2004 Sentra sub wiring
A great resource for Nissan Sentra, Infiniti G20, 200sx, Pulsar, NX1600, NX2000, Tsuru, Primera and Sunny owners.
kasey24e
Car: Nissan 240sx (1990)/Nissan Sentra (2004)
Does anybody here own a 2004-2006 sentra with the factory sub that would be willing to go out and take a picture of the seven wires that run into the sub? Mine all got pulled out while I was attempting to disconnect the base, so if anyone knows which wire that is so i can simply not reconnect the broken piece of junk that would be great too. I found similar topics in the forums but no direct answers, thank you for your time.
kasey24e
I got the wire order, if anyone was wondering, across top- blue, blue/white gap, orange-across bottom-black, empty plug, grey, grey/red, black/pink. However, the display still has no power, the fuse is good and so is the ground, any help?
nametakennow
Car: '06 MINI Cooper S
Display went out on mine years ago, though it occasionally would work at random. No longer an issue when I replaced the head unit after the CD player stopped working.
Check the back of the HU and make sure everything's tight, but it's very common for these to go out and you may be out of luck short of replacing the unit.
kasey24e
The thing is, it only turned off when I unplugged the base, I plugged it back in and no change so Im confused, I checked the fuse I guess Ill end up just bringing into the shop.
Return to “Sentra Forum / Infiniti G20 Forum / Pulsar / NX Forum”
