GTR Injectors into RB20 (resistor)
ripracer
Car: 01 Dodge Ram & 91 s13 hatch
WEll I'm hoping to get to the dyno this week to see what my rb20 puts down with all the new parts I put on it turbo, carl h tune, tomei cams, yada yada. Well I'm using the GTR injetors got them for a super good deal and have them getting cleaned and tested right now.
Question: Does anyone know where to find a quide or wiring diagram how to wire the Acura Legend or GTR style resistor into the injectors harness?
I have been search and can't find anything dummy proof. I need pictures or a diagram to learn. Thanks for the help
StricNyne
i figured it out there is only 7wires i think, 1 power and 6 to each inj
ripracer
I think I got it.
Single color wire splice into the common 12v and then run the other six to the injectors.
Carl H
iirc the power wire from the eccs relay (which is hot all the time) is white and black. this runs to the injectors and branches off several times, so split the loom open and run the single different wire to that wire then run the others to the injectors.
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
my friend used accord v6 resistor on his rb26 and it runs like a champ when its not destroying oil pumps(crank collar)
StricNyne
i got the accord one i gotta splice it in still thou i was hoping for a plug and play soluition
