C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu Jun 18, 2009 9:00 am
The KP technology device only needs to be hooked up with one wire to the board behind the control stick. Namely, the pin on the board that gets grounded when you press the enter button. I'd suspect the board is probably the same as other QX56's using the same dash layout. Wouldn't make much sense to change the hardware unless they are changing layout. But even still, its still likely to be a signal that gets grounded when the button is pushed so all you need to do is find the pin that gets grounded when you press enter. Then solder the signal wire to that pin.
As for the ability to program while driving, you merely need to wire in a spdt relay (you can use your own or buy the kit with it included) to the speed signal wire.
I have this in my Titan. Works great. Though, my intent in buying it was to eliminate the legal disclaimer screen. The programming while driving was simply a bonus. Though I did order it with the relay and beeping device. I highly recommend the beeping option as I can barely hear the relay when it clicks over.
