94 J30T HICAS four wheel steering
General discussion forum for J30 and M30 owners!
Victor
Car: 1994 Infiniti J30T
The owners manual says the four wheel steering only is activated above a certain speed, and either turns the back wheels in the same direction as the front, or in opposite direction than the front, depending on speed. I had someone follow me and they said they couldn't observe the back wheels on my car turning. Is that because they weren't turning, or is the amount of turning so small that you can't notice it from a distance?BTW, it seems to me four wheel steering would be most useful at very low speeds like when parallel parking, so why they only made it active at higher speeds seems like a bad design decision to me.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Yes, the amount of steering is very small and difficult to notice...around a degree or so. Honda had a 4 wheel steering system used for low-speed situations like you mention, and the degree of steering was more noticable.
HICAS has a different purpose. Since small changes in toe can make a noticable difference in vehicle dynamics, HICAS is used to help fine-tune vehicle balance on turn-in. Here's an illustration by Nissan (for the 240sx specifically, but the system works the same on all cars)"
driverdriver
Car: NICO's longtime resident Canuck!!!
I love HICAS, zero body roll, very flat cornering-like your on rails, I can take a lot of corners at a higher then posted speed limit without losing control.
beals8888
Car: 1993 j30t
this fat cat is a monster, yes it will take alot of work but not many mods this car, I have seen what this cat can do.
Return to “J30 Forum / M30 Forum”
