Keep an eye on your oil level, when my first turbo took a dump, I drove it for about 10,000 miles until I could afford a new one, it only smoked at idle, more when it was hot. Check your hot pipe, its likely the oil is only leaking into the exhaust, if thats the case, all you are going to do by driving it, is destroy you catalytic converter and oxygen sensor.Clawhammer wrote:I guess my next question is, how long does she have?
Thats not true at all. I rebuilt the T25 on my car now, it doesn't burn a drop of oil, and its been on the motor for 2 years and around 30,000 miles. Ive rebuilt more than a handful of turbos with great success. As long as you replace the seals, bearings and thrust plate, as well as clean everything properly, there is no reason a journal bearing turbo cannot be rebuilt.boro drift wrote: Also, once the cartridge of a turbo starts leaking oil out of either end, it's done. Turbo City told me this but I rebuilt the turbo on my Supra anyway. It slowed the consumption down but didn't stop it.
Sporadic oil leakage is a common symptom of a restricted oil drain.91SilviaKs wrote:yeah but the finny thing is mine only does it like once every couple of weeks or so, very sparingly....I think that for some reason mine loads up on fuel for some reason every once and a while...BTW I'm not running a cat either...
Rich
