Chrispy300 wrote:I want to remove the oil filter branch off my VH45. I was just going to drill and tap the back of the oil pump and go from there. The only problem I can think of is the pressure relief in the filter tree. Is it really neccessary? Is it just incase the filter gets gunked up and wont flow?
As far as I can tell it's the only pressure valve for the oil pump.
Will it cause any problems having overly high oil pressure?
Anyone make know of any external aftermarket releif valves?
There was a large thread here on NICO that spoke specifically about this. Some discussion around whether the pressure relief was for clogged filter which would bypass the filter in that case, but in general whether it's a clogged filter or something else (i.e. different viscosity oil, etc.) the pressure relief is there to do just that - relieve pressure.
So to answer your question, pressure works in two ways; pressure to the engine and back-pressure towards the oil-pump. If you take the pressure relief valve out while it *may* not damage anything on your engine, the excessive back-pressure on the oil-pump will most likely damage the seals in the pump.
I haven't seen any external units, but someone may make one in the racing space. I looked through summit and didn't see anything. Good luck with your mod.
Thanks,Nick.
