is there a dipstick in a mannual transmission on a 1990 300zx z32
wv300zx
Car: 1990 nissan 300zx
how can i check the fluids in my 1990 300zx? its a stick shift two seater. its making a noise and i need to check the trans fluid..is there a dipstick anywhere?
wv300zx wrote:how can i check the fluids in my 1990 300zx? its a stick shift two seater. its making a noise and i need to check the trans fluid..is there a dipstick anywhere?
No.
There are 2 plugs - One is a drain plug (bottom of trans), one is a level check plug (side of trans).
Remove side plug. Fluid should be AT the level of the hole - Stick your finger in there or look inside with a flashlight.
wv300zx
how do i know if i need fluid or not? and thank you for such a quick post im new to the 300zx i think im going to like owning it
Like I said, fluid level should be at the level of the hole. In other words, add fluid until it flows OUT of the side filler hole, then replace the plug.
wv300zx
ok thank you
