Finally! Someone else who has REAL experience. It drives me nut how people listen to shops and not their wallet. I have known so many kids who've done the SR swaps through shops and its cost them close to 4-6k. Where as the system you described above is maybe 1200 bucks. lol! Its just crazy. peace.jilo860 wrote:i just bought a 91 hardbody and im thinking of doing the same thing. ive been through 240's and sr's also and id say just sticking with the ka is the easyest idea by far. im not looking for much power out of mine, just torque so im not even thinking about rebuilding the engine.
the easyest cheapest route is t28 from a s14 240sx550cc injectorscheap cast exhaust manifoldmuffler shop downpipe and exhaustenthalpy rom tuned ecucheapo intercooler kit300zx maf
basically a done deal and not much fab. the ka has a long stroke and good displacement so with a small turbo, lots of low end torque is possible. and 10 psi out of a t28 isnt gonna hurt a ka.
Would this work on a pathfinder too??jilo860 wrote:i just bought a 91 hardbody and im thinking of doing the same thing. ive been through 240's and sr's also and id say just sticking with the ka is the easyest idea by far. im not looking for much power out of mine, just torque so im not even thinking about rebuilding the engine.
Not to start a crazy debate here, fact is what you want from your exhaust is an increased diameter in exhaust. It isn't possible to get the exhaust ports large enough for the flow it will demand. On a KA24de you have 2 exhaust valves which increases curtain space. Exhaust ports are determined on curtain space, not necesarilly the size valve that is used. In comparison a KA24de head flows 1/3 more effecient in CFM when flow tested on a flow bench. Stock for stock the DE head is considerably better. Thats all the fact I would need to determine exhaust flow rate, more curtain space, equals better flow.You could enlarge a KAe exhaust valve and port the exhaust but then again we would be talking about doing a considerable amount of work, and time is money...nismopu wrote:Thats incorrect thinking. Could you tell me the size of the exhaust valve on a KAe? Also, you know the 4g63 mitsu turbo engines have oil squirters as well but in race form they get blocked off because they cause a loss in oil pressure at higher rpms.
Thats right. Right now my car is in the process of a paint job and the KA engine is getting stripped down for an internal rebuild. I work to much so now I just troll and try to chime in when ever I can....nismopu wrote:BTW, just checked your username. I remeber you from over in the KA section when I used to troll through there, you've heard all this stuff before. Especially from some of the old school guys like deviousKA, and Jason grey.Heck you've done a couple cool KA builds in the past right?
SR guys may remove them but as far as I recall Ivan at AMS still has the highest HP and fastest 1/4mile KA24det to date without removal of oil squirters or use of a windage tray and scraper. His record beats the highest HP sr20det to date.nismopu wrote:Sr guys remove them in most high HP applications, they're not needed. They work best in stock form, if what your saying is true for the reasoning of KA's needing oil squirters then SR's would'nt require them either. Pressure is pressure and where there is a drop, there is a problem. right? I understand your thinking of exhaust flow, but its not necessarily flow that spools turbos. My single cam turbo spooled my t3 just fine before 3k and my friends DE spools maybe 200-300 rpms quicker.
Its not boost pressure that kills ringlands either, its usually detonation that breaks them. If pressure killed ringlands then guys boosting with stock bottom ends on t4 setups of upwards of 20psi would be blowing there guts out. As you know its all in the tune.
I'm a noob to this forum, but not to turbo'ing engines that were never intended to wear an exhaust-driven air pump off their exhaust ports. That being said, that quoted statement makes no sense.Bigvinnie wrote:
As far as detonation, it's not an issue with the KA24de since NGK, and denso offer the best iridium plugs on the market to date. Denso and NGK only offer platinums for the KA24e. Most detonation/early misfire usually occurs from spark plug temprature, and or cylinder chamber hot spots.....So yeah I can agree to some extent that detonation/early ignition can damage ringlands but if you also use boost it would increase ring failure.
Detonation is caused by poor tuning, not spark plugs. Whether you're running NGK BKR7whatever copper plugs, some nice NGK Iridiums, or platinum triple forked lightning ricer whizzers, if your ECU isn't keeping pace with what's going on in the head, you will get detonation. Period. I've never seen boost pressure break stock rings either and that's on little 75mm bore Hondas pushing 20+ psi, but again on a solid tune.
Pressure won't cause it. It's a rotating assembly. Increased pressure causes to rotate faster, and as long as everything is firing when it's supposed (tuning), you won't harm anything. It's when the timing/tuning/or AFRs are off that detonation occurs at a point the rotating assembly isn't ready to have that particular piston pushed down that you run into bent rods, blown rings, or even fragging the top of your piston. Iridium spark plugs won't prevent that.
Well here I go... back to old fundementals that people forget....Of coarse bad tuning has alot to do with mis fire and detonation... The critical truth is ignition timing..... Here is the temprature to ignition timing to spark plugs... The chart shpould expalin that egt plays a large factor in this but yet it is just a simple graph.Technically you can run an engine lean or rich, where you get detonation is from ignition timing being to far from load which is your K values. If your load is high and you advance timing to much and raise EGT you get misfire, plain and simple. Spark plugs although can reduce this problem as long as you are within a REALISTIC CAS, and K value. If you are a bad tuner you shouldn't be tuning to begin with.... Then you need to understand load, a bit better. But if it is within a realistic load setting then your just dealing lean heat variables from A/Fr's.nismopu wrote:I gave up after he posted the spark plug comment, lol. This is interesting this little tiny thread in the Truck forum( go figure) has sparked this much attention when theres like 15 others just like this ones title. very interesting.
Anyway, you know a good place to find a comp. map for a hy35 Holset? peace.
Iridium plugs have a melting point at 4000* F, thats 2/3 greater than the melti point of copper, and 1/2 the melti point of platinum plugs. You can get misfire from not gapping platinum, or copper plugs......I have NEVER gapped a set of iridiums, and I have never had misfire as long as I have used them as a motorsport enthusiast.nismopu wrote:This is all basic tuning knowledge dude. Wheres the point with the plugs you listed? Whats there heat range?
O.K so your saying that you don't know how boost pressure raises EGT's?You don't know how boost pressure increases flamefront propagation?You don't know how boost pressure increases cylinder temprature which effects spark plug life and misfire if not correctly tuned within the K value?nismopu wrote:Also, if you were talking about detonation, then why did you mention pressure breaking ringlands?
I've seen alot of ford and dodge diesel owners use it.nismopu wrote: Vinnie you know where I could find a good comp map on the holset hx35?
