92 240sx will not start....help please (details inside)
Got questions about your Nissan? We're here to help, and it's FREE!
shinjimae
Car: chuki 240sx,92 dakota,91 integra
ok i just picked up a 92 240sx coupe and it will not start
it has a ka24de twin cam
it has sparkit has fuel
it will not fire
cant figure it out for the life of me
MaximA32
Does it crank?
shinjimae
cranks fine i had some people look at it and we reset the timing and it seems that it is the battery and or the alternator apparantly the ecu is not getting enough volts to stay on
240FeVeR
Car: 1992 240sx Coupe!
If it's cranking fine then you don't have a low voltage issue.Go through the basics.
1) Check ecu for codes2) Make sure the ignition wires are not mixed up.3) Make sure there is spark at the plugs not just from the coil.4) Check for loose connections on the air inlet hose, big vacuum leaks..etc 5) Disconnect the mass air sensor and see if it starts. 6) Compression test
Does it want to start if you hold the throttle open a little while cranking?
Return to “Nissan Online Mechanic”
