ShippingShipping is not included in any of the prices, unless otherwise noted. I ship USPS parcel post or FedEx ground unless other method is requested. Faster FedEx and USPS services available. Shipping to Canada is available, but buyer pays brokerage fees and duties. Buy 2 or more items together for free ground shipping.
PaymentIf paying by PayPal with credit or debit card, add 3%. If via an e-check, add $5. Bank checks, money orders also accepted. Everything is ready to ship same day payment is made.. Local pick up for cash available. No personal checks unless you don’t mind a waiting period for them to clear.
Thanks for looking, email me at
[email protected] with any questions. Plenty of references available upon request.------------------------------------------------------------------------------------------------------------
RPS Segmented Flywheel (TT)
Brand new, in the box, never even been mounted. Thought I needed a new flywheel for a clutch issue, turns out I was wrong. I’m selling here before I return it so I can avoid a restocking fee. $415 shipped and paypalled anywhere in the continental US.
A’Pexi SAFC II, Black:
Excellent cosmetic condition, however, I could not get it to work. It would power up, as the knob would light up green, but I never got a working display. I was told it was working when I bought it from eBay years ago, but I can’t get it to work. Would be a perfect candidate for a cosmetic swap from a silver unit. I have not opened it up, so it may be a simple resolder job. I don’t have the time or need for it now though.
$65 shipped (Continental US)
Stock intercoolers:
I have 2 sets of stock intercoolers for sale. Both are leak and crack free, minimal bent fins. One set has some black overspray, one is clean. The oversprayed set still works fine, just cosmetically imperfect.
The cleaner IC’s:
The oversprayed IC’s and ducts:
ducts no longer available
Intercoolers only: $90(clean pair) $70(oversprayed pair)
Ducts, hoses and clamps are no longer available
Lower Timing Cover:
Excellent condition, two available.
$20 for lower cover
OEM stereo converter:
This unit allows you to use an aftermarket head unit with the stock Bose system. Also has 4 channel RCA outs for amplified expansion. Unit sells for $39.99 new. Excellent condition.
$20
Light Control Pod
Control unit only, no plastic pods to mount to dash. Perfect working order, excellent cosmetically. No broken mounts. Out of my 1991 TT. Great for replacements or cores for a LED conversion.
Light control: $40 (new is $135)
1991 TT CAS painted satin blackWorks fine, I switched to a 95 CAS to match my harness
$75 shipped
Cam Gears
One Intake cam gear – No leaks, great condition: $100 shipped
One set of exhaust cam gears: $30 shipped for the pair
ES Bushings in Tension Rods
OEM tension rods with black 3-piece ES bushings pressed in. Also available, OEM brake air guides, complete with hardware.
$80 shipped Tension rods$40 shipped Air guides$110 shipped For the combo
Also available but not pictured:
(Pictures available upon request. Shipped prices are continental United States only. Email for quotes for other regions.)
90-94 lower plenum. Good condition, $30 shipped.
90-93 TT Power Steering Pump, good condition, removed because I have an NA subframe: $55 shipped (new is $430) I can include the engine bracket as well if needed.
90-93 TT Power Steering Reservoir, good condition. $35 shipped.
90-93 TT HiCAS pump, good condition $55 shipped
Brand new OEM heater core hoses: $25 shipped for the pair
Compressor outlet pipes $40 shipped
Both VTC solenoids: $35 each shipped , $70 for the pair.
Two TT front shock actuators: $20 shipped
OEM exhaust manifolds: $30 shipped
Complete EGR system – Valve, solenoid, tubes: $50 shipped
Platinum Mist Metallic mirrors, pair
Platinum Mist Metallic fender, driver side.
Platinum Mist Metallic T-tops. Include bags and shades
Charcoal sun visors, pair
Door seat belt assemblies
Map light assembly
Various HVAC ducts
Clifford Concept 600 Alarm, complete
Some charcoal interior panels, ask about specifics
Passenger and driver seats, charcoal leather, good condition, local only
T-top wind deflectors
…And a bunch of other stuff I just took off the car. Let me know if you’re looking for something specific and I’ll see if I have it.
Thanks for looking and happy Zing.
