Didderson »
https://forums.nicoclub.com/didderson-u38557.html
Thu Jul 02, 2009 6:14 pm
Sand blasting the valves is NOT YOUR PROBLEM at this point buddy.
Oil is sliding through where the long rod is on those valves. Called a valve seal. Take the head off and replace em. I did a writeup that didn't get put into the articles section that you may search for.
Sandblasting them will help get the carbon off, but may just fuk up their surface so you'll have to re-seat them anyway. Just use goof off or carb cleaner to clean the valves duhhh
edit for claro clarity:Your compression is wonderful, which means even IF your valves have soooo much carbon on them (LOL) they're seating and sealing perfectly fine. You're correct the problem is oil coming thru the valves, but it has nothing to do w/ the valve seal seeing as the valves OPEN and thus the oil slides down the shaft and valve and enters. Sry we were all nubs once. I apologize but you acted like you knew exactly what was wrong and you weren't totally right so...
Also op, this is the 2nd time I've told you. your sig is filled with annoying nub grammar. the word site is a website, the word sight is the act of seeing.
Modified by Didderson at 9:21 PM 7/2/2009
