ScorchedNX2K wrote:you spent 6 hours buffing/polishing? That's a bit of overkill... A couple hours at most is sufficient even for the most swirled/scratched up car...and that one was not bad at all. Takes me an hour and a half for a car, 2 hours for an SUV to do a 3 stage polish (cut, swirl remover, polish)Some time wasted...but good looking.
No overkill here, time wasted was time I had, if there is no need to rush the detail in anway then, exactly that, no need. I'll break it down a little:
At two passes per panel for each stage of the buffing, you're looking at easily a half hour per panel for the smaller ends. I pace the buffer along very slowly at 900-1000 rpms, making swirls impossible. The car could have been done in a day had I wanted to, but on an energy conserving process I made sure there were no defects left in this car at all. Thanks
