Fuel gauge
kingpin35
Car: 2004 M45
Has anyone had a problem with their fuel gauge? I have a 2004 M45 and ran out of gas the other day. My gauge showed over a 1/4 tank and the computer said 90 more miles until empty.
EniGmA1987
Car: '06 Infiniti M35 Sport
Mine is the oposite problem. Shows I am empty when I still have about 5 gallons left in the tank.
kingpin35
Car: 2004 M45
I'd rather have your problem.
BigP
Car: 2006 M45
If you can't get it fixed I recommend you put a fixed amount of gas in (I use 10 gallons) and reset your trip odometer. If you are pretty sure you get say 16 MPG then you should get 10 more gallons when you get to about 140 miles. It will work with any number of gallons but it's easier to do the math with 10 gallons and if you do the same every time you get gas you won't have to remember how much you put in each time.
My M45 seems to be accurate, but I had a Jeep Cherokee that did what yours is doing.
RAGTPZ
Car: 1993 Nissan 300ZX Twin Turbo Convertible, 2010 Infiniti FX50S
kingpin35 wrote:Has anyone had a problem with their fuel gauge? I have a 2004 M45 and ran out of gas the other day. My gauge showed over a 1/4 tank and the computer said 90 more miles until empty.
Very common problem among Y34s (mine for one). If you ultimately want it fixed, it will take a trip to the dealership to have the gauge cluster replaced.
kingpin35
Car: 2004 M45
Thanks that was what I was looking for.
szh
Car: 2018 Tesla Model 3.
There is a big thread on this issue in our forums. Please do a search ...
You may need to print it out and take it with you to the dealer and push them to give you a fix. If the car is out of warranty, then you need to push them a bit - may need to contact Infiniti Corporate about the issue.
Z
