Quick question about stock boost solenoid mounted on ignitor plate.
redsx13
Car: 93 240sx 03 350z
ok, I know that the stock SR boost pressure solenoid located on the ignitor plate is unused when the motor is swapped into a usdm 240.but.....
my question is, can you unplug and remove the two solenoid/sensor's located on the plate, remove the plate,and just keeping the ignitor?
the reason i am asking is because i recently removed the whole plate (just kept the ignitor) and cut off the plugs going to the two boost control solenoid components.i did that while doing my swap, and my car runs like ****. is this my problem? (p.s. when i cut off the plugs, i wrapped up all the wires. they are not touching one another and they are not touching ground.)
redsx13
Come on... i know someone knows this one.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Yeah, I want to know this as well!
SpeedRacer1
Car: 1990 240SX, G35
Yes, you do not need either sensor plugged in nor the plate to run the car. However I will say this, when you use the boost control solenoid and properly set up the vacuum piping the engine will run approx 11.5 psi of boost instead of the 7.
Neither of these sensors will cause the car to run poorly if they are tripped, wired wrong, grounded out, etc.
positron1
Thanks, I've been pondering about that for some time.
redsx13
SpeedRacer1 wrote:Yes, you do not need either sensor plugged in nor the plate to run the car. However I will say this, when you use the boost control solenoid and properly set up the vacuum piping the engine will run approx 11.5 psi of boost instead of the 7.
thankyou, I would be running the solenoid, but i have an hks electronic boost controller.
Tulsa_S-13
Car: 1991 SR 240sx
Are you mounting the plate on the driver's side strut tower? If so then your igniter chip won't reach. If you plan to run the plate on your passenger side then you'll need to drill into the tower to mount the plate.
Only if he replaces the line that contains the restrictor. If not, then even with the solenoid wired properly he'll run 7psi. I know because I was running 7psi with the solenoid, replaced the line containing the restrictor and from then on it ran 11psi.
s13gebala
Car: 99 Nissan Maxima
91 Nissan SR hatch
had to bring this thread back, whats the boost solenoid restrictor?
i have the ignitor plate to and i was super confused on where it goes...
i like the sound of 11 psi :]
