the coolest boats ever!
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
im building an rc gas boat, and i was looking at rc boats on youtube, i ended up coming across these boats!http://www.youtube.com/watch?v...ext=1
feel free to post other boat vids!
Modified by darens13 at 10:18 PM 5/31/2009
93coupe
Car: crap
These races used to come on television a lot but I never see them anymore. Hands down the coolest boat races ever. Those are some talented drivers.
TougeChallenger
Car: 91 240SX
Damn thats crazy. They must be hitting a couple Gs when cornering liike that.
NME-s12
Car: 1995 kioki s14 w/ s14 sr20det , 1986 s12 biuld in progress
Thats a hole bunch of crazy! Any one now what type of hp numbers they run?
starscream6
Car: 93 civic/B18c
Classes
There are two internationally recognised classes
Class A - Engines in Class A boats are restricted to either 6.7-litre (412 cubic inch) engines with cast iron blocks and heads or 6-litre (365 cubic inch) engines with aluminium heads. Both size engines are only allowed two pushrod operated valves per cylinder. Furthermore the engine must be normally aspirated, using a 4-barrel carburettor. Fuel is 100+ octane aviation fuel. Typically these engines produce up to 650 horsepower
Superboats - Engines in the superboat class have no maximum size but instead have a minimum size restriction. Normally aspirated engines must have a displacement of 6.5 litres (400 cubic inch) or while forced induction (turbocharged or supercharged) engines must be at least 3.8 litres (235 cubic inch) in displacement. These engines typically are fuel injected and run methanol fuel. The small-block engines typically produce 950+ horsepower, while the big blocks can typically produce between 1000 to 1400 horsepower.
Nitromethane and nitrous oxide are not allowed.
