how to lean it out?
livinglegend2100
so my cars been running really rich lately. smells god aweful with the windows or sunroof open. and it pops and crackles everytime i shift. most of the time when i downshift, it backfires so loud it even scares me..
is there any way i can lean it out a little without having to bring it into a shop?
BMAR240SX
Car: 1993 Nissan 240S Coupe
For backfire check the the spark plug and vacuum leaks along with, intake valve deposit
carmo
Car: 92 Accord, 90 Civic, 89 240sx
You may want to figure out why the car decided to start running so rich. Bad oxygen sensor? Bad MAF sensor? Bad ECU? Does the car act like it has a low rpm rev limiter? Alot of the time this indicates MAF sensor. Is there any other problems? Maybe cooling fans not working due to a coolant temp. sensor reading way low which could in turn cause the ECM the think the vehicle still needs to warm up thus it dumps gas.
livinglegend2100
it doesnt seem to run any different than it normally does. just pops, crackles, and backfires a lot.
Emperor_Tha
is your car boosted? Then recirculate your bov.
motoman399
Car: 98' wrecked (RHD coming soon) 240
clean your mafs, make sure there isnt any exhaust leaks, check plugs/wires, get a new o2 sensor. bet it will fix your problem
XTCshri2222
Car: 1978 Datsun 280z L28ET Powered
1991 S13 Ca18det coupe - sold
safc
livinglegend2100
cleaned maf 1 week ago. cars not boosted. new plugs + wires 3 days ago. ill have to try a new o2 sensor.
would it be easier/cheaper to get an safc or bring the whole car somewhere? i dont need performance gains off this or anything cuz the motors comin out this winter, i just want it runnin right.
e1_griego
Car: 89 fastback
If it's not running right, safc will be a bandaid (and I'd highly recommend against, anyway).
Check for ecu codes, since it's a free check. A lot of problems with running rich stem from bad coolant temp sensors or oxygen sensors.
Alex
livinglegend2100
yea i think im gonna go get this shiz checked tomorrow and see if its throwin codes. hopefully its just an o2 sensor or somethin..
ThuG LyFe
Car: 95 S14
hmm i believe i'm running rich too because it backfires when i slow down...plus i'm getting like 20 mpg. seemed to have started happening when i installed my 3" exhaust...any problem it could be that or i just didn't hear the backfire w/ the stock exhaust but it was still there?
prob. get a new o2 sensor this summer.
livinglegend2100
lol ya im gettin liked 16 mpg. its disgusting. i get about 270 **Km** not miles. my dash is in Km. so thats like what, 160 mi? out of a full tank of gas...
livinglegend2100
but im about to go get it scanned for codes right now. post up the results when i get back
livinglegend2100
so apparently nobody in my town has an OBD1 code reader for a nissan... this is a royal PITA... i really dont wanna buy one just to check for 2 codes..
gtc_240sx
Car: NISSAN 240sx 1990 Hatch, 1994 Honda Accord
you can check ur codes manually
ken240sx
Car: '92 KA-T 240sx, '08 Vette + Spray, '09 Benz C300, '98 Trans Am + Cam & Spray, '03 Acura TL Type S
Check out the FSM online and it will tell you how to check codes AND diagnose any problem with your engine. I read through the FSM when I'm bored lol...it's a great way to learn about your car.
