Nissan techs please help--Which VQ do I have???????
Discuss topics related to the VQ series engine.
40flash
Car: 240sx 95 S14 VQ
I bought a VQ and 6spd a this spring to put in a Z. Changed my mind and am now putting it in a 240SX S14. Here is my problem. It has the right manifolds and looks just like a VQ from a 2003 G35 like I was told it came out of. It even has the G35 plastic intake manifold cover. The Guy I got it from got from a guy who was going to put it in a Dune buggy or something. It has a fan clutch on the front. To my knowledge, all VQs came with electric fans except possibly the pathfinder but the ones I have seen have a different intake maifold. Maybe the fan clutch was added for the dune buggy application. Any Ideas how I can tell for sure what I have? I tried to post a picture of my VQ but couldn't figure out how to do that.
VQMaxima
Car: 2003 Nissan Maxima and 2009 Nissan Murano SL AWD
You have a VQ35DE, same as Altima, Maxima Pathfinder, Murano etc.
40flash
VQMaxima wrote:You have a VQ35DE, same as Altima, Maxima Pathfinder, Murano etc.
Thanks, but You have made a statement, but have not supported your argument. How did you conclude it is out of one of those cars? I have never seen a FWD Altima/Maxima/Murano VQ that has a cooling fan on the water pump like mine? Have you? Why would they when the radiator is not on the side of the car? Pathfinder maybe, but In what year did the pathfinder ever come with the same intake manifold as the G35/350z?
VQMaxima
40flash wrote:Thanks, but You have made a statement, but have not supported your argument. How did you conclude it is out of one of those cars? I have never seen a FWD Altima/Maxima/Murano VQ that has a cooling fan on the water pump like mine? Have you? Why would they when the radiator is not on the side of the car? Pathfinder maybe, but In what year did the pathfinder ever come with the same intake manifold as the G35/350z?
The Block and Internals are all the same on every VQ35, but the compression ratio may vary. they all have the same bore, except the Pathfinder and murano if I am not mistaken 95.5cm something to that affect.
I don't believe their's a cooling fan on the water pump never heard of such a thing? does it say 3.5L on the Valve Cover? or you didn't get one with it?
The 350z/G35 never came with the same manifold to my knowledge.
40flash
It came with the plastic cover that sits on the top of the engine that has the Infinity logo and says 3.5. It has RWD motor mounts also.When you say that "The 350z/g35 never came with the same manifold," do you mean the G35/350Z manifolds are the same but that manifold was never put in a pathfinder, right?I'm hoping that an owner before me put the fan clutch on it for his installation. My engine serial number is 925915A VQ35. Does anyone know how to check out that number to identify this thing? Who can I contact? Wish I knew how to post a picture.
VQMaxima
40flash wrote:It came with the plastic cover that sits on the top of the engine that has the Infinity logo and says 3.5. It has RWD motor mounts also.When you say that "The 350z/g35 never came with the same manifold," do you mean the G35/350Z manifolds are the same but that manifold was never put in a pathfinder, right?I'm hoping that an owner before me put the fan clutch on it for his installation. My engine serial number is 925915A VQ35. Does anyone know how to check out that number to identify this thing? Who can I contact? Wish I knew how to post a picture.
My mistake that was a typo on my part, yes the 350z/G35 share the same manifold.
40flash
VQMaxima wrote:
No problem. I thought that is what you meant. I think I must have a G35 VQ because as far as I can tell G35,350Z and Infinity FX are the only cars that came with that manifold and none of them came with a fan clutch. I think the former owner took a fan clutch off a pathfinder and stuck it on the G35 motor. Everything else seems to match G35 specs. If anyone has come up with another possibility, help me out.
Nealoc187
Car: 95 Maxima
G35 Sedans (at least the autos anyway) have belt driven fans unlike all the other VQ35s (not sure on pathfinder, those may well have had belt driven fans too).
All VQ35DEs have the same bore and stroke. They are all 95.5mm. Pathfinders have a 10.0:1 compression ratio due to piston design differences and head combustion chamber size differences. Pathfinders have flat top pistons and smaller combustion chambers (also different shaped intake ports on the heads).
Modified by Nealoc187 at 2:26 PM 11/4/2009
Modified by Nealoc187 at 2:27 PM 11/4/2009
splitime
Car: 93 miotta-t
Nealoc187 wrote:G35 Sedans (at least the autos anyway) have belt driven fans unlike all the other VQ35s (not sure on pathfinder, those may well have had belt driven fans too).
Exactly as he said. Pulled a VQ out of a G35 auto sedan a few months ago. It had the clutched fan on the front.
40flash
Thanks. That helps a lot. I was worried I had something strange.
FAST-DATSUN
NEED PICTURES OF THE INTAKE AND ENGINE MOUNTS TO KNOW FOR SURE!!!!!
40flash
I am pretty secure with knowing what I have now. It can't be anything other than a 2003 G35. How are you guys coming with those prototype headers for the VQ S14 swap? I am thinking about your motor mounts and trans mounts for my project also. Did you guys use a laser sighting devise to line up the trans and the rear end when you designed the mounts?
FAST-DATSUN
Street/strip headers done..All our mounts are adjustable do you can dial in the engine and driveshaft aligment...
OPY: RWD and RWD block are very different
40flash
Thanks. I am planning to order your mounts when I get to that stage of the project.
Andy4106
Car: 91 s13
08 frontier
if it has a clutch fan on it.
it was a rwd vehicle.and you guys are wrong on the pathy. but close. you could have either one out of the g35/350z or something out of a frontier/xterra/pathy.
n20sled
Car: 06 g35
why don't you just cross the block number but its probably a vq40de
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
