Just went Turbo .... Tell me what you think
Sr20Det20
Car: 240SX
So i parted together a turbo kit cost me about 1100 but did it rite... t25 370cc injectors.. apr head studsCometic Gaskets and head gasket head ported and polished..walbro fuel pump ebay mani greddy oil adapter custom oil lines apexi neo gauges{boost & oil temp and press} godspeed fmic greddy rs bov comp clutch comp flywheel egr block off greddy downpipe 3inch import intel tune timing to 15* battery reloc.. custom intake tube got some pics of Matts drift beast also
what do you guys think ill dyno at and run in the 1/4 ith stock 7 psi
Modified by Sr20Det20 at 3:44 PM 7/30/2008
92KA-T
Car: 96 240sx
92 240sx hatch -sold
i just did mine as well.. today was the first day i actually got to drive it.. t25 burns a little oil at times.. need rebuild but i love it other than that..
lrb_2000
Car: '91 Nissan KA-T hatch
What are you using for tuning?You don't need to set your timing back to 15*btdc for 7psi. You're just losing power.
I'd say around 190whp and about a 14.5 1/4 mile... of course I know nothing else about the car besides this turbo setup.
boznuttz
Car: MS13
You really don't need to retard that much. If you wanted to be safe, just retard it back to 18 degrees or so. 7 psi would put your around 180 to 190 or so at the wheels. A friend of mine ran low 14s. He had a similar setup, 225 Kumho MXs, and a factory VLSD.
1mansho
what kind of tune do you guys suggest for 7 psi boost on a t25, tuned ecu or safc neo and back off timing a little? im running 370cc, n60 maf, t25
Sr20Det20
Car: 240SX
well if your going to run a n60 maf then you might have to flash your ecu ... i didnt flash mine and im tuning with a apexi neo ... my car runs fine ...
neverlift
he should be ok w/ n60 and 370cc... its the only maf/injector setup that doesnt NEED tuning, could it use it yes....tuned ecu hands down the best... without invasive stand alones.
afc and a btm are also good for that boost
480sx
Car: 1996 Pearl White 240sx
neverlift wrote:he should be ok w/ n60 and 370cc... its the only maf/injector setup that doesnt NEED tuning
Every time someones tried this their car has run pig rich and like ***.
This does not work at all, idk how that got started.
Sr20Det20
Car: 240SX
so i had my turbo now 3 days ... the turbo is now burning oil... i chked my car its not the head gasket so the only other thing it can be would be the t25 is buring oil
lancet913
Car: 1996 240sx se
KA24DET @12psi
My prediction on 1/4 mile and dyno.13.89 at 99 mph227 hp
When are going to the track?
480sx
Try to add an oil restrictor before you replace/rebuild it. What size of a line are you running to your turbo?
WDRacing
neverlift wrote:he should be ok w/ n60 and 370cc... its the only maf/injector setup that doesnt NEED tuning, could it use it yes....tuned ecu hands down the best... without invasive stand alones.
You need to stop telling people this is ok...because you are simply not correct.........................................................................................................................
At first glance the only thing I'd say would be to pull up your pants
WD
Sr20Det20
Car: 240SX
ouch we have a internet hard ***... watch out now
Sr20Det20
Car: 240SX
idk what size it is really but thats it on the top of the motor u can see in the first few pics... and now the car wont rev its sitten now in my driveway idles real bad at 600rpm and when i rev it nthn happens ... when i give it full thr it foes to like 2000k but dien out and reving ....idk im hoping tis fouled plugs
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
I like how u routed the valvecover breather tube back in after the MAF. People don't believe me but my car idles funny with it off.
This might sound stupid but check all of your pipes after the MAF. My Friends SR had an boost leak and ran exactly like you just stated.
92KA-T
Car: 96 240sx
lrb_2000 wrote:What are you using for tuning?You don't need to set your timing back to 15*btdc for 7psi. You're just losing power.
for tuning we used a SAFC2 and a wide bandwe put mine on the dyno tonight and it got 205.3hp and 243.49tq on 7 pounds im impressed by it.. 207700 miles on the motor..
