RT22 »
https://forums.nicoclub.com/rt22-u137418.html
Fri Jul 03, 2009 1:27 am
The screws are under the lip of the black trim ring of the center dash part, around radio and ashtray. look at the AC controls, now look under the lip of the big black ring around the controls. UNDER neath the lip, the screws are basically right above the control slides, 2 phillips head screws, and there are 2 under the ring at the bottom by the radio. run your fingers under the black trim under the radio and you will feel them. the ring is black and runs all around the controls and between the radio and ac controls and ash tray. once you find and remove them the ring pulls straight out and you can see the inside of the dash around the ac controls then it all just pops off by pulling.
