because not everyone wants to go backwards in technology from coil on plug to wasted spark, plug wires, and a big box you need to find somewhere to hide in your engine bay.craz4240 wrote:Why not do a GNX coil retrofit??
Yes, I own that car now, and have no problems w/ it whatsoever...if you need me to help out anyway with getting this setup to work for you, let me know...i'll help where I canBlown240sx wrote:IF you want a strong setup we ran 6 MSD SS blaster coils on my friends 400 whp RB and the spark output puts any of the factory or aftermarket replacments to shame and cost about the same..
How to....
take your coils out and pull out the coil harness where its easy to see.
Mark each of the center wires they should be some combination of red/xxxx another color. Number them so you will remember what cylinder they fire.
Start at the ignitor and de loom the harness towards the coils. You will have 3 wires to each coil. 1 power, 1 constant ground, and 1 switch ground from the Ignitor.
The factory ground going to each coil will not be used.
Take the factory power and either daisy chain it across all the MSD coils or use it as a switch 12v for a thicker Relayed system. RecommendedWe used 10 gauge wire and a high amp replay since the factory wire is thinner gauge. You can use the factory power wire to switch your relay.
Now run your power, daisy chaining it off every coil to (+) side on the coil.
Now for the switch. Youll need to extend all the wires coming from the ignitor. The ignitor is a large relay essentially and it sends ground pulse.
Run a lead to each coil in the order you marked before removing the harness.This goes to the (-) negative side of the coil.Then use the boot kit they come with and make your wires and mount the coils somewhere and fire it up.
Yeah it kindof is but it works equally as good as stock and is ALOT cheaper to replace when the time comes.gawdzilla wrote:because not everyone wants to go backwards in technology from coil on plug to wasted spark, plug wires, and a big box you need to find somewhere to hide in your engine bay.
I cant take much credit since the previous owner (brandon) did the wiring but I fully understand how it was done and how it works.crccustoms wrote:good clean setup blown240, and i agree you'll end up spending as much or more with the stock style coils than the msd setup with 8mm that can be achieved for around $350 from summit, and if you need more spark due to higher compression $400 buys you higher output coils and 10 mm wires, the summit (sum-850500m) coils are rated at 51,000v and have enough power to fire the discovery space shuttle to the next galaxy, there $50 a piece at summit, $75-100 for a good set of wires and your set, and you would go about hooking up that setup the same way as the msd, negative being the trigger, which comes from the harness that your stock setup uses
your wideband is going to show false richness if you are misfiring. there is unburnt fuel that is coming out of your exhaust each time you miss a spark. that is probably why your wideband is showing rich.rb25drag wrote:Well, here is how it started. It first started when I went from 1st to 2nd gear it totally dropped 1-2 cyl for about 5 seconds then picked back up and ran fine. It only done it when I shifted and it dropped RPM's.
Then the more I ran the car it got to were it started misfiring anything above 5,000RPM's. On my last pass of the night it would not even rev over 5,000 While on WOT, and the A/F readings on my wideband went to 9.0 Which is Pig rich and it was holding 15lbs of boost, Not dropping off. I know there is no boost leaks and I also no its not a spark plug foul, It Revs Fine and idles good, no missing like a fouled plug would cause.
I pulled the plugs, They were Gray looking which seemed to be not too rich and not too lean, The Gaps are .022 just as I set them.
I have a s2 motor, Which if I went to the Buick coils I would have to buy a igniter and hack my harness, Which I don't really wanna do. I would rather just buy what fits and plugs in and go.
Im also afraid of the buick coil not working with my launch control which I just spent 300$ on.
Im almost 100% my coils are getting weak. I don't think they have been in the greatest shape from day 1, I just didn't wanna spend more $ than I had too.
I mean, Something is Def screwed, I went from a 7.80@91 in the 1/8th to 10.02 @ 67, on the same tune.
Ive tried to help push you in the right direction man but if you dont want to listen then thats cool too, i think that you fail to see that an 80a alternator cannot provide power to a car that has to run high amperage drawing electric fans, provide power to 6 coils which are individualy fired as well as 6 injectors all while powering the car's electronics and interior.Stick a multimeter on the battery terminals and run leads into the cabin and see what voltage looks like with everything on and running, i bet it will be low 13's at best...most likely high 12's.rb25drag wrote:I really don't think its electrical, Its def something with the spark.