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
looks pretty decent for the money, did you have to hack up that piping? I had to on my ebay piping lol
92KA-T
Car: 96 240sx
GTR PrYdE wrote:looks pretty decent for the money, did you have to hack up that piping? I had to on my ebay piping lol
my ebay kit made no sense.. good thing a buddy had a spare 1 peace cold pipe off of his SR and it fit right up.. only thing i used from the e bay set up was couplers and on the hot side where the intercooler meets the pipe..
tjmhillz
Car: 2001 Lexus IS300 Turbo
wes nice to see your finally boosted. wats up with the hair lol growing the fro back.. where was the pics taken at import intel? is this the same hatch u had before or this a new one?
Sr20Det20
Car: 240SX
same hatch tj ... i just cut the hair yest .. lol i got tired of it ... but yea car is still not idling and i cant drive it .. it wont rev rite... dont know what to really do ...
WDRacing
Sr20Det20 wrote:ouch we have a internet hard ***... watch out now
What makes me a hard ***? The fact that I was stopping the spread of bad information or joking with you about your pants being pulled down?
Sr20Det20
Car: 240SX
somone help me with this damn car ....
NateDogg
Do some research.Do a boost-leak test.Take pics of your setup.Test injectors for leaking.Get proper engine management.
Blown240sx
Car: 1996 240sx
Sounds like a vaccum or boost leak.
Sr20Det20
Car: 240SX
so turns out tis the maf... lol need a new one cant keep runing 245hp with maxed out injecors on a stock ka maf
240sxvaj
1994 MKIV TT-Daily/Track
Sr20Det20 wrote:so i had my turbo now 3 days ... the turbo is now burning oil... i chked my car its not the head gasket so the only other thing it can be would be the t25 is buring oil
Could be a few things, bad turbo seals, oil lines are not good(feed line should be smaller than return line), or you have a loop on your return line where oil cant get back to your engine and it burns out of your tailpipe. Happened to me before.
One other thing make sure to upgrade your fuel pressure regulator, my turbo set-up didnt last long before my fpr crapped out on me. i learned the hard way and got stuck on the road. i heard the reason why is because the stock fpr isnt made to handle the high flow walbro.
try to unplug the maf and if it idles better than the maf is bad and make sure it is at least 12" away from turbo(looks like it is) . i made 245whp and 241wtq with stock maf and 7-8psi stock wastegate using afcneo. your stock maf should be able to handle up to around 270whp based on a guy on nico.
also what is your vac/boost gauge reading, sounds like could be vac leak.
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
+2
Sr20Det20
Car: 240SX
when i unplug the maf it revs to 4 k but breaks up ...and when the car idles .. it idles at 740 the neo says.... wtf is wrong with this thing ... the cars vac is at 20 .... thats what the boost gauge says...
240sxvaj
adjust the idle and make it idle at 900rpm or 1000rpm and see if that helps. btw does it hold a steady idle at 740. You're only using an afcneo right? Honestly it works but they are pretty crappy there are days where it just goes crazy and doesnt want to work right. I think the neo is pretty accurate with tach reading though.
make sure to gap plugs to .033 and go at least 1 step colder, i prefer the bkr7e ngk iridium.
also make sure hotwire is 5in/5out
I prefer you get ecu tune something like emance, jason is really cool and especially the price it's like half the cost of that neo. Gauranteed it will be a thousand times better than that stupid afcneo. trust me i've been through two dyno shop with afcneo and i almost gave up but found out about emance. i went to meet up with him and didnt regrett getting his ecu tune. holds a really steady idle and way better power than trying to run retard timing the whole time, meaning better response when off boost. also better gas mileage. sorry typed so much. hope this helps. still check all couplers for boost leak.
Sr20Det20
Car: 240SX
i sset the idle at 1000 and it still idles at 740 .. and i used a fog machine to look for leaks found nthn .. even hoes down the damn motor still nthn ....
