custom turbo kit?!?
x Too Fly x
Car: 1991 240sx s13 hatch
can yall give me a list of the things i need for a custom turbo kit,
i think ima just KA-T mine. but if u can give me the list it would be appreciated greatly!!!
chaos2000
Car: 89 240sx HB (s14 sr20det)
90 240sx Coupe (nothing,yet)
Search and you will know. All the part you need and all the information you need is in the stickys.
x Too Fly x
i mean where do i search?!?
i googled it and all i did was get actual kits!
r3v_v3ng3
Car: 91 fastback ka-t
on top of the page theres SEARCH option and its blinking.
480sx
Car: 1996 Pearl White 240sx
Just read the Ka-T info sticky from top to bottom, every link and you will be set.
Its at the top of this page, labled Ka-T Info & FAQ (STUCK).
x Too Fly x
ok. thanx.
ima noob at this stuff. but i do kno bout cars.
shimizu_17
x Too Fly x wrote:ok. thanx.
First of all check out your engine to see if it has good compression. If your engine is bad there is no point to even go ka-t until you rebuild or get a new engine. Depending on how much work your willing to put into the car and how much knowledge you have will greatly determine what parts you should buy as well.
do you know what kinda turbo you want?How much money you want to spend?What kind of power do you want to make? lookin to drag race, auto x, or drift with it? because depending on what type of driving you do will determine what setup will be good for you.
To help you get started I guess ill list my setup
ETD log maniGreddy 20g turbotial 38mm wastegate megan downpipemegan test pipemegan exhaust550cc rc engineering top feed injectorsgreddy top feed fuel rail greddy fmicturbo xs bov Z32 mafJWT ecu walbro 255 fuel pump300zx fuel filterkn filterngk ididium plugsspec stage 3 clutchautometer boost gaugeblitz turbo timer aem widebandapexi safc 2
Modified by shimizu_17 at 9:25 PM 7/20/2008
x Too Fly x
well i want kinda cheap like 1200 or sumthin but yea it has good all that. and i dunt kno yet. i do drift but not all tha time.
WDRacing
With a budget like that you're going to have to use EBay parts. Just becareful...some are prone to failure.
WD
x Too Fly x
well wat if i buy lik a 800 doller turbo or sumthin and juss buy ebay piping and an actual intercooler?!? would that work?
480sx
You need a LOT more than a turbo, intercooler, and IC pipes for a turbo kit man.. Please, do your own research.
Buying an 800 dollar turbo with a 1200 dollar budget is retarded.
x Too Fly x
well yea i kno but i was just wondering if i could. that one guy said he payed 1100 to turbo his KA. and yea i kno i need more stuff. im juss tryn to find out. thas y i posted this forum!
moulton712
Car: coupe, hatch, both s13s
just wait till some one is parting out their car. i got most of my ka-t parts for $350. turbo, turbo elbow, down pipe, piping, intercooler, 370 sr injectors. etc.. the t25 had no shaft play and had about 50k on it. just look around if you want to do it for cheap. u don't need to spend $800 on a turbo. unless you have more money to back it up. just look. i was going to give myself $4000 for a motor swap, but i found this deal and i'm going ka-t
shimizu_17
for 1200 bucks you could go the popular T25 setup. Its cheap and effective to a extent.
ebay manifoldebay downpipeebay test pipeebay exhaustemance ecu sr injectorssr smicsr bovsr T25 turbosr intake setupwalbro 255jgs oil linesautometer boost gaugeaem/plx/ some kind of wideband if you can afford it
That should be around the 1200 and get your turbo. Not much room to grow but if thats all your willing to spend thats about what your going to get realistically.
x Too Fly x
ok thanx i was juss wonderin. if all fails i kno sumone that can make me a custom one for lik 2000.
thanx people.
240sxvaj
1994 MKIV TT-Daily/Track
Ka-t nice, Good luck.
Modified by 240sxvaj at 1:46 AM 7/23/2008
