Darius wrote:
I'm pretty sure the humps have to do with the PCV baffling in the valve covers along with the cam lobe covers on the 5 & 6 cylinders. Same with the RB26 except the humps extend further forwards. Not sure of how it all works together or the engineering behind it, but maybe someone else can fill that part in.
Works just like a baffled catch can, to seperate as much oil from the blow by gas as possible, so when it vents through the PCV you're not getting an overwelming amount of oil back into your intake stream.
If you look at the underside of the 26 covers you'll notice the difference between, R32/R33, R34, Nismo, and Mine's.
BTW, Matt your Email is blocking and sending back all my emails to you.
