Upgrade rear sway bar only?
supra33202
I have a 1993 S13 Hatchback mainly for drifting.
Currently I have:
Eibach Sportlines SpringsTokico Blues Shock Absorbers
I am thinking of just upgrading the rear sway with Tanabe rear sway bar.
So, I will have Front bar 24mm and 22 mm in the rear. Do you think this is good idea?
http://en.wikibooks.org/wiki/N..._Bars
If I were to upgrade both bars, I will get Suspension Techniques Front and Rear Sway Bar. Do they come with the stock endlink bushings and the bracket bushings?
In the near future, I will get:Energy supspension Rack and Pinion Bushings SetMegan Street Coilover (With the coilover, do you think I should just keep the two stock sway bars and replace the sway bar bushing?)Tein Tie Rod and Tie Rod EndSPL PRO V2 tension rodsRear Tanabe Sustec Strut Tower Bar
If I were to do adjustment for the rear suspension, I will get:
Megan rear upper control arms (RUCA)Megan Rear Toe ArmsMegan rear traction rods
What do you think of this setup for drifting?
Thanks!
94_240sx
Car: 94_240SX
Do research on Progress sway bars. They are good.
iitywygms
Car: 1993 sx se
I have both the front and rear progress bar. Beefy as #### and the heim joint end links are really nice.I am considering removing my rear one thou. I am going for grip, not drift and I have read that no rear bar is sometimes best for grip.
tramp_drift240
Car: 1992 240sx SE Coupe
^ ive got the progress rear and i love it. grip or drift, it does a damn good job.
im really trying to pick up a matching front bar with the sweet endlinks. i really liked how much of a differnce the rear made.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
progress makes good sh**. IF you have the extra deniro, Cusco makes nice stuff as well....
supra33202
I want to increase the steering response. There is dead spot with my steering.
I know I should replace:
Rack and Pinion Bushing (ordered from Energy Suspension; waiting for the part)Aluminum Steering BushingTie rods + Tie rod endsTension rod
What else should I do? I know I can get HICAS steering rack for quicker ratio, but it is over my budget.
Thanks!
supra33202
Thanks!
