Replacing fuel injector problems
green93GXE
Car: Black Emerald 93GXE + Pearl White 92GXE
I have a 93 GXE - VG engine. I replaced the #5 fuel injector with a new one. When I put everything back together the car won't start. The cylinders are full of gas resulting in a hydrostatic lock. I checked my spark plugs and they're working. Any ideas?
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Fuel injector o-ring. It likely isn't seated correctly. You'll need to pull that injector out again and make sure the o-ring is still in good shape. If so, lightly lube the o-rings and put the injector back in. You should feel it seat pretty snugly when it pops in. That should fix your issue.
Also, you'll also need to drain the oil and put new oil in. The fuel that leaked into the engine will drain past the pistons into the oil ruining it. Definitely DO NOT forget to do this!!!
I actually had the exact same thing happen to me in the past.
green93GXE
hey, thanks. Yep, it was the O-ring, the one on the bottom of the injector. Should I be concerned about the O-rings that are in the lower manifold that the fuel rail mounts into? Thanks again!
mtcookson
1992 Iinfiniti Q45
and much much more
If they look worn out I would replace them. They won't cause any nasty fuel leaks but will cause a vacuum leak causing the engine to run poorly.
green93GXE
I got it all back together and she purrs like a kitten!! Thanks for your help!
mtcookson
1992 Iinfiniti Q45
and much much more
Good deal!
jdefelic
Car: 1993 Nissan D21 Pickup
mtcookson
You are like the VG30 all knowing guru. You are amazing. Every post you reply to with the best information and it's dead on. I have never seen anything like it. How do you do it? I'm just in awww. I to you.
I will not kiss your feet though... well maybe if i need help
mtcookson
1992 Iinfiniti Q45
and much much more
Thanks for the compliments, I really appreciate it!
I just love the VG30E engines and study them as much as I can. They are old technology but can pack a mean punch when modified, they're pretty reliable, inexpensive, and the list goes on. I'm actually working on putting one in my Z32 that I'm very confident will take on many DETT powered Z32's.
Return to “VG30 / VE30 Forum”
