Pharaohabq »
https://forums.nicoclub.com/pharaohabq-u94688.html
Mon Jun 01, 2009 7:55 am
Hey Awesone, Congrats on your "new" Z. it looks pretty good. No doubt you'll find more rust, but it definitely looks good, it's got very little rust in comparison to most you'll see. Though yeah, you'll want to get on that rust asap! and get a couple cans of spray primer to protect the areas you clean up in the meantime. then get it all stripped out and you're set.
One of the first things you should do is decide what diection you want to go with the Z. Do you want to restore it to classic stock style? If so you'll want to step back and crunch some numbers. it's not cheap.
It kinda sounds like you want to modify it. If that's the case, there's a ton of stuff you can do. Though you'll again be best off looking at where you want to be with it. If you're wanting Turbo, you might forget that L26, just start looking for an 82/83' Turbo engine and 5 speed transmission. you'll save a ton on swapping parts that later you'll be replacing anyway. Also at the same time the Turbo engine comes with the electric Dist, lighter AC(as was said) and you might even consider a 300zx VLSD at the same time. There's a ton of options open at this point just save yourself some $$$ and make a plan.
Also, now that you found a car look into Classic/modified insurance, it's cheap and will cover the car's real worth rather than risk having it totalled for a paint scratch...
So, all that being said, congrats again, and we look forward to more pictures.
Phar
