2007 Sentra 2.0S; Rims and TPMS
A great resource for Nissan Sentra, Infiniti G20, 200sx, Pulsar, NX1600, NX2000, Tsuru, Primera and Sunny owners.
nok610
Car: 2007 Nissan Sentra 2.0S CVT
I've been planning on getting new rims for some time now, but the TPMS issue has been holding me back. I wanted to ask if it is possible to replace my oem 16" rims with 17" rims (215/45 tires) and keep my original TPMS sensors? Would I have to take the car to Nissan to get the sensors reset to compensate for the wheel change? One last stupid question, will replacing the rims void my warranty?
Any help would be appreciated. Thanks.
djtorello
Car: 2008 nissan Sentra SE-r
Replacing your rims wont void your warrenty.Unless you get the wrong backspacing and destroy your calipers, But thats highly unlikely.
as for the TPMS, I dont know. Im swapping them between my current 17" wheels to a set of 17" gram lights.
nametakennow
Car: '06 MINI Cooper S
From my understanding of TPMS, the sensors can be put in your new wheels since all tire stem holes are the same size.
nok610
So when I replace the wheels, it won't put the computer on a fritz, being that the PSI would be different from stock wheels, and set off any warning indicators?
I'm probably being paranoid, but I just don't want the TPMS indicator flashing in my face all the time if I replaced the wheels.
nametakennow
Depends on what tire pressure the TPMS is set at. I've heard other owners say it's 35psi, which is a good pressure for a 215/45/17 anyway.
nok610
That sounds just about right to me... I guess I'll be picking myself up some Konig Hotswap and some Eibach Pro springs to go along with them.
Thanks guys.
sentrastace
hey i swapped my 16' rims on my 07 sentra for 18', and i just swapped the original TPMS system instead of buying a new one---its like $250 when u can just transfer it! anywhooo, it works fine, none of my warning indicators have been set off. i duno if u kno how to do it urself, when i ordered my rims and tires, my mechanic just switched them out--so dont worry
livinloud98
Car: 2007 Nissan Sentra S
idk with all the orange on the dash one more orange light doesn't bother me, i just deal with it...it stop flashing after about 30seconds and stays a solid light..
ill deal with a little light if it saves me a few bucks
djtorello
Having the light on saves you money? Thats backwards, simply because if you dont have proper air pressure, you waste gas, and gas = money.
nametakennow
If you're slightly over the air pressure sensor mark (while avoiding being overinflated), you'll actually reduce your rolling resistance and increase gas mileage.
I think he was referring to the cost of filling up the tires with air... which is free (not including a little electricity) if you do it with an air compressor at home. Even if you have to pay at the air pump at a gas station, it's definitely smarter to have proper tire pressure. If you let it slide too long you can cause poor tire wear and even get yourself in some dangerous situations, aside from the gas mileage issue.
nok610
Thanks guys, I just ordered the Konig's and should be shipping out today. I'm so pumped, I can't wait to get 'em. I'll post some pics when I get them installed.
I just got the wheels in, although I told them not to mount them cause I need the TPMS sensors installed to the new wheels... jerks.
Do you think the installers will get pissed off if they have to pull the sensors from the oem rims to the new ones?
Modified by nok610 at 10:41 AM 7/17/2008
Installers gave me a really hard time, but they installed the original TPMS sensors. I think they just didn't want to break the bead because they were being lazy. That's the last time I go to them. Other than that, all is well. The TPMS indicator didn't come on so everything's all good.
Modified by nok610 at 1:06 PM 7/21/2008
alex_btl
Car: Versa SL HB/QUEST SE
Hey
would you sell your stock 16 RIMS to me
Are they Alloy wheels with 4 LUGS
email me [email protected]
Thanks
nok610
They aren't alloy rims, they're 16" steel wheels with hubcaps.
Return to “Sentra Forum / Infiniti G20 Forum / Pulsar / NX Forum”
