2004 Maxima SL w/ 170k knocking noise and high gas consumption?
Trungster
Car: 2004 Maxima SL
Can someone help me out? Anyone from the Toronto area who knows a shop that can stop the engine knocking noise? And as for gas mileage im getting 12-13.5L/100km. Any idea what the problem may be? Any help will be greatly appreciated.
johnnyd6404
Car: 2004 G35 Coupe 6MT 2k2 Maxima SE(sold) 2005 Altima 2.5S
are you using super like recomended? If not switch ASAP dont cheap out its good for the engine and will reduce/eliminate knock also run a can of techtron through the tank to help remove the carbon build up in the engine and should help with your mpg. Also use synthetic oil to futher help the engine and mpg.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
There should be no knock even if running regular unless something else is wrong.
Is the car showing a CEL? Any codes showing?
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
I have to say that's some impressive mileage. So if google has not failed me you are running roughly 18mpgs, what were you getting and when did you notice the l/km going down?
Have you replaced your plugs. There are a few other sensors that have a life span. Although the owners manual does not specify things like the O2 sensors actually have a life span, and may require replacement after a certain amount of time. Things like proper tire inflation, quality of fuel used, amount of weight in the trunk, condition of your air filter, and loads applied to the engine will all have a negative effect on fuel economy. Any recent service info would be helpful in assisting you in the right direction. Oh and whats your oil level like and what type of fuel have you been using?
Modified by SteveTheTech at 1:43 PM 8/31/2008
Modified by SteveTheTech at 1:44 PM 8/31/2008
