.
Folders are laid out so that navigation is much easier. The start button menu still looks about the same, but “Libraries” is “pinned” to the taskbar. So one click of that, it displays all the folders that are on your start button, and then you have a nav panel on the left that allows you to click through a lot of other stuff.
IE8 is better than IE7, but that is like comparing which dump I took was better. It’s still IE, but it doesn’t have the continuous crash that IE7 suffered from. Since I actually like IE, it is a nice upgrade, and they seemed to have fixed the password problems that the beta version had. Downside is that it is a PITA to open multiple windows. I know it is fixable by going to IE options, and uncheck the box that says “open new pages in a new tab”, but I want my pages to open in a new tab.So that process is a little different, and I will have to figure it out.
WMP is still basically the exact same, but they added some tabs and simplified the libraries a little bit. It makes finding your music a little easier.
Now I had tried the beta version of Windows 7, and thought it was a catastrophic suckfest. It ran like crap, IE8 was a POS, it hogged almost as much of the memory as Vista did, it just started everything up slowly, instead of all at once. After using the beta version, I had figured that Microsoft had failed again. To my surprise, this works pretty damn good. It’s a hell of a lot better than Vista and much more user friendly/modifiable.
I’ll add more to this review when I get a better feeling for it.
