Finger chopper be gone! (Electric fan install)
karism
Car: 1992 Nissan 200sx. CA18DET
Halo Everybody.
So i got tired of the viscous fan sound when driving.Decided to put on a nice electric fan.
I bought the fan,and ordered the controler.
Finished up the install last night.
Specs : 14" FanElectronic fan controler,with water & oil temp display,and variable fan on and off setting.
Enginebay space after the fan is installed
Temp probe installed into thermostat housing
Fan temp controler showing water temp
Finger chopper where its supposed to be,on the ground where the dog can chew it
Karis
ThuG LyFe
Car: 95 S14
lucky i wish i could do this...
Ghost_silvia
Car: 1991 nissan silvia s13
How much did the whole setup run you? I need a thermo probe and temp sensor, cause I turn the fans on manually Also where are the parts from and is the oil temp actually hooked up to tell temp?
karism
The whole setup ran me R1000.I sourced it locally here in RSA
Only the water temp is hooked up at the moment.The next step will be to wire on the oil temp sensor.
Stay tuned,i`ll come tell you guys about it
sloweighty
Car: sileighty
where did you get that efan controller?
kornmanz
Car: 89 240sx Hatch SR Powa'd
guys I can take a few pics of my setup if you wish but it is by far the easiest and cheapest way to do it.
get a 12 inch fan (35 bucks at autozone) and wire it into your fuel pump fuse. This way when you turn the key the fan turns on. Its always on but its ok, keeps the car running perfect.
AZ89two4Tsx
So how much did it cost?
Ilvemynissan
Car: 240sx s13
$R1000?
EnjoiNismo
Car: 93 240sx
AZ89two4Tsx wrote:So how much did it cost?
sputnik
I only have R500
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
sputnik wrote:I only have R500
Ditto what kind of Fan Controller is that and where/how much was it?
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
Guys I belive the cost of this set up is clear
"The whole setup ran me R1000"
Never heard of an "R" denominational bill. The ratio of "R100" to a US Dollar is rougly the same as the ratio of unicorns to leprechauns.
Yeah I tried hooking an E-Fan to one of my cars this past weekend didn't run a relay (big mistake!!!) I guess like "kornmanz" did running power to the fuel pump fuse essentially ran it off of the fuel pump relay thus not running to high of an amp to any wires and frying them like I did.
I hope he responds and really lets you know how much this set-up cost!
TimTurboZ
Did a little searchin from his myspace he's from south africa
1 US Dollar = 9.39761 South African Rand 1 South African Rand (ZAR) = 0.10641 US Dollar (USD)
1000/9.4= roughly $106
Ta-Dah!!! 2 min of research and you can stop scratching your heads!
Welcome!
Ghost_silvia
I liked the unicorns to leprechauns ratio better Does that fancy search thingy majiggy tell you what brand its?
karism
I leave for 5 minutes and it turns into this?hahaha
Let me provide a link to the Fan controler,it is made by autogauge :
http://www.autostyle.co.za/pro...6&str=
The fan controler consisted of the following :
1x fan controler1x wired 30amp relay2xtemp probes with long enough wires,and clips1x double sided tape for fixing the controler3 x cable tie for the wires
Cable tie = Tie strap/ Honda clamp/whatever it is called in your neck of the woods.haha
I will not run a single 12" on a turbo charged engine.It will not keep the temp low enough if running off a switch,and not constantly
The 14" fan fits the core perfectly like it was made for it
Karis
redclaw05
Car: 1993 s13 caged vert
clutch fan + shroud > *
karism
redclaw05 wrote:clutch fan + shroud > *
Each to their own i guess!I hate that the fact that it makes it sound like pickup with the viscous.
Crap!I cant believe i spelt controller wrong the whole time haha.
Unstock240
Car: 89 240sx se
I heard doing this can around 10-15 horses from less strain on the engine, did you notice any gain?
brandonDavid
Car: 1992 240sx, 1992 D21
Unstock240 wrote:I heard doing this can around 10-15 horses from less strain on the engine, did you notice any gain?
i dunno about that much, but i know e-fans do free up horses. i was wondering the same, i'm about to put some electronics on my truck...
dtowndrifter
Car: s-14 kouki
looks good...i dont think one fan cuts it here in Texas..
7anshin8r
Car: 96 Nissan 240sx
dtowndrifter wrote:looks good...i dont think one fan cuts it here in Texas..
That is what I was wondering about the hot Florida summers.
ZX88
Car: s13
clutch fan > electrics
ddgsxr504
ZX88 wrote:clutch fan > electrics
Uhhh.... no. Please explain your thought process on this.
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
no wiring, no failing, etc.
i plan to run a combo of the two when i boost the car... single high cfm e'fan on the rad, then a clutchfan behind it... keep that SOB ice cold
s13gebala
Car: 99 Nissan Maxima
91 Nissan SR hatch
you have any pictures of how its like in south africa ?
would be nice to see :]
karism
We were running 97 here yesterday ,and we are still in spring..... It held up fine to the temperature,even sitting in traffic for a few min.
I read up on the specs of the fan,and it looks like a 14" straight blade fan flows 1000 CFM.
>> According to heat dynamics ,a radiator only needs postive airflow of 30% of the core size,to cool the water sufficiently. << Now my fan covers 100 % of the radiator in the height ,and more than 60 % in the width.
Hence working fine!
One fact that is more important for airflow ,is how well the radiator is sealed off,and able to utilise the air porvided.Air leaking around the side and top/bottom decreases the capacity of the air cooling the core.
This is one of the reasons that the Rad fan (when not using a factory shroud),should allways be the same size,and not larger than the core.The edge of the fan blades that are not over the core,will pull the air around the core,and not through it
Practical example : If i fitted a 16" fan ,the would have been overhang of 1" per side of the fan.the specs of the fan says that it flows 2000 cfm.Now the 1" of the blade that protudes,is allso the most curved part of the blade,that generates the most flow.The curved part now disrupts the flow (not flowing through the core) ,and flows less than the given CFM.This sometimes knocks of 100s of CFM,not just 5 or 10
Fan placement ,fan shrouds , clean core and correctly working thermostat is much more important than the size of the fan in the end.
Ok,my fingers are going to fall off now...
Karis
karism
s13gebala wrote:you have any pictures of how its like in south africa ?
I have some photos of camping trips?and some of the seaside.
Would that do?
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
i wish i had room for a pull-fan in my engine bay have two 12" spal push fans though
karism
Good thing you are using SPAL fans.They are one of the best,if not the best on the market.I will be using SPAL fans on my beetle when it runs
